Windows 7 x64
Firefox 14.0.1
flash player 11.3.300.265
Hello,
installation of install_flash_player_11_plugin.exe ends with the error message that flashplayer.xpt can not be written to C:\Windows\SysWOW64\Macromed\Flash because of missing rights.
Who can help me?
Please feel free to email it to me at ccampbel@adobe.com or post it someplace like dropbox or sendnow and send me the link.
I also received an email from another customer this weekend that had run into a similar problem. Here's what they found and how they were able to resolve the problem:
The reason for blocking the file flashplayer.xpt was the program ThreatFire.
Although I removed the program from Autostart and no entry in the taskmanager was found a ThreatFire service was running and blocked
Are you running the installer as an Administrator user?
If yes, see How do I fix Windows permission problems with Flash Player?
I am running the installer as an Administrator user.
Occasionally users can encounter the following scenarios:
I do not have these problems. Is the solution described in How do I fix Windows permission problems with Flash Player? really the solution to my problem?
According to your first post, you do have some sort of permission problem.
Can you post the contents of the FlashInstall.log file from that same folder?
I do have some sort of permission problem but I do not have these problems:
FlashInstall.log:
=O====== M/11.3.300.265 2012-07-20+14-28-58.802 ========
0000 00000010 "Z:\Installation\Adobe Flash Player\11.3.300.265\install_flash_player_11_plugin.exe"
0001
0002
0003
0004
0005 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0006 00000011 1
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_3_300_265.dll
0020 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_3_300_265_Plugin.exe
0021 00000017 C:\Windows\SysWOW64\Macromed\Flash
0022
0023 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0024 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_11_3_300_265.exe
0025 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
=X====== M/11.3.300.265 2012-07-20+14-29-12.661 ========
UQCfLM85 wrote:
0022
00001031 C:\Windows\SysWOW64\Macromed\Flash\flashplayer.xpt:5
Question: does that file already exist in that folder?
The "Permission Problem" FAQ does not list all possible scenarios under which it may apply, just the most common ones.
http://forums.adobe.com/thread/987370
Did it work? No.
reset_fp11.bat
Done: 0, Modified 0, Failed 0, Syntax errors 1
Last Syntax Error:WARNING : /grant=users=r : Error when checking arguments - HKE
Y_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.6
LookupAccountName : HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.Shockwave
Current object HKEY_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash
.7 will not be processed
Elapsed Time: 00 00:00:00
Y_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.7
.8 will not be processed
Y_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.8
.9 will not be processed
Y_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.9
.10 will not be processed
Y_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.10
.11 will not be processed
Y_LOCAL_MACHINE\SOFTWARE\Classes\ShockwaveFlash.ShockwaveFlash.11
LookupAccountName : HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{D27CDB6E-AE6D-11c
f-96B8-444553540000}:users 1337 Die Struktur der Sicherheitskennung ist unzuläss
Current object HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B
8-444553540000} will not be processed
Y_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}
Repairing Flash Player File System Permissions. One moment please...
LookupAccountName : C:\Windows\System32\Macromed:administrators 1337 Die Struktu
r der Sicherheitskennung ist unzulässig.
Current object C:\Windows\System32\Macromed will not be processed
Last Syntax Error:WARNING : /grant=administrators=f : Error when checking argume
nts - C:\Windows\System32\Macromed
LookupAccountName : C:\Windows\System32\Macromed\*:administrators 1337 Die Struk
tur der Sicherheitskennung ist unzulässig.
Current object C:\Windows\System32\Macromed\* will not be processed
nts - C:\Windows\System32\Macromed\*
LookupAccountName : C:\Windows\System32\Macromed:users 1337 Die Struktur der Sic
Last Syntax Error:WARNING : /grant=users=r : Error when checking arguments - C:\
LookupAccountName : C:\Windows\System32\Macromed\*:users 1337 Die Struktur der S
C:\Windows\System32\Macromed : delete Perm. ACE 5 nt-autoritÄt\system
C:\Windows\System32\Macromed : delete Perm. ACE 4 nt-autoritÄt\system
C:\Windows\System32\Macromed : delete Perm. ACE 0 nt-autoritÄt\system
C:\Windows\System32\Macromed : new ace for nt-autoritÄt\system
C:\Windows\System32\Macromed : 5 change(s)
Elapsed Time: 00 00:00:05
Done: 1, Modified 1, Failed 0, Syntax errors 0
Last Done : C:\Windows\System32\Macromed
C:\Windows\System32\Macromed\Flash : delete Perm. ACE 4 nt-autoritÄt\system
C:\Windows\System32\Macromed\Flash : delete Perm. ACE 0 nt-autoritÄt\system
C:\Windows\System32\Macromed\Flash : new ace for nt-autoritÄt\system
C:\Windows\System32\Macromed\Flash : 4 change(s)
C:\Windows\System32\Macromed\Flash\Flash32_11_3_300_268.ocx : delete Perm. ACE 2
nt-autoritÄt\system
C:\Windows\System32\Macromed\Flash\Flash32_11_3_300_268.ocx : new ace for nt-aut
oritÄt\system
C:\Windows\System32\Macromed\Flash\Flash32_11_3_300_268.ocx : 2 change(s)
C:\Windows\System32\Macromed\Flash\FlashInstall.log : delete Perm. ACE 0 nt-auto
ritÄt\system
C:\Windows\System32\Macromed\Flash\FlashInstall.log : new ace for nt-autoritÄt\s
ystem
C:\Windows\System32\Macromed\Flash\FlashInstall.log : 2 change(s)
C:\Windows\System32\Macromed\Flash\FlashPlayerUpdateService.exe : delete Perm. A
C:\Windows\System32\Macromed\Flash\FlashPlayerUpdateService.exe : new ace for nt
-autoritÄt\system
C:\Windows\System32\Macromed\Flash\FlashPlayerUpdateService.exe : 2 change(s)
C:\Windows\System32\Macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.dll : delete
C:\Windows\System32\Macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.dll : new ac
C:\Windows\System32\Macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.dll : 2 chan
ge(s)
C:\Windows\System32\Macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.exe : delete
C:\Windows\System32\Macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.exe : new ac
C:\Windows\System32\Macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.exe : 2 chan
ge(s)
C:\Windows\System32\Macromed\Flash\mms.cfg : delete Perm. ACE 0 nt-autoritÄt\sys
tem
C:\Windows\System32\Macromed\Flash\mms.cfg : new ace for nt-autoritÄt\system
C:\Windows\System32\Macromed\Flash\mms.cfg : 2 change(s)
Done: 7, Modified 7, Failed 0, Syntax errors 0
Last Done : C:\Windows\System32\Macromed\Flash\mms.cfg
LookupAccountName : C:\Windows\SysWow64\Macromed:administrators 1337 Die Struktu
Current object C:\Windows\SysWow64\Macromed will not be processed
nts - C:\Windows\SysWow64\Macromed
LookupAccountName : C:\Windows\SysWow64\Macromed\*:administrators 1337 Die Struk
Current object C:\Windows\SysWow64\Macromed\* will not be processed
nts - C:\Windows\SysWow64\Macromed\*
LookupAccountName : C:\Windows\SysWow64\Macromed:users 1337 Die Struktur der Sic
LookupAccountName : C:\Windows\SysWow64\Macromed\*:users 1337 Die Struktur der S
C:\Windows\SysWow64\Macromed : delete Perm. ACE 2 nt-autoritÄt\system
C:\Windows\SysWow64\Macromed : delete Perm. ACE 1 nt-autoritÄt\system
C:\Windows\SysWow64\Macromed : new ace for nt-autoritÄt\system
C:\Windows\SysWow64\Macromed : 4 change(s)
Last Done : C:\Windows\SysWow64\Macromed
C:\Windows\SysWow64\Macromed\Flash : delete Perm. ACE 1 nt-autoritÄt\system
C:\Windows\SysWow64\Macromed\Flash : delete Perm. ACE 0 nt-autoritÄt\system
C:\Windows\SysWow64\Macromed\Flash : new ace for nt-autoritÄt\system
C:\Windows\SysWow64\Macromed\Flash : 4 change(s)
C:\Windows\SysWow64\Macromed\Flash\Flash32_11_3_300_268.ocx : delete Perm. ACE 2
nt-autoritÄt\system
C:\Windows\SysWow64\Macromed\Flash\Flash32_11_3_300_268.ocx : new ace for nt-aut
oritÄt\system
C:\Windows\SysWow64\Macromed\Flash\Flash32_11_3_300_268.ocx : 2 change(s)
C:\Windows\SysWow64\Macromed\Flash\FlashInstall.log : delete Perm. ACE 0 nt-auto
ritÄt\system
C:\Windows\SysWow64\Macromed\Flash\FlashInstall.log : new ace for nt-autoritÄt\s
ystem
C:\Windows\SysWow64\Macromed\Flash\FlashInstall.log : 2 change(s)
C:\Windows\SysWow64\Macromed\Flash\FlashPlayerUpdateService.exe : delete Perm. A
C:\Windows\SysWow64\Macromed\Flash\FlashPlayerUpdateService.exe : new ace for nt
-autoritÄt\system
C:\Windows\SysWow64\Macromed\Flash\FlashPlayerUpdateService.exe : 2 change(s)
C:\Windows\SysWow64\Macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.dll : delete
C:\Windows\SysWow64\Macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.dll : new ac
C:\Windows\SysWow64\Macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.dll : 2 chan
ge(s)
C:\Windows\SysWow64\Macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.exe : delete
C:\Windows\SysWow64\Macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.exe : new ac
C:\Windows\SysWow64\Macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.exe : 2 chan
ge(s)
C:\Windows\SysWow64\Macromed\Flash\mms.cfg : delete Perm. ACE 0 nt-autoritÄt\sys
tem
C:\Windows\SysWow64\Macromed\Flash\mms.cfg : new ace for nt-autoritÄt\system
C:\Windows\SysWow64\Macromed\Flash\mms.cfg : 2 change(s)
Last Done : C:\Windows\SysWow64\Macromed\Flash\mms.cfg
Drücken Sie eine beliebige Taste . . .
