codyjblan
Wordpress Header Image
Aug 11, 2012 6:54 PM
Trying to edit wordpress theme with Dreamwaver. Have setup all according to tutorials and everything works; however, the header image appears in a box with a question mark in it. I've rechecked the code according to the tutorial and cannot figure out the problem
    Aug 11, 2012 7:04 PM   in reply to codyjblan
    It would be difficult for us too to figure out  without a link to your problem page.  Have you got a link that you could share with us?
    Aug 11, 2012 7:14 PM   in reply to codyjblan
    codyjblan wrote:
    It is all setup locally on my machine... is it possible to share that?
    If you make your local machine public.  The alternative is to try wordpress.com and setup a test site using the same theme as you are currently using.  The test site will not allow you to change any HTML and also the CSS you use has to be inline.  Apart from that public can see what you are trying to do.
    Could you post a code here?  I know it can only be the HTML and CSS and the problem you are describing is more about the HTML link to the header image.  A box indicates that the image is not found in the path.
    hth
