KyleIrving
Save options panel not displaying correctly on a mac - photoshop CS6
Aug 11, 2012 4:18 AM
Tags: #mac #cs6
Hi
I am finding that when using photoshop cs6 on a mac and when saving files as png or web files - the options panel displays as black and you are unable to see any of the options.
how do you change this?
    Aug 11, 2012 5:24 AM   in reply to KyleIrving
    And the version of the OS you are using is a secret why?
    Boilerplate-text:
    Does turning off »Use Graphics Processor« in the Performance Preferences and restarting Photoshop have any bearing on the issue?
    Are Photoshop and OS fully updated?
    As with all unexplainable Photoshop-problems you might try trashing the prefs (after making sure all customized presets like Actions, Patterns, Brushes etc. have been saved and making a note of the Preferences you’ve changed) by keeping command-alt-shift pressed on starting the program or starting from a new user-account.
    System Maintenance (repairing permissions, purging PRAM, running cron-scripts, cleaning caches, etc.) might also be beneficial, Onyx has been recommended for such tasks.
    http://www.apple.com/downloads/macosx/system_disk_utilities/onyx.html
    Weeding out bad fonts never seems to be a bad idea, either. (Validate your fonts in Font Book and remove the bad ones.)
    http://helpx.adobe.com/photoshop/kb/troubleshoot-fonts-photoshop-cs5.h tml
    If 3rd party plug-ins are installed try disabling them to verify if one of those may be responsible for the problem.
  • Noel Carboni
    Dec 23, 2006
    Aug 11, 2012 8:51 AM   in reply to KyleIrving
    Christoph touched on plug-ins, but I wanted to mention one more thing:  You haven't copied plug-ins from an older version of Photoshop have you?  Or pointed the Extra plug-ins folder setting at plug-ins from an older version of Photoshop?
    -Noel
    Aug 11, 2012 1:11 PM   in reply to KyleIrving
    We saw a few other people with problems like that in Save For Web.
    Reinstalling Photoshop or deleting preferences didn't help.
    What did help was a clean install of the OS.
    Aug 13, 2012 7:34 AM   in reply to KyleIrving
    Did you copy any plug-ins from previous versions of PS?  If so delete those.
  • Noel Carboni
    Dec 23, 2006
    Aug 13, 2012 10:41 AM   in reply to KyleIrving
    Please go into Help - System Info... in Photoshop, copy what's there, and paste it into a post here (remove the serial number info if you like).  This will provide a lot of system details, such as plug-in info, that people can use to help you further.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Aug 14, 2012 6:45 AM   in reply to KyleIrving
    Actually, there's a lot of important information across the entire thing (which is quite long, admittedly), but since it's now working for you there's no need.
    -Noel
