After making a DVD I very often have to go back and reedit and move chapters around in Pemiere Pro CS4. I am not adding or removing any chapters. Then I reopen the project in
Encore using Dynamic link. I right click on the project and Replace with Original. At this point the timeline still shows the old chapter positions. If I right click on the timeline and select Update Markers from Source, then I have to relink and rename all the chapters. Is there anyway to have Encore just relink to the new chapter positions?
Then I reopen the project in Encore using Dynamic link.
To make sure this is not just symantics, your original Encore project uses a dynamic link to the specific sequence in PR that you are editing, right?
I did not use CS4 that long, so I wonder if there is a difference frolm the following, so let us know.
Since you say, "After making a DVD," I assume this sequence/timeline was transcoded. Did you use, "Revert to original"? If so, the PR changes should appear without using a "replace original." And yes, I would expect the "update markers" to fix any marker changes.
