Mac Pro 3.1, 16-GB Ram, OS 10.6.8, CS6 Extended
I notice trhat recently hitting Key Commands in Photoshop like Command-M minimizes my open window to the dock instead of opening Curves? This used to work. The Keyborad Shortcuts as set in Photoshop correctly, but it is ignoring them and using the Finder shortcut instead?
Anuyy ideas?
A workaround: since I would agree that Cmd-M is more important than minimizing windows, you can change and/or disable the Cmd-M shortcut in Snow Leopard.
System Preferences -> Keyboard->Keyboard Shortcuts
Since "Minimize" is not listed, you go to "Application Shortcuts", hit the "+" button, choose "Finder" from the list, type in the Menu Title "Minimize" without quotes, and then type your new, preferred shortcut, Such as "Ctrl-Alt-Cmd-M" as an example. Use what ever works for ya.
Close the panel, and when you now go up to the Finder menu "Window - Minimize", you should see your new shortcut.
I've been changing stock OS Keyboard shortcuts on almost every OS I have used for almost 30 years, to better reflect my workflow and speed.
Thank you for the response. What you suggest "should' work, but does not on my end.
I went in to System Preferences - Added Finder > Minimize > then changed the shortcut to Command-Shift-M.
Restarted the couputer and Command-M still minimizes windows in both the Finder AND Photoshop??? Only now, when I click Command-Shift-M in the Finder, that shortcut ALSO minimizes windows (it has no effect in Photoshop).
I am also concerned as to why this started all of a sudden in Photoshop - it was working fine up until a few days ago. I even trashed my Photoshop Prefs and the problem still presists. I am not noticing any other strange behavior (yet).
OK... it just got stranger...
I thought I would try changing Command+M in the Photoshop Keyboard Shortcuts to something else (like Command-Shift-P), save the set and the new command worked as expected to bring up Curves. Then I went back to Keybiard Shortcuts and tried to change it back to Command+M and it would not accept that keboard combination - just like I was not pressing any keys at all? It also showed a tiny icon of a thought bubble with an exclaimation point in it next to the entry field when I first activated that field to type in a new short cut. I then tried entering several other Key-Combinations into Curves and all of them worked - just not Command+M.
Then just for fun, I pressed the CAPS LOCK key and then entered Command-M and it accepted the combination and sure enough inside Photoshop hitting Command+M with the CAPS LOCK on works. But turn off CAPS LOCK and there goes the Photoshop window into the Dock again.
This is really frustrating as I have used Command+M almost everyday for over 20 years!
I even tried the Default Keyboard Shortcut set and get the same behavior. All the other Keyboard Shortcuts seem to be working as they are supposed to.
choreo,
You may not like what I'm about to tell you, but it is the absolute truth:
I just went to Photoshop 13 ("CS6") on my machine running under Snow Leopard, and pressed Command+M, which immediately brought up the Curves adjustment dialog box.
Something is wrong with your setup.
Here's my System Info, per copy and paste from the Photoshop Help menu:
Adobe Photoshop Version: 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00) x64
Operating System: Mac OS 10.6.8
System architecture: Intel CPU Family:6, Model:15, Stepping:6 with MMX, SSE Integer, SSE FP, SSE2, SSE3
Physical processor count: 2
Processor speed: 2000 MHz
Built-in memory: 4096 MB
Free memory: 2396 MB
Memory available to Photoshop: 3752 MB
Memory used by Photoshop: 70 %
Image tile size: 128K
Image cache levels: 4
The GPU Sniffer crashed on 8/9/12 at 3:47:59 AM
OpenGL Version: 1.4 APPLE-1.6.36
OpenCL Unavailable
Video Card Vendor: Intel Inc.
Video Card Renderer: Intel GMA 950 OpenGL Engine
Display: 2
Display Depth:= 32
Display Bounds:= top: 0, left: 1280, bottom: 1024, right: 2560
Unaccelerated Video Card.
