1
3D menu doesn't appear - Photoshop CS6 extended
Guest
Aug 12, 2012 Aug 12, 2012
The 3D menu doesn't appear on my Photoshop CS6 extended.
I am running Windows 7 Ultimate (Version 6.1)
Any ideas about what is going on?
132.5K
LEGEND , Aug 12, 2012 Aug 12, 2012
That's an entirely different issue...  The software is looking for your Graphics Processor to deliver a certain level of functionality, and apparently it's not finding what it needs.
Check your Edit - Preferences - Performance dialog, and see if the [  ] Use Graphics Processor option is enabled.  If it can be but is not currently enabled, try checking it then restarting Photoshop.
If it can't be enabled, you may want to see if you can get an updated display driver from the web site of the maker of
Adobe
The appearance / hiding of the menu is dependent on whether Photoshop thinks your license is for Extended or Standard, and that's managed through the serial number.
If you've purchased Extended, but only Standard features are available, you may ultimately have to call Adobe customer support to get it worked out.  But some folks have reported here on the forum that Deactivating the software (through the Help menu) then reactivating it has cleared similar problems.
-Noel
Guest
Hey Noel Carboni,
Thanks for your answer. I uninstalled and installed it again and now the 3D menu is appearing.
But now all the options inside the 3D menu are unavailable. I can see them but they aren't available for clicking.
Any thoughts about that?
If it can't be enabled, you may want to see if you can get an updated display driver from the web site of the maker of your video card in your computer.
-Noel
Guest
Aug 13, 2012 Aug 13, 2012
Huge thanks Noel Carboni! Problem fixed. I hope this topic can be useful for other users.
You're welcome!  I'm happy I could be of help, and thanks in return for following up and reporting your success.
-Noel
Feb 16, 2013 Feb 16, 2013
Dear Noel,
I'm facing the same problem as of Matheus. I've been through every single step of troubleshooting which you've mentioned in this thread. I'm usuing Dell Studio 1558 Laptop with Windows 7 Ultimate platform 64-bit. It has an 8 GB of RAM and an ATI Mobility Radeon HD 5470 Graphics Card 1GB (with the latest drivers installed).
Though I'm using the Extended version only but I'm still unable to get that 3D option. I've tried uninstalling the CS6 couple of times. Even tried Creative Suite Cleaner and then re-installing it however, the problem persists.
Aman Gill.
Feb 17, 2013 Feb 17, 2013
First, go download and install the Photoshop updates - you're still on 13.0.0.
And you've got regular, not extended -- and the 3D features are only available in extended.
Dear Chris,
                        This is an Extended copy. Second my "Update" setting copy is greyed out. Something which is quiet astonishing is that earlier it was working just fine but all of as sudden it stopped working. I mean it just disappeared abruptly.
Aman Gill.
Dear Chris,
                        I've updated the Photoshop CS6. Here is the snap shot of it. Still I'm facing the same problem.Untitled.jpg
That is not extended - it does not say extended in the splash screen, and has no 3D menu.
All-right Pal. Let me try the extended one the
Thanks a lot for your help anyways.....
I'll keep you updated
Aman Gil.
Mar 10, 2013 Mar 10, 2013
Hate to say it, but I cannot click anything on my 3D menu anymore. After i updated to my Photoshop via the Application Manager (both at work and home). I'm using Windows 8 (H) and Windows 7 (W). Everything worked fine until I updated. Are there any known issues involving the update? Are the required PC Specs different now?
Thanks for any information....
JW
The specs recently changed for Creative Cloud Phostoshop.
Version 13.1 and newer strictly require a minimum of 512 MB VRAM for the 3D features to be made available.
http://helpx.adobe.com/photoshop/kb/new-system-requirements-photoshop-131.html
And check Help-> System Info -- your video card driver may have crashed and forced GPU features to be disabled.
Feb 18, 2013 Feb 18, 2013
I have the same problem where all the options inside the 3D menu are unavailable and I can see them but they aren't available for clicking
I try'd what you suggested and my display driver is up to date, so I don't know why it won't let me enable the Graphics Processor option
Could you please help if possible??
