New Sequence Settings for DNxHD Clips
Aug 11, 2012 2:46 PM
Tags: #presets #avid #dnxhd #hyperdeck #shuttle
Hello All :-)
I have a BMD HyperDeck Shuttle 2 and it records uncompressed and in the DNxHD (220 I believe) codec.
I can import, play and edit the files just fine, but there's no Sequence Preset for this codec.
Q)  Is there a preset somewhere?
Q)  What settings should I use to get the best results with these files?
Thanks!!
    Aug 11, 2012 3:24 PM   in reply to Amarotti
    Just drop the clip on the timeline and PP will create an appropriate sequence for it (in most cases).
    Aug 11, 2012 10:07 PM   in reply to Amarotti
    You can just drop a clip on the Make Sequence icon or or make your own custom sequence.
    For more information, read this...
    http://help.adobe.com/en_US/premierepro/cs/using/WS3E67AF4C-B2A2-4f04- 90B4-F8CCFB74B144.html
    Aug 11, 2012 10:20 PM   in reply to Amarotti
    I think there are a number of reasons, but to explain them, I must make 2 categories of users:
    • FCP converts, and
    • others.
    FCP converts are used to converting everything to ProRes or whatever other intermediate format FCP used. They have a difficult time understanding the concept of editing 'native', they fail to understand there is no advantage in converting to any other format, they fail to understand that 420 material can never be 'improved' by converting to 422 format, because it only entails adding zeroes. In addition they are used to using QuiRcktime, which may work fine on a MAC, but is a curse on a PC.
    If you don't belong to the group of FCP-converts and are lucky and smart enough not to have a MAC, there is no reason to use any intermediate or converted format, because everything works in native mode, so why make a preset for a lossy codec like DNxHD, when none is needed? Additionally, DNxHD requires QuiRcktime on a PC and that is about the last thing you want to do, apart from taking your PC out for a swim.
    Aug 12, 2012 6:34 AM   in reply to Harm Millaard
    Amorati, Harm makes several good points before he resorts to being a mean amateur.
    As an editor with both a Mac and PC system, such fanboy displays I find distasteful. But there is truth in the observation that there is a different philosophy and work flow when using Premiere Pro.
    Transcoding is only necessary when thee isnt enought computer power to handle native playback of media.
    For professionals, DNxHD is a standard for creating a final master.There are many reasons for this that hobbyists fail to grasp. Suffice it to say that it is the codec of choice for most serious work done in the industry.
    Get this book and read it to enhance your skills and understanding of how best to utilize the fine editorial tools in CS6.
    http://www.amazon.com/Editors-Guide-Adobe-Premiere-Pro/dp/0321773012
    Aug 12, 2012 2:56 PM   in reply to Amarotti
    I was wondering why there were no presets for DNxHD.
    Most likely because it's not a very common format used "in-camera".  So far, all the presets are based around common formats that a camera itself actually records.
    Aug 12, 2012 9:54 AM   in reply to Jim Simon
    The Arri Alexia (extremely popular in the industry these days) creates DNxHD files.The Black Magic Cinema camera will do so when released.
    Aug 12, 2012 4:58 PM   in reply to lasvideo
    Well, if enough people using those cameras start using PP to edit with, and start making the appropriate requests, then it's likely Adobe will add the appropriate presets.
    (Though personally, I suspect you'll see more of those camera ops recording RAW files instead.)
    Aug 12, 2012 3:06 PM   in reply to Amarotti
    Actually the studio I work at uses the BMD hyperdeck studio so I often edit with DNxHD 220 and ProRes HQ because that is the format that the deck records stuff in.  Anyways though
    if you just let Premiere pick the sequence settings you for you I assure you it picks correctly. So don't sweat it.
    Aug 28, 2012 5:58 AM   in reply to Amarotti
    I too have a BM Hyperdeck Shuttle and am having an issue using the DnxHD file. I have dowloaded the AVID Codec LE but that didnt seem to do anything. I am on a windows based machine and can not get PP to read the files. When I try and import them i get "Unsupported format or damaged file" The file plays fine in quicktime so i know it's not damaged. What are my options? i reallt need to get this done as i have a pfoject that a client is waiting for. Any help?
    Aug 28, 2012 6:20 AM   in reply to Amarotti
    I am on CS5.5 (which may be the issue)
    I am recording with the BM Shuttle also in the AVID DHxHD format. I have it recording out of the BM ATEM TV Studio.
    The file plays on my quicktime player on my machine.
    Aug 28, 2012 7:00 AM   in reply to RuschCMG
    CS5.5 is able to open files from the BMD hyperdeck studio for me just fine. CS5 however cannot cs5 can't properly handle the 16 channel audio that all the hyperdeck's create.
    The other issue could be if you're using the MXF flavor of DNxHD option then it won't import into Premiere period. Premiere only works with the .MOV flavor of DNxHD from the hyperdecks. In my personal experince anyways.
    Aug 28, 2012 7:06 AM   in reply to ComputerNovice25
    It is a movie file. PP can read it when i use the uncompressed 10bit mode but ont when i compress it. Here is the error message:
    Aug 28, 2012 2:09 PM   in reply to RuschCMG
    Are you using the Hyperdeck Shuttle 2? If so then please attempt to use the ProRes  record option and tell me if that works.
    I have the Hyperdeck studio here where I work and I haven't ever had issues with CS5.5 or cs6. All I can recommend is selecting ProRes or checking to make sure your Premiere is totally up to date.
    The last  thing I can recommend, is to try  using the program FFMBC to re-wrap it although that tool is generally used to make the MXF type of DNxHD into a .MOV  that Premiere can actually import.
    CS5 won't open any of them at all though.
    Aug 29, 2012 5:52 AM   in reply to ComputerNovice25
    I do have the shuttle 2. i have done the update on the shuttle and below are the only optuons i have to choose from when I have the shuttle plugged into hte computer via USB. I don't see a "ProRes" setting. When I select hte Uncompressed 10bit Quicktime it works but if i select either of the AVID's it doesnt. The Avid DNxHD plays in quicktime on my computer but does not import into premier.
    Aug 29, 2012 7:19 AM   in reply to RuschCMG
    I got it! i had IT do an update on Premier and that worked! Thanks everyone for all of the help
    Aug 29, 2012 5:55 PM   in reply to RuschCMG
    Glad to hear you got it working, I figured that was most likely the issue. Wanted to mention though I was indeed a bit confused about the ProRes option apparently they only made that option avaiable for people who use the studio version which is what we use where I work. So I was incorrect to suggest using that with the shuttle for some reason I thought that they added ProRes support for both the shuttle 2 and the Studio versions but not the original shuttle. Anyways though glad to hear a update helped I figured that had to be it since before I downloaded the ProRes update I used to constantly use DNxHD option with both CS5.5 and CS6 and never had any issues.