OpenCL Unavailable
Display: 1
Main Display
Display Depth:= 32
Display Bounds:= top: 0, left: 0, bottom: 1024, right: 1280
Video Renderer ID: 16924672
Video Card Memory: 64 MB
Video Rect Texture Size: 2048
Serial number: 91xxxxxxxxxxxxxxxxxx13
Application folder: MacBook HD:Applications:Adobe Photoshop CS6:
Photoshop scratch has async I/O enabled
Scratch volume(s):
MacBook HD, 148.7G, 118.0G free
Ps_13_scratch, 149.0G, 148.9G free
Required Plug-ins folder: MacBook HD:Applications:Adobe Photoshop CS6:Adobe Photoshop CS6.app:Contents:Required:
Primary Plug-ins folder: MacBook HD:Applications:Adobe Photoshop CS6:Plug-ins:
Additional Plug-ins folder: not set
Installed components:
adbeape.framework adbeape 3.3.8.19346 66.1025012
AdbeScriptUIFlex.framework AdbeScriptUIFlex 6.2.29.18602 66.490082
adobe_caps.framework adobe_caps 6.0.29.0 1.276181
AdobeACE.framework AdobeACE 2.19.18.19243 66.492997
AdobeAGM.framework AdobeAGM 4.26.17.19243 66.492997
AdobeAXE8SharedExpat.framework AdobeAXE8SharedExpat 3.7.101.18636 66.26830
AdobeAXEDOMCore.framework AdobeAXEDOMCore 3.7.101.18636 66.26830
AdobeBIB.framework AdobeBIB 1.2.02.19243 66.492997
AdobeBIBUtils.framework AdobeBIBUtils 1.1.01 66.492997
AdobeCoolType.framework AdobeCoolType 5.10.31.19243 66.492997
AdobeCrashReporter.framework AdobeCrashReporter 6.0.20120201
AdobeExtendScript.framework AdobeExtendScript 4.2.12.18602 66.490082
AdobeJP2K.framework AdobeJP2K 2.0.0.18562 66.236923
AdobeLinguistic.framework 17206
AdobeMPS.framework AdobeMPS 5.8.0.19463 66.495174
AdobeOwl.framework AdobeOwl 4.0.93 66.496052
AdobePDFL.framework AdobePDFL 10.0.1.18562 66.419471
AdobePDFSettings.framework AdobePDFSettings 1.4
AdobePIP.framework AdobePIP 6.0.0.1654
AdobeScCore.framework AdobeScCore 4.2.12.18602 66.490082
AdobeUpdater.framework AdobeUpdater 6.0.0.1452 "52.338651"
AdobeXMP.framework AdobeXMPCore 66.145661 66.145661
AdobeXMPFiles.framework AdobeXMPFiles 66.145661 66.145661
AdobeXMPScript.framework AdobeXMPScript 66.145661 66.145661
ahclient.framework ahclient 1.7.0.56
aif_core.framework AdobeAIF 3.0.00 62.490293
aif_ocl.framework AdobeAIF 3.0.00 62.490293
aif_ogl.framework AdobeAIF 3.0.00 62.490293
AlignmentLib.framework xcode 1.0.0.1
amtlib.framework amtlib 6.0.0.75
boost_date_time.framework boost_date_time 6.0.0.0
boost_signals.framework boost_signals 6.0.0.0
boost_system.framework boost_system 6.0.0.0
boost_threads.framework boost_threads 6.0.0.0
Cg.framework NVIDIA Cg
CIT.framework CIT 2.0.5.19287 145486
data_flow.framework AdobeAIF 3.0.00 62.490293
dvaaudiodevice.framework dvaaudiodevice 6.0.0.0
dvacore.framework dvacore 6.0.0.0
dvamarshal.framework dvamarshal 6.0.0.0
dvamediatypes.framework dvamediatypes 6.0.0.0
dvaplayer.framework dvaplayer 6.0.0.0
dvatransport.framework dvatransport 6.0.0.0
dvaunittesting.framework dvaunittesting 6.0.0.0
dynamiclink.framework dynamiclink 6.0.0.0
FileInfo.framework FileInfo 66.145433 66.145433
filter_graph.framework AdobeAIF 3.0.00 62.490293
hydra_filters.framework AdobeAIF 3.0.00 62.490293
ICUConverter.framework ICUConverter 3.61 "gtlib_3.0" "." "16615"
ICUData.framework ICUData 3.61 "gtlib_3.0" "." "16615"
image_compiler.framework AdobeAIF 3.0.00 62.490293
image_flow.framework AdobeAIF 3.0.00 62.490293
image_runtime.framework AdobeAIF 3.0.00 62.490293
LogSession.framework LogSession 2.1.2.1652
mediacoreif.framework mediacoreif 6.0.0.0
PlugPlug.framework PlugPlug 3.0.0.383
UpdaterNotifications.framework UpdaterNotifications 6.0.0.24 "6.0.0.24"
wrservices.framework
Required plug-ins:
Accented Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Adaptive Wide Angle 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “Adaptive Wide Angle.plugin”
ADM 3.10x16, Copyright © 1987-2008 Adobe Systems Inc. All rights reserved. - from the file “AdobeADM.bundle”
Angled Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Average 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “Average.plugin”
Bas Relief 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
BMP 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Camera Raw 7.1 (354), Copyright © 2012 Adobe Systems Incorporated - from the file “Camera Raw.plugin”
Chalk & Charcoal 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Chrome 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Cineon 13.0 20120315.r.428 2012/03/15:21:00:00 ©2002-2012 Adobe Systems Incorporated - from the file “Cineon.plugin”
Clouds 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
Collada DAE 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
Color Halftone 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Colored Pencil 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