FlashInstall.log
=O====== M/11.3.300.268 2012-07-29+10-06-21.398 ========
0000 00000010 "Z:\Installation\Adobe Flash Player\11.3.300.268\install_flash_player_11_plugin.exe"
0001 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0002 00000011 1
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_3_300_268.dll
0013 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_3_300_268_Plugin.exe
0014 00000017 C:\Windows\SysWOW64\Macromed\Flash
0015
0016 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0017
0018
0019 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_11_3_300_268.exe
0020 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0021
0022
0023
=X====== M/11.3.300.268 2012-07-29+10-06-38.246 ========
Installation of install_flash_player_11_plugin.exe ends with the error message that flashplayer.xpt can not be written to C:\Windows\SysWOW64\Macromed\Flash because of missing rights.
You ran SubInACL because flashplayer.xpt did not exist; is that correct?
UQCfLM85 wrote:
Die Struktur der Sicherheitskennung ist unzulässig.
There seems to be something wrong in your registry; that is certainly an error I have never seen before.
On the other hand, I do not think that this is the cause why flashplayer.xpt cannot be written to the target folder, when anything else can.
Can you try to run the uninstaller, then delete that folder, and install again?
I ran SubInACL because flashplayer.xpt did not exist.
I ran the uninstaller, then deleted that folder, and installed again.
Same error message: Installation of install_flash_player_11_plugin.exe ends with the error message that flashplayer.xpt can not be written to C:\Windows\SysWOW64\Macromed\Flash because of missing rights.
This is most puzzling; why can only one file not be written to that folder? I simply cannot explain that...
One last thing to try: can you run the MSI installer from http://www.adobe.com/products/flashplayer/distribution3.html ?
If that does not work, I will ask someone from the installer team to have a look at this puzzle.
I ran the uninstaller, then deleted that folder, and installed again running the MSI installer.
install_flash_player_11_active_x.msi
install_flash_player_11_plugin.msi
Did it work? No.
FlashInstall.log:
=O====== M/11.3.300.268 2012-07-31+14-21-21.609 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\InstallAX.exe" -install -msi
0001
0002 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0003 00000011 1
0004
0005 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_3_300_268.ocx
0006 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.exe
0007 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.dll
0008 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0009 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
=X====== M/11.3.300.268 2012-07-31+14-21-28.488 ========
=O====== M/11.3.300.268 2012-07-31+14-22-27.798 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\InstallPlugin.exe" -install -msi
0001
0002
0003 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0004 00000011 1
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_3_300_268.dll
0017 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_3_300_268_Plugin.exe
0018 00000017 C:\Windows\SysWOW64\Macromed\Flash
0019
=X====== M/11.3.300.268 2012-07-31+14-22-30.357 ========
Adobe Flash Player 11 Plugin Installer Information
Error 1722. There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action NewCustomAction1, location: …\InstallPlugin.exe, c…
OK
InstallShield Wizard
InstallShield Wizard Completed
The wizard was interrupted before Adobe Flash Player 11 Plugin could be completely installed.
Your system has not been modified. To complete installation at another time, please run setup again.
Click Finish to exit the wizard.
Finish
Could you please go through steps 1 - 5 in this post (see reply 15 by me) and either paste the log contents to a reply or email them to ccampbel@adobe.com? We'd like to get a better idea what's going on with your folders and files.
Chris
Hello Chris,
attachement: flashreport.txt
Yours sincerely
UQCfLM85
Windows Version: 6.1.7601 x64
Permissions: windows\system32\macromed
C:\Windows\system32\macromed\Flash
RW NT SERVICE\TrustedInstaller
RW NT-AUTORITÄT\SYSTEM
RW VORDEFINIERT\Administratoren
R VORDEFINIERT\Benutzer
C:\Windows\system32\macromed\Flash\Flash64_11_3_300_268.ocx
C:\Windows\system32\macromed\Flash\FlashInstall.log
C:\Windows\system32\macromed\Flash\FlashUtil64_11_3_300_268_ActiveX.dll
C:\Windows\system32\macromed\Flash\FlashUtil64_11_3_300_268_ActiveX.exe
C:\Windows\system32\macromed\Flash\FlashUtil64_11_3_300_268_Plugin.exe
C:\Windows\system32\macromed\Flash\NPSWF64_11_3_300_268.dll
Permissions: windows syswow64\macromed
C:\Windows\syswow64\macromed\Flash
C:\Windows\syswow64\macromed\Flash\Flash32_11_3_300_268.ocx
C:\Windows\syswow64\macromed\Flash\FlashInstall.log
C:\Windows\syswow64\macromed\Flash\FlashPlayerPlugin_11_3_300_268.exe
C:\Windows\syswow64\macromed\Flash\FlashPlayerUpdateService.exe
C:\Windows\syswow64\macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.dll
C:\Windows\syswow64\macromed\Flash\FlashUtil32_11_3_300_268_ActiveX.exe
C:\Windows\syswow64\macromed\Flash\FlashUtil32_11_3_300_268_Plugin.exe
C:\Windows\syswow64\macromed\Flash\mms.cfg
C:\Windows\syswow64\macromed\Flash\NPSWF32_11_3_300_268.dll
Directory Listing: syswow64\macromed\flash\
Datentr„ger in Laufwerk C: ist W7x64
Volumeseriennummer: 6433-81B6
Verzeichnis von C:\Windows\syswow64\macromed\flash
31.07.2012 16:53 <DIR> VORDEFINIERT\Administra.
31.07.2012 16:53 <DIR> VORDEFINIERT\Administra..
