How to control volume in Netstream
Aug 11, 2012 1:26 PM
Hello,
I had a previous post but received no answer after a while.  I have a project in actionscript 2.0 using flash cs4.  It is a flash game.  I have the flv files loaded from my site using NetStream. Some of the videos volume is lower and I would like to adjust them without rerendering all of the videos.  I have gone on line and have tried many things, but none have worked and most have given error messages.  Below is the script I have been loading my flvs.
var nc:NetConnection = new NetConnection();
nc.connect(null);
var ns:NetStream = new NetStream(nc);
aud1.attachVideo(ns);
ns.play("http://www.mysite.org/video/myvideo/1.flv");
ns.onCuePoint = function(evt:Object){
    trace(evt.name);
    trace(evt.time);
    if(evt.name == "c1") {
        trace("YO !Jump to 108!");
        gotoAndPlay(108);
I have this script above the layer with my NetStream player.
Thank you for your help.
Mark.
    Aug 11, 2012 1:56 PM   in reply to MARKARKARK
    Per the directions kGlad provided in the other posting...
    var st:SoundTransform=your_ns.soundTransform;
    st.volume=.5;
    your_ns.soundTransform=st;
    you should have tried...
    nc.connect(null);
    var st:SoundTransform=ns.soundTransform;
    st.volume=.5;
        trace(evt.name);
        trace(evt.time);
            gotoAndPlay(108);
    If that doesn't work, you should continue in your other posting, and show what you tried that doesn't work.
    Please don't start a new one just because no one has responded for little while.  When kGlad comes around he will almost certainly respond.
    Aug 12, 2012 6:45 AM   in reply to MARKARKARK
    Review alternate audio control method posted here:
    http://forums.adobe.com/thread/1047840
    Best wishes,
    Adninjastrator