CompuServe GIF 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Conté Crayon 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Craquelure 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crop and Straighten Photos 13.0 20120315.r.428 2012/03/15:21:00:00 ©2003-2012 Adobe Systems Incorporated - from the file “CropPhotosAuto.plugin”
Crop and Straighten Photos Filter 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Crosshatch 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Crystallize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Cutout 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Dark Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
De-Interlace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Difference Clouds 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “Clouds.plugin”
Diffuse Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Displace 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Dry Brush 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Eazel Acquire 13.0 20120315.r.428 2012/03/15:21:00:00 ©1997-2012 Adobe Systems Incorporated - from the file “EazelAcquire.plugin”
Embed Watermark NO VERSION - from the file “DigiSign.plugin”
Enable Async I/O 13.0 20120315.r.428 2012/03/15:21:00:00 © 2004-2012 Adobe Systems Incorporated - from the file “Enable Async IO.plugin”
Extrude 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
FastCore Routines 13.0 20120315.r.428 2012/03/15:21:00:00 ©1990-2012 Adobe Systems Incorporated - from the file “FastCore.plugin”
Fibers 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Film Grain 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Filter Gallery 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Fresco 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Glowing Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Graphic Pen 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Halftone Pattern 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
HDRMergeUI 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “HDRMergeUI.plugin”
IFF Format 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Ink Outlines 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
JPEG 2000 13.0 20120315.r.428 2012/03/15:21:00:00 ©2001-2012 Adobe Systems Incorporated - from the file “JPEG2000.plugin”
Lens Blur 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Blur.plugin”
Lens Correction 13.0, Copyright © 2002-2012 Adobe Systems Incorporated - from the file “Lens Correct.plugin”
Lens Flare 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Liquify 13.0, Copyright © 2001-2012 Adobe Systems Incorporated - from the file “Liquify.plugin”
Matlab Operation 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Measurement Core 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “MeasurementCore.plugin”
Mezzotint 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
MMXCore Routines 13.0 20120315.r.428 2012/03/15:21:00:00 ©1990-2012 Adobe Systems Incorporated - from the file “MMXCore.plugin”
Mosaic Tiles 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Multiprocessor Support 13.0 20120315.r.428 2012/03/15:21:00:00 ©1990-2012 Adobe Systems Incorporated - from the file “MultiProcessor Support.plugin”
Neon Glow 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Note Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
NTSC Colors 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “NTSC Colors.plugin”
Ocean Ripple 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Oil Paint 13.0, Copyright © 2011 Adobe Systems Incorporated - from the file “Oil Paint.plugin”
OpenEXR 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Paint Daubs 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Palette Knife 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Patchwork 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Paths to Illustrator 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
PCX 13.0 20120315.r.428 2012/03/15:21:00:00 ©1989-2012 Adobe Systems Incorporated - from the file “PCX.plugin”
Photocopy 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Photoshop 3D Engine 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “Photoshop3DEngine.plugin”
Picture Package Filter 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “ChannelPort.plugin”
Pinch 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pixar 13.0 20120315.r.428 2012/03/15:21:00:00 ©1989-2012 Adobe Systems Incorporated - from the file “Pixar.plugin”
Plaster 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Plastic Wrap 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