31.07.2012 16:53 9.285.832 VORDEFINIERT\AdministraFlash32_11_3_300_268.ocx
31.07.2012 16:53 6.312 VORDEFINIERT\AdministraFlashInstall.log
31.07.2012 16:53 1.536.712 VORDEFINIERT\AdministraFlashPlayerPlugin_11_3_300_268.exe
31.07.2012 16:53 250.056 VORDEFINIERT\AdministraFlashPlayerUpdateService.exe
31.07.2012 16:53 466.632 VORDEFINIERT\AdministraFlashUtil32_11_3_300_268_ActiveX.dll
31.07.2012 16:53 686.792 VORDEFINIERT\AdministraFlashUtil32_11_3_300_268_ActiveX.exe
31.07.2012 16:53 686.792 VORDEFINIERT\AdministraFlashUtil32_11_3_300_268_Plugin.exe
31.07.2012 16:53 47 VORDEFINIERT\Administramms.cfg
31.07.2012 16:53 9.465.032 VORDEFINIERT\AdministraNPSWF32_11_3_300_268.dll
9 Datei(en), 22.384.207 Bytes
Anzahl der angezeigten Dateien:
2 Verzeichnis(se), 98.836.262.912 Bytes frei
Directory Listing: system32\macromed\flash\
Verzeichnis von C:\Windows\system32\macromed\flash
31.07.2012 16:53 12.451.016 VORDEFINIERT\AdministraFlash64_11_3_300_268.ocx
31.07.2012 16:53 199.958 VORDEFINIERT\AdministraFlashInstall.log
31.07.2012 16:53 513.224 VORDEFINIERT\AdministraFlashUtil64_11_3_300_268_ActiveX.dll
31.07.2012 16:53 417.992 VORDEFINIERT\AdministraFlashUtil64_11_3_300_268_ActiveX.exe
31.07.2012 16:53 417.992 VORDEFINIERT\AdministraFlashUtil64_11_3_300_268_Plugin.exe
31.07.2012 16:53 12.315.336 VORDEFINIERT\AdministraNPSWF64_11_3_300_268.dll
6 Datei(en), 26.315.518 Bytes
2 Verzeichnis(se), 98.836.787.200 Bytes frei
HKLM\SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\MozillaPlugins\@adobe.com/FlashPlayer]
"Path"="C:\\Windows\\system32\\Macromed\\Flash\\NPSWF64_11_3_300_268.dll"
"ProductName"="Adobe© Flash© Player 11.3.300.268 Plugin"
"Vendor"="Adobe Systems Incorporated"
"Description"="Adobe© Flash© Player 11.3.300.268 Plugin"
"Version"="11.3.300.268"
HKCR\MIME\Database\Content Type
HKCR\MIME\Database\Content Type\application/atom+xml
HKCR\MIME\Database\Content Type\application/epub+zip
HKCR\MIME\Database\Content Type\application/fractals
HKCR\MIME\Database\Content Type\application/futuresplash
HKCR\MIME\Database\Content Type\application/hta
HKCR\MIME\Database\Content Type\application/mac-binhex40
HKCR\MIME\Database\Content Type\application/ms-infopath.xml
HKCR\MIME\Database\Content Type\application/ms-vsi
HKCR\MIME\Database\Content Type\application/msaccess
HKCR\MIME\Database\Content Type\application/msaccess.addin
HKCR\MIME\Database\Content Type\application/msaccess.cab
HKCR\MIME\Database\Content Type\application/msaccess.exec
HKCR\MIME\Database\Content Type\application/msaccess.ftemplate
HKCR\MIME\Database\Content Type\application/msaccess.runtime
HKCR\MIME\Database\Content Type\application/msaccess.template
HKCR\MIME\Database\Content Type\application/msaccess.webapplication
HKCR\MIME\Database\Content Type\application/msonenote
HKCR\MIME\Database\Content Type\application/msword
HKCR\MIME\Database\Content Type\application/opensearchdescription+xml
HKCR\MIME\Database\Content Type\application/pdf
HKCR\MIME\Database\Content Type\application/pkcs10
HKCR\MIME\Database\Content Type\application/pkcs7-mime
HKCR\MIME\Database\Content Type\application/pkcs7-signature
HKCR\MIME\Database\Content Type\application/pkix-cert
HKCR\MIME\Database\Content Type\application/pkix-crl
HKCR\MIME\Database\Content Type\application/postscript
HKCR\MIME\Database\Content Type\application/rss+xml
HKCR\MIME\Database\Content Type\application/vnd.adobe.acrobat-security-settings
HKCR\MIME\Database\Content Type\application/vnd.adobe.adept+xml
HKCR\MIME\Database\Content Type\application/vnd.adobe.pdfxml
HKCR\MIME\Database\Content Type\application/vnd.adobe.pdx
HKCR\MIME\Database\Content Type\application/vnd.adobe.xdp+xml
HKCR\MIME\Database\Content Type\application/vnd.adobe.xfd+xml
HKCR\MIME\Database\Content Type\application/vnd.adobe.xfdf
HKCR\MIME\Database\Content Type\application/vnd.fdf
HKCR\MIME\Database\Content Type\application/vnd.groove-injector
HKCR\MIME\Database\Content Type\application/vnd.groove-space-archive
HKCR\MIME\Database\Content Type\application/vnd.groove-tool-archive
HKCR\MIME\Database\Content Type\application/vnd.groove-vcard
HKCR\MIME\Database\Content Type\application/vnd.ms-excel
HKCR\MIME\Database\Content Type\application/vnd.ms-excel.12
HKCR\MIME\Database\Content Type\application/vnd.ms-excel.addin.macroEnabled.12
HKCR\MIME\Database\Content Type\application/vnd.ms-excel.sheet.binary.macroEnabled.12
HKCR\MIME\Database\Content Type\application/vnd.ms-excel.sheet.macroEnabled.12
HKCR\MIME\Database\Content Type\application/vnd.ms-excel.template.macroEnabled.12
HKCR\MIME\Database\Content Type\application/vnd.ms-mediapackage
HKCR\MIME\Database\Content Type\application/vnd.ms-officetheme
HKCR\MIME\Database\Content Type\application/vnd.ms-package.relationships+xml
HKCR\MIME\Database\Content Type\application/vnd.ms-pki.certstore
HKCR\MIME\Database\Content Type\application/vnd.ms-pki.pko
HKCR\MIME\Database\Content Type\application/vnd.ms-pki.seccat
HKCR\MIME\Database\Content Type\application/vnd.ms-pki.stl
HKCR\MIME\Database\Content Type\application/vnd.ms-powerpoint
HKCR\MIME\Database\Content Type\application/vnd.ms-powerpoint.12
HKCR\MIME\Database\Content Type\application/vnd.ms-powerpoint.addin.macroEnabled.12
HKCR\MIME\Database\Content Type\application/vnd.ms-powerpoint.presentation.macroEnabled.12
HKCR\MIME\Database\Content Type\application/vnd.ms-powerpoint.slide.macroEnabled.12
HKCR\MIME\Database\Content Type\application/vnd.ms-powerpoint.slideshow.macroEnabled.12
HKCR\MIME\Database\Content Type\application/vnd.ms-powerpoint.template.macroEnabled.12
HKCR\MIME\Database\Content Type\application/vnd.ms-publisher
HKCR\MIME\Database\Content Type\application/vnd.ms-visio.viewer
HKCR\MIME\Database\Content Type\application/vnd.ms-word.document.12
HKCR\MIME\Database\Content Type\application/vnd.ms-word.document.macroEnabled.12
HKCR\MIME\Database\Content Type\application/vnd.ms-word.template.12
HKCR\MIME\Database\Content Type\application/vnd.ms-word.template.macroEnabled.12
HKCR\MIME\Database\Content Type\application/vnd.ms-wpl
HKCR\MIME\Database\Content Type\application/vnd.ms-xpsdocument
HKCR\MIME\Database\Content Type\application/vnd.oasis.opendocument.presentation
HKCR\MIME\Database\Content Type\application/vnd.oasis.opendocument.spreadsheet
HKCR\MIME\Database\Content Type\application/vnd.oasis.opendocument.text
HKCR\MIME\Database\Content Type\application/vnd.openxmlformats-officedocument.presentationml.presentation
HKCR\MIME\Database\Content Type\application/vnd.openxmlformats-officedocument.presentationml.slide
HKCR\MIME\Database\Content Type\application/vnd.openxmlformats-officedocument.presentationml.slideshow
HKCR\MIME\Database\Content Type\application/vnd.openxmlformats-officedocument.presentationml.template
HKCR\MIME\Database\Content Type\application/vnd.openxmlformats-officedocument.spreadsheetml.sheet
HKCR\MIME\Database\Content Type\application/vnd.openxmlformats-officedocument.spreadsheetml.template
HKCR\MIME\Database\Content Type\application/vnd.openxmlformats-officedocument.wordprocessingml.document
HKCR\MIME\Database\Content Type\application/vnd.openxmlformats-officedocument.wordprocessingml.template
HKCR\MIME\Database\Content Type\application/vnd.ovi-suite
HKCR\MIME\Database\Content Type\application/x-complus
HKCR\MIME\Database\Content Type\application/x-compress
HKCR\MIME\Database\Content Type\application/x-compressed
HKCR\MIME\Database\Content Type\application/x-gzip
HKCR\MIME\Database\Content Type\application/x-informationCard
R NT-AUTORITÄT\SYSTEM
R VORDEFINIERT\Administratoren
HKCR\MIME\Database\Content Type\application/x-java-applet
HKCR\MIME\Database\Content Type\application/x-java-jnlp-file
HKCR\MIME\Database\Content Type\application/x-jtx+xps
HKCR\MIME\Database\Content Type\application/x-latex
HKCR\MIME\Database\Content Type\application/x-mix-transfer
HKCR\MIME\Database\Content Type\application/x-mplayer2
HKCR\MIME\Database\Content Type\application/x-ms-application
HKCR\MIME\Database\Content Type\application/x-ms-license
HKCR\MIME\Database\Content Type\application/x-ms-vsto
HKCR\MIME\Database\Content Type\application/x-ms-wmd
HKCR\MIME\Database\Content Type\application/x-ms-wmz
HKCR\MIME\Database\Content Type\application/x-ms-xbap
HKCR\MIME\Database\Content Type\application/x-msexcel
HKCR\MIME\Database\Content Type\application/x-mspowerpoint
HKCR\MIME\Database\Content Type\application/x-mspowerpoint.12
