I received a zip file with contents I'm supposed to update in Robohelp 9 HTML. I know Robohelp for Word but not HTML very well. The only project file I find has the name ccaic_xls. the type column indicates robohelp html project.
I launch Robohelp, select this file and get a dialog box that reads: Confirm access: to execute selected action files in list must be writable. I click OK but none of the file folders or content from the zip file display on screen. I don't know what to do. I have to complete this test by Monday, August 13. Don't know what I'm doing wrong. Please help.
I
Message was edited by: matisse57
The XLS file you mention doesn't ring any bells. To open a RoboHelp project, you have to do the following:
1. Extract the entire contents of the zip file to a local folder.
2. In the project root folder, search for a file with the extension .xpj.
3. Double click that file and RoboHelp will open the project.
If this is not working, please post some screenshots of the root directory so we can see what is going on.
Good luck on your assignment.
Greet,
Willam
My own guess here is that the ccaic_xls is the XPJ as it bears the RoboHelp icon. Windows is likely hiding the file extension from you as it should be associated with RoboHelp. What happens if you just double-click the ccaic_xls file in the list? That should cause RoboHelp to open.
(assuming, of course, that you are looking at all the files after extracting them to a folder)
Cheers... Rick ![]()
Hi, Rick:
I did click on the ccai_xls file and it did launch robohelp. However, none of the existing topics I received in the zip file appear.
Funny, I clicked this icon several times before and got the following error message, now it opens the project with default content the client sent to me.
this is what shows now
Now I'm missing content from folders that were in the download. Shouldn't the folders default into the project?
Hello again
Ummmm, unless I'm mistaken, you are simply opening the zip file and attempting to run the project. As Willam stated in his reply, the first step here is to extract the content from inside the zip file to a folder in your hard drive. The fact you are encountering the issues you are is suggesting that you are unfamiliar with extracting zip files. So your first step should be to learn how to properly extract the zip contents to a folder. Until you are successful with this, the rest is moot.
Note that you will likely need to return the modified content in zip format as well.
Not Rick, but I hope it'll work too ![]()
The file indicated by RoboHelp is set to read-only. This may be because it was zipped or because it was taken from source control.
Simply select all the files, right click and choose Properties. At the bottom of the dialog uncheck the Read only checkbox. Click ok and let Windows make all your files writable.
Now open the project again.
Greet,
Willam
Willam, I suspect that the files are still inside the zip because if you look at the path, it's pointing to the temp folder. ![]()
That suggests to me that they are simply being viewed from inside the zipped package.
Thanks, for your help. It was my error in not properly unzipping the files. I have the project open and am now busily working on the tasks assigned. I do have one question. The generated help file has breadcrumbs across the top.
When I create new topics to the project, I don't see the breadcrumb trail on the newly created topics.
Any suggestions. I printed help from Adobe about breadcrumbs: selecting the pods view >single source etc., but it doesn't seem to work.
From what I see, the breadrumbs are probably set in the header of te master page. Did you assign the same master page to the new topics as is assigned to the existing topics? (Right click topic in the topic list and choose properties.)
Greet,
Willam
matisse57 <forums@adobe.com>schreef:
>matisse57 http://forums.adobe.com/people/matisse57 created the discussion
>"Re: Help. Trying to get a job. Sent a zip file to update in Robohelp 9 HTML."
>To view the discussion, visit: http://forums.adobe.com/message/4615824#4615824
In addition to what Willam suggested, it's worth noting that even if the topics are using a Master Page, you still may not see the breadcrumbs unless you created the topics from the onset using the Master page. It all depends on how the orignal author configured the breadcrumbs.