PNG 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Pointillize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Polar Coordinates 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Portable Bit Map 13.0 20120315.r.428 2012/03/15:21:00:00 ©1989-2012 Adobe Systems Incorporated - from the file “PBM.plugin”
Poster Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Radial Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Radiance 13.0 20120315.r.428 2012/03/15:21:00:00 ©2003-2012 Adobe Systems Incorporated - from the file “Radiance.plugin”
Read Watermark NO VERSION - from the file “DigiRead.plugin”
Reticulation 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Ripple 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Rough Pastels 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Save for Web 13.0, Copyright © 1999-2012 Adobe Systems Incorporated - from the file “Save for Web.plugin”
ScriptingSupport 13.0, Copyright © 2012 Adobe Systems Incorporated - from the file “ScriptingSupport.plugin”
Shear 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Smart Blur 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Smudge Stick 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Solarize 13.0 20120315.r.428 2012/03/15:21:00:00 ©1993-2012 Adobe Systems Incorporated - from the file “Solarize.plugin”
Spatter 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Spherize 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Sponge 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Sprayed Strokes 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stained Glass 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Stamp 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Sumi-e 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Targa 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Texturizer 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Tiles 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Torn Edges 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Twirl 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Underpainting 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Vanishing Point 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “VanishingPoint.plugin”
Water Paper 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Watercolor 13.0, Copyright © 1991-2012 Adobe Systems Incorporated - from the file “Filter Gallery.plugin”
Wave 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Wind 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Wireless Bitmap 13.0 20120315.r.428 2012/03/15:21:00:00 ©1989-2012 Adobe Systems Incorporated - from the file “WBMP.plugin”
ZigZag 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “Standard Multiplugin.plugin”
Optional and third party plug-ins:
Disable OpenGL Drawing 13.0 20120315.r.428 2012/03/15:21:00:00 © 2004-2012 Adobe Systems Incorporated - from the file “DisableDragBoundingBox.plugin”
Disable Scratch Compression 13.0 20120315.r.428 2012/03/15:21:00:00 © 2004-2012 Adobe Systems Incorporated - from the file “DisableScratchCompress.plugin”
PG-Processor 2.0.1 ©2002-2010 PixelGenius LLC - from the file “PG-Processor.plugin”
PhotoKit Capture Sharpener 2 2.0.7 ©2002-2010 PixelGenius LLC - from the file “PhotoKit Sharpener 2.plugin”
PhotoKit Creative Sharpener 2 2.0.7 ©2002-2010 PixelGenius LLC - from the file “PhotoKit Sharpener 2.plugin”
PhotoKit Output Sharpener 2 2.0.7 ©2002-2010 PixelGenius LLC - from the file “PhotoKit Sharpener 2.plugin”
PhotoKit Preview Helper 2.1.6 ©2002-2010 PixelGenius LLC - from the file “PG Toolbox Previewer.plugin”
PixelGenius Toolbox 2.2.2 ©2002-2010 PixelGenius LLC - from the file “PixelGenius Toolbox.plugin”
Plug-ins that failed to load: NONE
Flash:
Mini Bridge
Kuler
Installed TWAIN devices: NONE
Station_two,
I see you've got the plug-in Disable OpenGL Drawing 13.0 20120315.r.428 2012/03/15:21:00:00 © 2004-2012 Adobe Systems Incorporated - from the file “DisableDragBoundingBox.plugin" on your system.
Why is that? What does that do for you that can't be accomplished via the Performance preferences dialog? Just curious.
Same question re: the Disable Scratch Compression plug-in and the File Handling preferences.
-Noel
You might try resetting the keyboard shortcuts in both the system and photoshop.
Also check your actions panel for shortcuts assigned to actions.
One of the default sets that you can load called Commands has some preset shortcuts.
Since a reinstall doesn't effect the photoshop preferences, resetting the photoshop would be something else to try by
holding Shift+Cmd+Option while starting photoshop and clicking yes in the dialog that follows.