HKCR\MIME\Database\Content Type\application/x-mspowerpoint.macroEnabled.12
HKCR\MIME\Database\Content Type\application/x-mswebsite
HKCR\MIME\Database\Content Type\application/x-pkcs12
HKCR\MIME\Database\Content Type\application/x-pkcs7-certificates
HKCR\MIME\Database\Content Type\application/x-pkcs7-certreqresp
HKCR\MIME\Database\Content Type\application/x-shockwave-flash
HKCR\MIME\Database\Content Type\application/x-stuffit
HKCR\MIME\Database\Content Type\application/x-tar
HKCR\MIME\Database\Content Type\application/x-troff-man
HKCR\MIME\Database\Content Type\application/x-vnd.google.oneclickctrl.9
HKCR\MIME\Database\Content Type\application/x-vnd.google.update3webcontrol.3
HKCR\MIME\Database\Content Type\application/x-wmplayer
HKCR\MIME\Database\Content Type\application/x-x509-ca-cert
HKCR\MIME\Database\Content Type\application/x-zip-compressed
HKCR\MIME\Database\Content Type\application/xaml+xml
HKCR\MIME\Database\Content Type\application/xhtml+xml
HKCR\MIME\Database\Content Type\application/xml
HKCR\MIME\Database\Content Type\application/zip
HKCR\MIME\Database\Content Type\audio/3gpp
HKCR\MIME\Database\Content Type\audio/3gpp2
HKCR\MIME\Database\Content Type\audio/aiff
HKCR\MIME\Database\Content Type\audio/basic
HKCR\MIME\Database\Content Type\audio/mid
HKCR\MIME\Database\Content Type\audio/midi
HKCR\MIME\Database\Content Type\audio/mp3
HKCR\MIME\Database\Content Type\audio/mp4
HKCR\MIME\Database\Content Type\audio/mpeg
HKCR\MIME\Database\Content Type\audio/mpegurl
HKCR\MIME\Database\Content Type\audio/mpg
HKCR\MIME\Database\Content Type\audio/vnd.dlna.adts
HKCR\MIME\Database\Content Type\audio/wav
HKCR\MIME\Database\Content Type\audio/x-aiff
HKCR\MIME\Database\Content Type\audio/x-mid
HKCR\MIME\Database\Content Type\audio/x-midi
HKCR\MIME\Database\Content Type\audio/x-mp3
HKCR\MIME\Database\Content Type\audio/x-mpeg
HKCR\MIME\Database\Content Type\audio/x-mpegurl
HKCR\MIME\Database\Content Type\audio/x-mpg
HKCR\MIME\Database\Content Type\audio/x-ms-wax
HKCR\MIME\Database\Content Type\audio/x-ms-wma
HKCR\MIME\Database\Content Type\audio/x-wav
HKCR\MIME\Database\Content Type\image/bmp
HKCR\MIME\Database\Content Type\image/bmp\Bits
HKCR\MIME\Database\Content Type\image/gif
HKCR\MIME\Database\Content Type\image/gif\Bits
HKCR\MIME\Database\Content Type\image/jpeg
HKCR\MIME\Database\Content Type\image/jpeg\Bits
HKCR\MIME\Database\Content Type\image/jps
HKCR\MIME\Database\Content Type\image/mpo
HKCR\MIME\Database\Content Type\image/pjpeg
HKCR\MIME\Database\Content Type\image/pjpeg\Bits
HKCR\MIME\Database\Content Type\image/png
HKCR\MIME\Database\Content Type\image/png\Bits
HKCR\MIME\Database\Content Type\image/pns
HKCR\MIME\Database\Content Type\image/svg+xml
HKCR\MIME\Database\Content Type\image/tiff
HKCR\MIME\Database\Content Type\image/vnd.ms-photo
HKCR\MIME\Database\Content Type\image/x-emf
HKCR\MIME\Database\Content Type\image/x-icon
HKCR\MIME\Database\Content Type\image/x-jg
HKCR\MIME\Database\Content Type\image/x-png
HKCR\MIME\Database\Content Type\image/x-png\Bits
HKCR\MIME\Database\Content Type\image/x-wmf
HKCR\MIME\Database\Content Type\image/x-wmf\Bits
HKCR\MIME\Database\Content Type\message/rfc822
HKCR\MIME\Database\Content Type\midi/mid
HKCR\MIME\Database\Content Type\model/vnd.dwfx+xps
HKCR\MIME\Database\Content Type\model/vnd.easmx+xps
HKCR\MIME\Database\Content Type\model/vnd.edrwx+xps
HKCR\MIME\Database\Content Type\model/vnd.eprtx+xps
HKCR\MIME\Database\Content Type\pkcs10
HKCR\MIME\Database\Content Type\pkcs7-mime
HKCR\MIME\Database\Content Type\pkcs7-signature
HKCR\MIME\Database\Content Type\pkix-cert
HKCR\MIME\Database\Content Type\pkix-crl
HKCR\MIME\Database\Content Type\text/calendar
HKCR\MIME\Database\Content Type\text/css
HKCR\MIME\Database\Content Type\text/html
HKCR\MIME\Database\Content Type\text/plain
HKCR\MIME\Database\Content Type\text/scriptlet
HKCR\MIME\Database\Content Type\text/vnd-ms.click2record+xml
HKCR\MIME\Database\Content Type\text/x-component
HKCR\MIME\Database\Content Type\text/x-ms-contact
HKCR\MIME\Database\Content Type\text/x-ms-iqy
HKCR\MIME\Database\Content Type\text/x-ms-odc
HKCR\MIME\Database\Content Type\text/x-ms-rqy
HKCR\MIME\Database\Content Type\text/x-scriptlet
HKCR\MIME\Database\Content Type\text/x-vcard
HKCR\MIME\Database\Content Type\text/xml
HKCR\MIME\Database\Content Type\video/3gpp
HKCR\MIME\Database\Content Type\video/3gpp2
HKCR\MIME\Database\Content Type\video/avi
HKCR\MIME\Database\Content Type\video/mp4
HKCR\MIME\Database\Content Type\video/mpeg
HKCR\MIME\Database\Content Type\video/mpg
HKCR\MIME\Database\Content Type\video/msvideo
HKCR\MIME\Database\Content Type\video/quicktime
HKCR\MIME\Database\Content Type\video/vnd.dlna.mpeg-tts
HKCR\MIME\Database\Content Type\video/x-mpeg
HKCR\MIME\Database\Content Type\video/x-mpeg2a
HKCR\MIME\Database\Content Type\video/x-ms-asf
HKCR\MIME\Database\Content Type\video/x-ms-asf-plugin
HKCR\MIME\Database\Content Type\video/x-ms-wm
HKCR\MIME\Database\Content Type\video/x-ms-wmv
HKCR\MIME\Database\Content Type\video/x-ms-wmx
HKCR\MIME\Database\Content Type\video/x-ms-wvx
HKCR\MIME\Database\Content Type\video/x-msvideo
HKCR\MIME\Database\Content Type\vnd.ms-pki.certstore
HKCR\MIME\Database\Content Type\vnd.ms-pki.pko
HKCR\MIME\Database\Content Type\vnd.ms-pki.seccat
HKCR\MIME\Database\Content Type\vnd.ms-pki.stl
HKCR\MIME\Database\Content Type\x-pkcs12
HKCR\MIME\Database\Content Type\x-pkcs7-certificates
HKCR\MIME\Database\Content Type\x-pkcs7-certreqresp
HKCR\MIME\Database\Content Type\x-x509-ca-cert
syswow64\macromed\flash\flashinstall.log
=O====== M/11.3.300.268 2012-07-31+14-53-07.844 ========
0000
0001 00000010 "Z:\Installation\Adobe Flash Player\11.3.300.268\install_flash_player_11_active_x.exe"
0003 00000011 1
0004
0009
0010
0011 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0012
0013
=X====== M/11.3.300.268 2012-07-31+14-53-23.958 ========
?=O====== M/11.3.300.268 2012-07-31+14-53-30.776 ========
0001
0002
0003
0004
0006 00000011 1
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_3_300_268.dll
0019 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_3_300_268_Plugin.exe
0020 00000017 C:\Windows\SysWOW64\Macromed\Flash
0021
0022 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0023
0024
0025 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_11_3_300_268.exe
0026 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0027
0028
0029
=X====== M/11.3.300.268 2012-07-31+14-53-44.676 ========
system32\macromed\flash\flashinstall.log
=O====== M/11.1.102.55 2011-11-27+08-22-38.187 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\F44D.dir\InstallFlashPlayer.exe" -iv 4
0001
0002
0003
0004
0006
0007
0008
0009
0010
0011
0012 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_1_102.dll
0013 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_Plugin.exe
0014 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0015 00000011 1
=X====== M/11.1.102.55 2011-11-27+08-23-26.108 ========
?=O====== M/11.1.102.62 2012-02-17+21-19-58.233 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\BAD6.dir\InstallFlashPlayer.exe" -iv 4
0002
0003
0004
0005
0006 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_1_102.dll
0007
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_1_102_Plugin.exe
0009 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0010 00000011 1
=X====== M/11.1.102.62 2012-02-17+21-21-33.441 ========
?=O====== M/11.2.202.228 2012-04-12+11-18-47.369 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\EC0.dir\InstallFlashPlayer.exe" -iv 4
0002
0003
0004
0005
0006 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_2_202_228.dll
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_228_Plugin.exe
0009 00000011 1
0010 00000012
=X====== M/11.2.202.228 2012-04-12+11-19-16.737 ========
?=O====== M/11.2.202.233 2012-04-14+15-25-40.051 ========
0000 00000010 FlashPlayerInstaller.exe -install -iv 9
0002
0003
0004
0005
0006 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_2_202_233.dll
0007 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_233_Plugin.exe
0009 00000011 1
0010 00000012
=X====== M/11.2.202.233 2012-04-14+15-25-46.296 ========
?=O====== M/11.2.202.233 2012-04-21+17-03-37.707 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\{02FC66C6-F23E-4AE2-8362-D85C6E2A1B20}\InstallFlashPlayer.exe" -iv 4
=X====== M/11.2.202.233 2012-04-21+17-03-52.162 ========
?=O====== M/11.2.202.235 2012-05-04+23-25-41.795 ========
0002
0003
0004
0005
0006
0007 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_2_202_235.dll
0008 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_2_202_235_Plugin.exe
0010 00000011 1
0011 00000012
=X====== M/11.2.202.235 2012-05-04+23-25-46.269 ========
?=O====== M/11.2.202.235 2012-05-05+08-23-58.461 ========
0001
=X====== M/11.2.202.235 2012-05-05+08-23-58.957 ========
?=O====== M/11.2.202.235 2012-05-05+08-25-37.581 ========
0001
=X====== M/11.2.202.235 2012-05-05+08-25-37.865 ========
?=O====== M/11.2.202.235 2012-05-05+09-25-37.660 ========
0001
=X====== M/11.2.202.235 2012-05-05+09-25-37.981 ========
?=O====== M/11.2.202.235 2012-05-05+10-26-42.485 ========
0001
=X====== M/11.2.202.235 2012-05-05+10-26-42.858 ========
?=O====== M/11.2.202.235 2012-05-05+11-25-48.051 ========
0001
=X====== M/11.2.202.235 2012-05-05+11-25-48.518 ========
?=O====== M/11.2.202.235 2012-05-05+12-25-41.883 ========
0001
=X====== M/11.2.202.235 2012-05-05+12-25-42.232 ========
?=O====== M/11.2.202.235 2012-05-07+12-26-56.573 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\install_flash_player_64bit.exe" -iv 8 -install -au 0
0001
=X====== M/11.2.202.235 2012-05-07+12-26-56.866 ========
?=O====== M/11.2.202.235 2012-05-07+12-27-05.075 ========
0002
0003
0004
0005
0006
0010 00000011 1
0011 00000012
=X====== M/11.2.202.235 2012-05-07+12-27-09.957 ========
?=O====== M/11.3.300.257 2012-06-11+06-18-59.156 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\{AD01B56A-781D-442E-9967-E388EE2B6E6E}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 4 -au 4294967295
0002
0003
0004
0005
0006
0007
0008 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_3_300_257.dll
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_257_Plugin.exe
0010 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0011 00000012
=X====== M/11.3.300.257 2012-06-11+06-19-00.341 ========
?=O====== M/11.3.300.262 2012-06-23+22-25-43.895 ========
0000 00000010 "C:\Windows\TEMP\{37FF6FA9-0883-4CBC-8853-D7209308D2A4}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0002
0003
0004
0005
0006
0007
0008 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_3_300_262.dll
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_262_Plugin.exe
0011 00000012
=X====== M/11.3.300.262 2012-06-23+22-25-45.171 ========
?=O====== M/11.3.300.262 2012-06-23+23-25-44.038 ========
0000 00000010 "C:\Windows\TEMP\{9F17EEBB-BB8C-4BB4-9BD8-360C07A8AF81}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0001
=X====== M/11.3.300.262 2012-06-23+23-25-44.326 ========
?=O====== M/11.3.300.262 2012-06-24+00-25-43.422 ========
0000 00000010 "C:\Windows\TEMP\{4952E246-21A2-4719-8ADC-F133766236E3}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0002
0003
0004
0005
0006
0007
0011 00000012
=X====== M/11.3.300.262 2012-06-24+00-25-44.649 ========
?=O====== M/11.3.300.262 2012-06-24+10-16-12.325 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\{9D313ABF-676F-4001-88F0-727A7B9835CD}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 0
0001
=X====== M/11.3.300.262 2012-06-24+10-16-12.564 ========
?=O====== M/11.3.300.262 2012-06-24+10-17-16.995 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\{397DCB4F-CABA-4599-847A-EF32CE32EAF2}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 0
0002
0003
0004
0005
0006
0007
0011 00000012
=X====== M/11.3.300.262 2012-06-24+10-17-17.897 ========
?=O====== M/11.3.300.262 2012-06-24+10-41-23.215 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{0E14DBE6-9BEF-46F5-829F-DE59D180A73D}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 0
0002
0003
0004
0005
0006
0007
0011 00000012
=X====== M/11.3.300.262 2012-06-24+10-41-24.122 ========
?=O====== M/11.3.300.262 2012-06-24+10-44-07.984 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{2EDF091D-ADE9-4BF3-B295-615B77BD92DD}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 0
0002
0003
0004
0005
0006
0007
0011 00000012
=X====== M/11.3.300.262 2012-06-24+10-44-08.630 ========
?=O====== M/11.3.300.262 2012-06-24+10-46-10.201 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{4CC6FA92-6F4C-4F6C-9B21-128E954FA617}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 0
0002
0003
0004
0005
0006
0007
0011 00000012
=X====== M/11.3.300.262 2012-06-24+10-46-10.779 ========
?=O====== M/11.3.300.262 2012-06-24+10-48-51.261 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{2DA94EAA-AF4A-4961-A4CF-9844562645BF}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 8 -au 0
0002
0003
0004
0005
0006
0007
0011 00000012
=X====== M/11.3.300.262 2012-06-24+10-48-51.832 ========
?=O====== M/11.3.300.262 2012-06-24+11-18-20.929 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{76B0269A-A85B-4EE4-A44C-8387B7D77268}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0002
0003
0004
0005
0006
0007
=X====== M/11.3.300.262 2012-06-24+11-18-21.928 ========
?=O====== M/11.3.300.257 2012-06-24+11-18-39.642 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{C26CECF6-0A33-499C-A989-B88686457910}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0001
0002
0004
0005 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_3_300_257.ocx
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_257_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_257_ActiveX.dll
=X====== M/11.3.300.257 2012-06-24+11-18-41.249 ========
?=O====== M/11.3.300.265 2012-07-12+11-35-35.434 ========
0000 00000010 "C:\Windows\TEMP\{5E92D8B3-6552-4F66-9D54-CDF855E615DE}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0002
0003 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_3_300_265.ocx
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_265_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_265_ActiveX.dll
0006 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0007 00000012
=X====== M/11.3.300.265 2012-07-12+11-35-58.444 ========
?=O====== M/11.3.300.265 2012-07-12+12-25-50.900 ========
0000 00000010 "C:\Windows\TEMP\{ADEA9BF8-245C-4BF0-865E-35CEB9E3DD06}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0002
0003
0004
0005
0006
0007
0008 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_3_300_265.dll
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_265_Plugin.exe
0011 00000012
=X====== M/11.3.300.265 2012-07-12+12-25-53.099 ========
?=O====== M/11.3.300.265 2012-07-12+13-25-45.725 ========
0000 00000010 "C:\Windows\TEMP\{B030B3DA-14A7-4429-A308-331D1F049AF4}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0001
=X====== M/11.3.300.265 2012-07-12+13-25-47.016 ========
?=O====== M/11.3.300.265 2012-07-12+14-25-57.055 ========
0000 00000010 "C:\Windows\TEMP\{D0242BA2-2D7E-4F34-8526-23CFEA6C5B4F}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0001
=X====== M/11.3.300.265 2012-07-12+14-25-58.515 ========
?=O====== M/11.3.300.265 2012-07-12+16-23-28.428 ========
0000 00000010 "C:\Windows\TEMP\{AA803854-79BA-45C1-81FD-F0C48D773A3F}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0001
=X====== M/11.3.300.265 2012-07-12+16-23-30.070 ========
?=O====== M/11.3.300.265 2012-07-12+16-25-50.148 ========
0000 00000010 "C:\Windows\TEMP\{612E1136-90A2-43C2-9D10-D1A2B30867B8}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0001
=X====== M/11.3.300.265 2012-07-12+16-25-51.432 ========
?=O====== M/11.3.300.265 2012-07-12+17-25-47.733 ========
0000 00000010 "C:\Windows\TEMP\{365AC863-AA66-4597-806E-6ECE8DAE679E}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0001
=X====== M/11.3.300.265 2012-07-12+17-25-49.095 ========
?=O====== M/11.3.300.265 2012-07-12+18-25-46.398 ========
0000 00000010 "C:\Windows\TEMP\{C542F0B2-B188-4D7B-94BA-5C64E4CEDC80}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0001
=X====== M/11.3.300.265 2012-07-12+18-25-47.718 ========
?=O====== M/11.3.300.262 2012-07-13+13-23-54.481 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\{3277A691-6689-47AE-AE1E-93DA27CDFA71}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 5 -au 4294967295
0001
=X====== M/11.3.300.262 2012-07-13+13-23-54.715 ========
?=O====== M/11.3.300.262 2012-07-13+13-30-28.200 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\{1D3B58CB-92C1-4265-970E-5ECF85D7C71E}\InstallFlashPlayer.exe" -uninstall plugin
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
=X====== M/11.3.300.262 2012-07-13+13-30-28.294 ========