Noel Carboni wrote:
Station_two,
I see you've got the plug-in Disable OpenGL Drawing...
Same question re: the Disable Scratch Compression plug-in and the File Handling preferences...
Noel,
Those are not something I installed myself, they're part of the default installation of Photoshop Standard for the Mac. I'm guessing they are needed for the respective settings in prefs to take effect.
The first one may have been installed automatically by the so-called "crash" of the GPU Sniffer as soon as the laptop's graphics were detected.
In any event, I had nothing to do with their presence. ![]()
No. That is all greayed out (Disabled).
Also, I don't have any of my 3rd party Plugins installed yet following the fresh install of CS6 this afternoon.
The same Serlal Numbered installation of Photoshop is working fine on my Power Book (Command+M, etc.). Just stopped working on my main MacPro (where I use Photoshop).
Sure. I just added my 3rd party Plugins back in since I had to get some work done tonight and they were obviously not the factor.
System architecture: Intel CPU Family:6, Model:23, Stepping:6 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1
Physical processor count: 8
Processor speed: 2800 MHz
Built-in memory: 16384 MB
Free memory: 10522 MB
Memory available to Photoshop: 15405 MB
Image tile size: 1024K
OpenGL Drawing: Enabled.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Version: 2.1 ATI-1.6.36
OpenCL Version:
Video Card Vendor: ATI Technologies Inc.
Video Card Renderer: ATI Radeon HD 5770 OpenGL Engine
Display: 3
Display Depth:= 32
Display Bounds:= top: 0, left: -1920, bottom: 1200, right: 0
Video Renderer ID: 16914946
Video Card Memory: 236 MB
Video Rect Texture Size: 16384
OpenCL Version:
Display: 2
Display Depth:= 32
Display Bounds:= top: 0, left: 1920, bottom: 1200, right: 3840
OpenCL Version: 1.0 (Dec 23 2010 17:30:26)
Display: 1
Main Display
Display Depth:= 32
Display Bounds:= top: 0, left: 0, bottom: 1200, right: 1920
Video Renderer ID: 16915202
Video Card Memory: 1012 MB
Serial number: 90149243933517754799
Application folder: SNOW LEOPARD:Applications:Adobe Photoshop CS6:
Scratch volume(s):
Startup, 931.2G, 644.6G free
Required Plug-ins folder: SNOW LEOPARD:Applications:Adobe Photoshop CS6:Adobe Photoshop CS6.app:Contents:Required:
Primary Plug-ins folder: SNOW LEOPARD:Applications:Adobe Photoshop CS6:Plug-ins:
Additional Plug-ins folder: SNOW LEOPARD:Applications:Adobe Photoshop CS6:MY PLUGINS:
Required plug-ins:
3D Studio 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
Dicom 13.0, Copyright © 2003-2012 Adobe Systems Incorporated - from the file “dicom.plugin”
Entropy 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Flash 3D 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
Google Earth 4 KMZ 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
Kurtosis 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Maximum 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Mean 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Median 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Minimum 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Range 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Skewness 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Standard Deviation 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Summation 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
U3D 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
Variance 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “statistics.plugin”
Wavefront|OBJ 13.0 20120315.r.428 2012/03/15:21:00:00 ©2006-2012 Adobe Systems Incorporated - from the file “U3D.plugin”
3D Invigorator ©1997-2009 Zaxwerks, Inc. - from the file “3D Invigorator PS_64.plugin”
Alien Skin Autolayer 3 Autolayer 3 3.0.0 15815 2011-06-23 06:11 Copyright © 2010 Alien Skin Software, LLC - from the file “Alien Skin Autolayer 3.8li.plugin”
Animal Fur Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Backlight Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Bevel Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Bokeh Bokeh 2 2.0.1.442 19135 Copyright © 2010 Alien Skin Software, LLC - from the file “Alien Skin Bokeh 2.8bf.plugin”
Brick Wall Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Brushed Metal Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Chrome Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Color Efex Pro 3.0 Complete NO VERSION - from the file “CEP3Complete.plugin”
Corona Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Diamond Plate Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Drip Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Edge Anarchy 1.2 ©2003 Digital Anarchy - from the file “Edges.plugin”