?=O====== M/11.3.300.265 2012-07-13+13-30-57.434 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\{94E40A98-8186-413D-8725-2EBF8CACE1BF}\InstallFlashPlayer.exe" -uninstall activex
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
=X====== M/11.3.300.265 2012-07-13+13-30-57.746 ========
?=O====== M/11.3.300.262 2012-07-13+13-34-09.525 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\{42CA9C1C-275B-483F-8FCA-699F1957D89C}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0001
0002
0004
0005
0006
0007
0008
0009
0010
0011 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_3_300_262.dll
0012 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_262_Plugin.exe
0013 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
=X====== M/11.3.300.262 2012-07-13+13-34-10.446 ========
?=O====== M/11.3.300.262 2012-07-13+13-35-05.525 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\{9239434B-873C-4207-ADB4-57B2097C6215}\InstallFlashPlayer.exe" -uninstall plugin
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
=X====== M/11.3.300.262 2012-07-13+13-35-05.572 ========
?=O====== M/11.3.300.265 2012-07-13+13-39-22.141 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\{7CE203BE-71F5-48E9-8A0D-3441EFAA3372}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0001
0002
0004
0005
0006
0007
0008
0009
0010
0011 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_3_300_265.dll
0012 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_265_Plugin.exe
=X====== M/11.3.300.265 2012-07-13+13-39-22.984 ========
?=O====== M/11.3.300.265 2012-07-13+13-39-54.272 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\{B1924213-D2FC-44B4-82E5-F15EE240E170}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0002
0003
0004
0005
0006
0007
=X====== M/11.3.300.265 2012-07-13+13-39-55.021 ========
?=O====== M/11.3.300.265 2012-07-13+13-40-53.876 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\{48EAB129-CE8F-4CF7-AA96-C6CBB79BE642}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0002
0003
0004
0005
0006
0007
=X====== M/11.3.300.265 2012-07-13+13-40-54.438 ========
?=O====== M/11.3.300.265 2012-07-13+13-41-15.614 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\{F3F91A4E-90EF-40ED-ACBB-DA8CFA139463}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0001
0003
0004 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_3_300_265.ocx
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_265_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_265_ActiveX.dll
0007 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
=X====== M/11.3.300.265 2012-07-13+13-41-17.143 ========
?=O====== M/11.3.300.265 2012-07-13+13-41-49.987 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\{49798A50-A956-4EE0-A10A-F2EFB35F7E9F}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0002
0003
0004
0005
0006
0007
=X====== M/11.3.300.265 2012-07-13+13-41-50.564 ========
?=O====== M/11.3.300.265 2012-07-13+13-43-26.924 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{2C82B74F-1392-481E-AC74-59E0C47178C7}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0002
0003
0004
0005
0006
0007
=X====== M/11.3.300.265 2012-07-13+13-43-27.470 ========
?=O====== M/11.3.300.265 2012-07-13+13-48-41.959 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{E6CA9EB4-9DFA-456C-94DD-2D3FDC646FB1}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0002
0003
0004
0005
0006
0007
=X====== M/11.3.300.265 2012-07-13+13-48-42.505 ========
?=O====== M/11.3.300.265 2012-07-13+13-52-51.287 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{BE13B9D8-B497-451C-B203-B1E6AD23B5C0}\InstallFlashPlayer.exe" -uninstall plugin
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
=X====== M/11.3.300.265 2012-07-13+13-52-51.318 ========
?=O====== M/11.3.300.265 2012-07-13+13-53-09.304 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{8E62CC41-8F98-4BDF-86E0-0B94CDF7EE70}\InstallFlashPlayer.exe" -uninstall activex
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
=X====== M/11.3.300.265 2012-07-13+13-53-09.351 ========
?=O====== M/11.3.300.265 2012-07-13+13-53-30.957 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{DC7A1566-EE56-48D6-848B-98CFD7CAEF5D}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0001
0002
0004
0005
0006
0007
0008
0009
0010
=X====== M/11.3.300.265 2012-07-13+13-53-31.519 ========
?=O====== M/11.3.300.265 2012-07-13+13-54-03.948 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{895E5AE1-E2D5-43ED-9215-ED5502C987D1}\InstallFlashPlayer.exe" -uninstall plugin
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
=X====== M/11.3.300.265 2012-07-13+13-54-03.979 ========
?=O====== M/11.3.300.265 2012-07-13+13-54-25.063 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{0D1BBEF4-CCFF-42F3-B8F5-92B7CF79561C}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0001
0003
=X====== M/11.3.300.265 2012-07-13+13-54-26.389 ========
?=O====== M/11.3.300.265 2012-07-13+13-57-19.740 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{6C5C5810-63C7-4E0F-AB7A-7DDAAAAB00EE}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0001
0002
0004
0005
0006
0007
0008
0009
0010
=X====== M/11.3.300.265 2012-07-13+13-57-20.348 ========
?=O====== M/11.3.300.265 2012-07-13+14-01-46.326 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{354DC694-268A-4669-A76E-AF0F56DC3021}\InstallFlashPlayer.exe" -uninstall plugin
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
=X====== M/11.3.300.265 2012-07-13+14-01-46.357 ========
?=O====== M/11.3.300.265 2012-07-13+14-02-01.162 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{790F1339-0B93-4FD2-9AF2-D7D561BEBE29}\InstallFlashPlayer.exe" -uninstall activex
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
=X====== M/11.3.300.265 2012-07-13+14-02-01.224 ========
?=O====== M/11.3.300.265 2012-07-13+14-28-06.739 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{65DF7E04-F825-42FE-B5CF-53ED855EB4DF}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0001
0002
0004
0005
0006
0007
0008
0009
0010
=X====== M/11.3.300.265 2012-07-13+14-28-07.909 ========
?=O====== M/11.3.300.265 2012-07-13+14-29-04.953 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{2CE6DE14-4463-491B-9098-880EDD031FBE}\InstallFlashPlayer.exe" -uninstall plugin
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
=X====== M/11.3.300.265 2012-07-13+14-29-05.000 ========
?=O====== M/11.3.300.265 2012-07-13+14-30-05.271 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{691B1741-90C7-43FC-BA64-C23ACA2E6398}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0001
0003
=X====== M/11.3.300.265 2012-07-13+14-30-07.377 ========
?=O====== M/11.3.300.265 2012-07-13+14-40-07.533 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{75757331-4BE5-43D4-9C84-3A83A67F2E0D}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0001
0002
0004
0005
0006
0007
0008
0009
0010
=X====== M/11.3.300.265 2012-07-13+14-40-08.485 ========
?=O====== M/11.3.300.265 2012-07-13+14-43-06.174 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{815ADBAA-31D9-4E87-979C-B7C52222677D}\InstallFlashPlayer.exe" -uninstall activex
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
=X====== M/11.3.300.265 2012-07-13+14-43-06.455 ========
?=O====== M/11.3.300.265 2012-07-13+14-43-32.132 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{81A18B51-83A6-498D-B53E-72C17D175C29}\InstallFlashPlayer.exe" -uninstall plugin
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
=X====== M/11.3.300.265 2012-07-13+14-43-32.195 ========
?=O====== M/11.3.300.265 2012-07-13+14-45-44.400 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{07C12740-EDA4-4D4A-9E70-5ADD36F50DD2}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0001
0002
0004
0005
0006
0007
0008
0009
0010
=X====== M/11.3.300.265 2012-07-13+14-45-45.227 ========
?=O====== M/11.3.300.265 2012-07-13+14-46-11.163 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{3A44F367-A9E1-424E-8A88-59C1045D5B86}\InstallFlashPlayer.exe" -uninstall plugin
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
=X====== M/11.3.300.265 2012-07-13+14-46-11.210 ========
?=O====== M/11.3.300.265 2012-07-13+14-50-08.631 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{8993DAA0-ED5B-464C-A1A3-164CFE5B42BC}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0001
0003
=X====== M/11.3.300.265 2012-07-13+14-50-10.066 ========
?=O====== M/11.3.300.265 2012-07-13+15-03-07.612 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{FA5FC60E-A978-4D96-9B5D-DC9A1E84548B}\InstallFlashPlayer.exe" -force -uninstall
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
0020
0021
0022
0023
0024
0025
0026
0027
0028
0029
0030
0031
0032 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0033
0034
0035
0036
0037
0038
0039
0040
0041
0042
0043
=X====== M/11.3.300.265 2012-07-13+15-03-07.893 ========
?=O====== M/11.3.300.265 2012-07-13+15-03-56.929 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{9C902F48-AED1-4897-A632-7A9A1B8A3F48}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0001
0002
0004
0005
0006
0007
0008
0009
0010
=X====== M/11.3.300.265 2012-07-13+15-03-58.145 ========
?=O====== M/11.3.300.265 2012-07-13+15-04-14.612 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{4F2D5D84-A698-4315-B2EE-8E5FC7812D80}\InstallFlashPlayer.exe" -force -uninstall
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
0020
0021
0022
0023
0024
0025
0026
0027
0028
0029
0030
0031
0032
0033
0034
=X====== M/11.3.300.265 2012-07-13+15-04-14.674 ========
?=O====== M/11.3.300.265 2012-07-13+15-04-35.446 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{82617BC7-2ADB-4960-9536-9DFAC113A23A}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0001
0002
0004
0005 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_3_300_265.ocx
0006 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_265_ActiveX.exe
0007 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_265_ActiveX.dll
=X====== M/11.3.300.265 2012-07-13+15-04-37.942 ========
?=O====== M/11.3.300.265 2012-07-20+14-20-59.149 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\{46EBE01A-886F-495B-B6EA-D444D9B65A05}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0001
0002
0004
0005
0006
0007
0008
0009
0010
=X====== M/11.3.300.265 2012-07-20+14-21-00.553 ========
?=O====== M/11.3.300.265 2012-07-20+14-21-40.143 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\{87940EC6-6CAC-4BEE-A045-D9B59C33A414}\InstallFlashPlayer.exe" -uninstall plugin
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
=X====== M/11.3.300.265 2012-07-20+14-21-40.209 ========
?=O====== M/11.3.300.265 2012-07-20+14-23-44.298 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\{772C0F30-C3A1-4818-B7D2-F126E6C97492}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0001
0002
0004
0005
0006
0007
0008
0009
0010
=X====== M/11.3.300.265 2012-07-20+14-23-45.226 ========
?=O====== M/11.3.300.265 2012-07-20+14-28-15.817 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\{336F65F8-A6AA-4069-9405-F5E2E6F80DD0}\InstallFlashPlayer.exe" -uninstall
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
0020
0021
0022
0023
0024
0025
0026
0027
0028
0029
=X====== M/11.3.300.265 2012-07-20+14-28-16.349 ========
?=O====== M/11.3.300.265 2012-07-20+14-28-29.476 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\{BC0ABCFD-FD29-4F5F-9ADB-8E385C24D1A6}\InstallFlashPlayer.exe" -uninstall
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0017
0018
0019
0020
0021
0022
0023
0024
0025
0026
0027
0028
0029
0030
0031
0032
0033
0034
0035
0036
0037
0038
0039 00000020 C:\Windows\system32\FlashPlayerCPLApp.cpl
0040
0041
0042
0043
0044
0045
0046
0047
0048
0049
0050
=X====== M/11.3.300.265 2012-07-20+14-28-29.530 ========
?=O====== M/11.3.300.265 2012-07-20+14-29-04.075 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\{589B7CEC-8E2E-4DBC-92CE-A40CBB89E360}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0001
0002
0004
0005
0006
0007
0008
0009
0010
=X====== M/11.3.300.265 2012-07-20+14-29-04.956 ========
?=O====== M/11.3.300.265 2012-07-20+14-29-33.780 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\{DA6B5CA8-1CDC-4975-B7B5-CB6211483CC9}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0001
0003
=X====== M/11.3.300.265 2012-07-20+14-29-35.809 ========
?=O====== M/11.3.300.265 2012-07-20+14-46-29.801 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\{6AFA87F5-6B41-4AE5-985B-D39C79DFF7CF}\InstallFlashPlayer.exe" -uninstall plugin
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
=X====== M/11.3.300.265 2012-07-20+14-46-29.857 ========
?=O====== M/11.3.300.262 2012-07-20+14-46-42.165 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\{72AC6420-4E71-45D0-B086-D443D5A4B772}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0001
0002
0004
0005
0006
0007
0008
0009
0010
=X====== M/11.3.300.262 2012-07-20+14-46-43.130 ========
?=O====== M/11.3.300.265 2012-07-20+14-47-08.354 ========
0000 00000010 "C:\Users\Marilyn\AppData\Local\Temp\{978FF520-0BB5-4032-AEB8-E9E565470EBF}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0002
0003
0004
0005
0006
0007
=X====== M/11.3.300.265 2012-07-20+14-47-09.231 ========
?=O====== M/11.3.300.268 2012-07-27+12-44-31.985 ========
0000 00000010 "C:\Windows\TEMP\{6AD962EA-8D31-410A-A2CA-16CCD8081B9A}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0002
0003 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_3_300_268.ocx
0004 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_268_ActiveX.exe
0005 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_268_ActiveX.dll
0007 00000012
=X====== M/11.3.300.268 2012-07-27+12-44-57.466 ========
?=O====== M/11.3.300.268 2012-07-27+13-19-44.291 ========
0000 00000010 "C:\Windows\TEMP\{8006E296-C764-4846-8493-B2B2C01CC95D}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0002
0003
0004
0005
0006
0007
0008 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_3_300_268.dll
0009 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_268_Plugin.exe
0011 00000012
=X====== M/11.3.300.268 2012-07-27+13-19-45.447 ========
?=O====== M/11.3.300.268 2012-07-27+14-19-45.758 ========
0000 00000010 "C:\Windows\TEMP\{1EDCC950-E15D-4049-9968-9DFB2105A5AC}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0002
0003
0004
0005
0006
0007
0011 00000012
=X====== M/11.3.300.268 2012-07-27+14-19-47.292 ========
?=O====== M/11.3.300.268 2012-07-28+12-10-32.887 ========
0000 00000010 "C:\Windows\TEMP\{53EC27D1-2A7E-4BFB-A9BD-DD96B4E22D4A}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0002
0003
0004
0005
0006
0007
0011 00000012
=X====== M/11.3.300.268 2012-07-28+12-10-36.459 ========
?=O====== M/11.3.300.268 2012-07-28+12-19-47.841 ========
0000 00000010 "C:\Windows\TEMP\{AE5A2887-A324-4DBD-9D51-B90435AC347E}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 9 -au 4294967295
0001
=X====== M/11.3.300.268 2012-07-28+12-19-48.139 ========
?=O====== M/11.3.300.265 2012-07-29+09-41-57.043 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{62FCF34D-119C-4C41-83FC-C203ECD11797}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0001
=X====== M/11.3.300.265 2012-07-29+09-41-57.245 ========
?=O====== M/11.3.300.265 2012-07-29+09-42-25.447 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{0D646003-6614-4B1C-98DF-6B2019003163}\InstallFlashPlayer.exe" -uninstall plugin
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
=X====== M/11.3.300.265 2012-07-29+09-42-25.540 ========
?=O====== M/11.3.300.265 2012-07-29+09-58-46.488 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{5C943027-855C-4589-AD44-84C3905171B8}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0001
0002
0004
0005
0006
0007
0008
0009
0010
=X====== M/11.3.300.265 2012-07-29+09-58-47.361 ========
?=O====== M/11.3.300.268 2012-07-29+10-06-04.341 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{37484A5F-0455-4DDC-B8F9-6A2B2979AC64}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0002
=X====== M/11.3.300.268 2012-07-29+10-06-09.240 ========
?=O====== M/11.3.300.268 2012-07-29+10-06-26.593 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{5C5ABA0F-333B-4DCA-9E6C-D93149F4545F}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0002
0003
0004
0005
0006
0007
=X====== M/11.3.300.268 2012-07-29+10-06-27.669 ========
?=O====== M/11.3.300.268 2012-07-30+16-16-31.710 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{D4E1B84D-7959-4A07-AB02-E1EC4A6235EE}\InstallFlashPlayer.exe" -uninstall activex
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
=X====== M/11.3.300.268 2012-07-30+16-16-32.053 ========
?=O====== M/11.3.300.268 2012-07-30+16-16-58.589 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{B6B8FC82-F8F4-46C4-BA33-A76AF490D83B}\InstallFlashPlayer.exe" -uninstall plugin