Extrude Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Fire Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Glass Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Gradient Glow Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
HDR Efex Pro 1.204, Copyright © 2000-2012 Nik Software Inc. - from the file “HDR Efex Pro Tonemapping.plugin”
HDR Efex Pro Metadata 1.204, Copyright © 2000-2012 Nik Software Inc. - from the file “HDR Efex Pro Metadata.plugin”
Icicles Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Knoll Light Factory NO VERSION - from the file “Light Factory.plugin”
Marble Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Merge to HDR Efex Pro 1.204, Copyright © 2000-2012 Nik Software Inc. - from the file “HDR Efex Pro Automation.plugin”
Motion Trail Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Nik Selective Tool 2.103, Copyright © 2000-2012 Nik Software Inc. - from the file “SelectivePalette.plugin”
Perfect Resize 7.0 Professional Edition 7.0.7, Copyright © 2012 onOne Software. All rights reserved. - from the file “Automation.plugin”
Perfect Resize 7.0 Professional Edition Batch 7.0.7, Copyright © 2012 onOne Software. All rights reserved. - from the file “Batch.plugin”
Perfect Resize 7.0 Professional Edition Filter 7.0.7, Copyright © 2012 onOne Software. All rights reserved. - from the file “Filter.plugin”
Perfect Resize 7.0 Professional Edition Format 7.0.7, Copyright © 2012 onOne Software. All rights reserved. - from the file “Format.plugin”
Perspective Shadow Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
PhotoTools 2.6 Hidden NO VERSION - from the file “HelperFilter.plugin”
PhotoTools 2.6 Professional Edition 2.6.2, Copyright © 2011 onOne Software. All rights reserved. - from the file “PhotoTools 2.6 Professional Edition.plugin”
PhotoTools 2.6 Professional Edition Batch 2.6.2, Copyright © 2011 onOne Software. All rights reserved. - from the file “PhotoTools 2.6 Professional Edition Batch.plugin”
PhotoTune 3 3.0.7, Copyright © 2011 onOne Software. All rights reserved. - from the file “PhotoTune.plugin”
PhotoTune 3 Batch 3.0.7, Copyright © 2011 onOne Software. All rights reserved. - from the file “PhotoTune Batch.plugin”
PhotoTune 3 Filter 3.0.7, Copyright © 2011 onOne Software. All rights reserved. - from the file “PhotoTune Filter Stub.plugin”
Plug-in on new layer NO VERSION - from the file “Autolayer2.plugin”
Power Mask v1.0 NO VERSION - from the file “PowerMask.plugin”
Power Stroke v1.0 NO VERSION - from the file “PowerStroke.plugin”
Reptile Skin Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Ripples Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Rust Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Smoke Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Snow Drift Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Squint Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Stone Wall Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Super Star Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Swirl Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Texture Anarchy Explorer 1.2 ©2003 Digital Anarchy - from the file “Explorer.plugin”
Texture Noise Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Tiling Texture Anarchy 1.2 ©2003 Digital Anarchy - from the file “Tiling.plugin”
Water Drops Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Weave Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Wood Eye Candy 6 6.1.1.1128 18819 Copyright © 2011 Alien Skin Software, LLC - from the file “Eye Candy 6.plugin”
Flash: NONE
@choreo - are you absolutely sure that you tried to recreate your problem with Cmd-M on an absolutely clean install of PS-CS6 without the plug-ins?
How did you clean your previous install of PS? I have a hunch that somewhere in that list of plug-ins could be your problem. Do you use a keyboard macro utility like Quickeys, iKey, or Keyboard Maestro?
Absolutely sure. Even reinstalled twice.
• Closed Photoshop
• Moved my 3rd party Plugins and Presets to another hard drive (for reinstallation later)
• Ran Uninstaller for Photoshop (including the checkbox to remove Preferences) - Un-install appeared to worked.
• Downloaded CS6 Web Design Premium Installer from My Account at Adobe.com
• Ran installer
• Launched Photoshop
• Opened new file
• Went straight to Keyboard Shortcuts to make sure Default Set was selected
• Tried Command+M
• Same problem
I have no Macro utilities like Quickeys installed (I do not even use Actions inside Photoshop)