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
=X====== M/11.3.300.268 2012-07-30+16-16-58.714 ========
?=O====== M/11.3.300.268 2012-07-30+16-21-54.591 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{9069434A-8364-4F45-8FF5-67EE0CB65C42}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0001
0002
0004
0005
0006
0007
0008
0009
0010
0011 00000014 C:\Windows\system32\Macromed\Flash\NPSWF64_11_3_300_268.dll
0012 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_268_Plugin.exe
=X====== M/11.3.300.268 2012-07-30+16-21-55.761 ========
?=O====== M/11.3.300.268 2012-07-30+16-23-41.412 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{F4125AD3-9A57-4B7A-8191-5603F6EC99BA}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0001
0003
0004 00000013 C:\Windows\system32\Macromed\Flash\Flash64_11_3_300_268.ocx
0005 00000015 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_268_ActiveX.exe
0006 00000016 C:\Windows\system32\Macromed\Flash\FlashUtil64_11_3_300_268_ActiveX.dll
=X====== M/11.3.300.268 2012-07-30+16-23-43.440 ========
?=O====== M/11.3.300.268 2012-07-31+14-13-51.294 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{F8606E07-9096-4065-970E-8E4DC7375FBF}\InstallFlashPlayer.exe" -uninstall activex
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
=X====== M/11.3.300.268 2012-07-31+14-13-52.105 ========
?=O====== M/11.3.300.268 2012-07-31+14-14-03.618 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{20F711EC-38B0-4718-87B2-3795F02CF637}\InstallFlashPlayer.exe" -uninstall plugin
0001
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016
0017
0018
0019
=X====== M/11.3.300.268 2012-07-31+14-14-03.696 ========
?=O====== M/11.3.300.268 2012-07-31+14-18-56.715 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{CCC7BE9E-74E6-4CD8-A2D3-DAFD0EE5211D}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 2 -au 4294967295
0001
0002
0004
0005
0006
0007
0008
0009
0010
=X====== M/11.3.300.268 2012-07-31+14-18-57.417 ========
?=O====== M/11.3.300.268 2012-07-31+14-21-22.451 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{083D62AD-E51C-4E63-A001-6B4AFB1D9046}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 2 -au 4294967295
0001
0003
=X====== M/11.3.300.268 2012-07-31+14-21-23.855 ========
?=O====== M/11.3.300.268 2012-07-31+14-22-28.516 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{2C0F79DB-47F8-4253-AD5A-3F87A261C40C}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 2 -au 4294967295
0002
0003
0004
0005
0006
0007
=X====== M/11.3.300.268 2012-07-31+14-22-29.124 ========
?=O====== M/11.3.300.268 2012-07-31+14-52-23.602 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{78634999-0393-4AD2-96EF-D3D2D15CF0B6}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 2 -au 4294967295
0002
0003
0004
0005
0006
0007
=X====== M/11.3.300.268 2012-07-31+14-52-24.694 ========
?=O====== M/11.3.300.268 2012-07-31+14-53-14.396 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{CF9EF76B-CAB0-4A67-B556-454E601DD99E}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0002
=X====== M/11.3.300.268 2012-07-31+14-53-16.720 ========
?=O====== M/11.3.300.268 2012-07-31+14-53-36.611 ========
0000 00000010 "C:\Users\Admin\AppData\Local\Temp\{2C5B5A9A-73BB-4B39-96F5-689F07E78322}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0002
0003
0004
0005
0006
0007
=X====== M/11.3.300.268 2012-07-31+14-53-37.500 ========
Am 02.08.2012 02:44, schrieb Chris Campbell:
Re: flashplayer.xpt can not be written to
created by Chris Campbell
<http://forums.adobe.com/people/chris.campbell> in /Installing Flash
Player/ - View the full discussion
Could you try creating a text file named flashplayer.xpt to your C:\windows\syswow64\macromed\flash folder by hand (you'll want to make sure that the extension is xpt, not txt)? Once created, try running the installer again.
I did this as you described it.
Installation of install_flash_player_11_plugin.exe ends with:
flashplayer.xpt: properties ---> security tab ---> current owner cannot be displayed
Let's try taking ownership of flashplayer.xpt.
1. Type cmd in the start menu, right click on cmd.exe and "run as administrator"
2. Navigate to "cd c:\windows\syswow64\macromed\flash\"
3. Type "takeown /a /f flashplayer.xpt"
Hopefully you receive a success message. If so, give the installer another try.
Fehler: Zugriff verweigert
Error: Access denied
I am starting to wonder if you have a more general problem with your HD.
Can you run a CHKDSK? Start button | type cmd
In the Command Prompt type chkdsk C: /r
You may need to restart Windows to allow the disk checker to run. Depending on your HD size this may take a long time.
No errors.
Could you try downloading Process Explorer from here: http://technet.microsoft.com/en-us/sysinternals/bb896653
Run it, open Find > Find Handle or DLL… and enter flashplayer.xpt in the search bar. Once you hit search, what process is displayed?
The next step would be to run Process Monitor (http://technet.microsoft.com/en-us/sysinternals/bb896645.aspx), attempt to run takeown again, and save the process monitor log off. If possible, email it to ccampbel@adobe.com.
Answer: No process is displayed.
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. Alle Rechte vorbehalten.
C:\Windows\system32>z:
Z:\>cd pstools
Z:\PSTools>PsExec -s -d Z:\ProcessMonitor\Procmon.exe /AcceptEula /Quiet /BackingFile C:\Procmon.pml
PsExec v1.98 - Execute processes remotely
Copyright (C) 2001-2010 Mark Russinovich
Sysinternals - www.sysinternals.com
Z:\ProcessMonitor\Procmon.exe started on ADMIN-PC with process ID 3500.
Z:\PSTools>c:
C:\Windows\System32>cd ..
C:\Windows>cd syswow64
C:\Windows\SysWOW64>cd macromed
C:\Windows\SysWOW64\Macromed>cd flash
C:\Windows\SysWOW64\Macromed\Flash>takeown /a /f flashplayer.xpt
Fehler: Zugriff verweigert (Error: Access denied)
Restarted Windows. After restart size of C:\Procmon.pml is 244.413 kB. I can not email this file. I could send logfile.csv as RAR-Archive (2 MB) instead. Would this be ok?
Please feel free to email it to me at ccampbel@adobe.com or post it someplace like dropbox or sendnow and send me the link.
I also received an email from another customer this weekend that had run into a similar problem. Here's what they found and how they were able to resolve the problem:
The reason for blocking the file flashplayer.xpt was the program ThreatFire.
Although I removed the program from Autostart and no entry in the taskmanager was found a ThreatFire service was running and blocked the installing process.
After uninstalling ThreatFire completely from the computer I had no problems to install flashplayer.
Yes, ThreatFire was the culprit. It was not necessary to uninstall ThreatFire competely. It was enough to delete items under tab Quarantined under tab Threat Control.
Everything is fine now.
=O====== M/11.3.300.271 2012-08-14+16-29-39.478 ========
0000 00000010 "Z:\Installation\Adobe Flash Player\11.3.300.270\install_flash_player_11_active_x.exe"
0001
0002
0004 00000011 1
0005
0006 00000013 C:\Windows\SysWOW64\Macromed\Flash\Flash32_11_3_300_271.ocx
0007 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_3_300_271_ActiveX.exe
0008 00000016 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_3_300_271_ActiveX.dll
0010 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
=X====== M/11.3.300.271 2012-08-14+16-29-54.532 ========
=O====== M/11.3.300.271 2012-08-14+16-30-02.481 ========
0000 00000010 "Z:\Installation\Adobe Flash Player\11.3.300.270\install_flash_player_11_plugin.exe"
0001
0002
0003
0004
0005 00000020 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0006 00000011 1
0007
0008
0009
0010
0011
0012
0013
0014
0015
0016 00000014 C:\Windows\SysWOW64\Macromed\Flash\NPSWF32_11_3_300_271.dll
0017 00000015 C:\Windows\SysWOW64\Macromed\Flash\FlashUtil32_11_3_300_271_Plugin.exe
0019 00000019 C:\Windows\SysWOW64\FlashPlayerCPLApp.cpl
0020
0021
0022 00000022 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerPlugin_11_3_300_271.exe
0023 00000021 C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0024
0025
0026
=X====== M/11.3.300.271 2012-08-14+16-30-16.693 ========
Thanks for the update and thanks a ton to the customer that sent me this info!! I've never used Threatfire, but I'm going to give it a try and see how it runs on my system.