[ several duplicate posts removed by admin ]
Kara - in your case it means that either you are running an OS that isn't capable (XP) or something about your video card says it is not capable of using the 3D features.
Check Help -> System Info for more information about your GPU/driver.
it sais:
The GPU Sniffer crashed on 18/02/2013 at 21:14:33
I did uninstall it as well and then re install it but nothing has changed.  The lightning effects filter is also greyd out, if you know what I mean?
Thanks for replying so quickly!
it sais:
it also states no video card dtected? I'm gunna paste verything it says so you can have a look at it if that ok?:
Adobe Photoshop Version: 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00) x32
Operating System: Windows 7 32-bit
Version: 6.1 Service Pack 1
System architecture: Intel CPU Family:6, Model:7, Stepping:10 with MMX, SSE Integer, SSE FP, SSE2, SSE3
Physical processor count: 2
Processor speed: 2610 MHz
Built-in memory: 2037 MB
Free memory: 412 MB
Memory available to Photoshop: 1627 MB
Memory used by Photoshop: 60 %
Image tile size: 128K
Image cache levels: 4
Display: 1
Display Bounds:=  top: 0, left: 0, bottom: 1080, right: 1920
No video card detected
Serial number: Tryout Version
Application folder: C:\Program Files\Adobe\Adobe Photoshop CS6\
Temporary file path: C:\Users\Kara\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
  Startup, 288.8G, 202.6G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6\Required\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6\Plug-ins\
Additional Plug-ins folder: not set
Installed components:
   A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
   ACE.dll   ACE 2012/01/18-15:07:40   66.492997   66.492997
   adbeape.dll   Adobe APE 2012/01/25-10:04:55   66.1025012   66.1025012
   AdobeLinguistic.dll   Adobe Linguisitc Library   6.0.0
   AdobeOwl.dll   Adobe Owl 2012/02/09-16:00:02   4.0.93   66.496052
   AdobePDFL.dll   PDFL 2011/12/12-16:12:37   66.419471   66.419471
   AdobePIP.dll   Adobe Product Improvement Program   6.0.0.1654
   AdobeXMP.dll   Adobe XMP Core 2012/02/06-14:56:27   66.145661   66.145661
   AdobeXMPFiles.dll   Adobe XMP Files 2012/02/06-14:56:27   66.145661   66.145661
   AdobeXMPScript.dll   Adobe XMP Script 2012/02/06-14:56:27   66.145661   66.145661
   adobe_caps.dll   Adobe CAPS   6,0,29,0
   AGM.dll   AGM 2012/01/18-15:07:40   66.492997   66.492997
   ahclient.dll    AdobeHelp Dynamic Link Library   1,7,0,56
   aif_core.dll   AIF   3.0   62.490293
   aif_ocl.dll   AIF   3.0   62.490293
   aif_ogl.dll   AIF   3.0   62.490293
   amtlib.dll   AMTLib   6.0.0.75 (BuildVersion: 6.0; BuildDate: Mon Jan 16 2012 18:00:00)   1.000000
   ARE.dll   ARE 2012/01/18-15:07:40   66.492997   66.492997
   AXE8SharedExpat.dll   AXE8SharedExpat 2011/12/16-15:10:49   66.26830   66.26830
   AXEDOMCore.dll   AXEDOMCore 2011/12/16-15:10:49   66.26830   66.26830
   Bib.dll   BIB 2012/01/18-15:07:40   66.492997   66.492997
   BIBUtils.dll   BIBUtils 2012/01/18-15:07:40   66.492997   66.492997
   boost_date_time.dll   DVA Product   6.0.0
   boost_signals.dll   DVA Product   6.0.0
   boost_system.dll   DVA Product   6.0.0
   boost_threads.dll   DVA Product   6.0.0
   cg.dll   NVIDIA Cg Runtime   3.0.00007
   cgGL.dll   NVIDIA Cg Runtime   3.0.00007
   CIT.dll   Adobe CIT   2.0.5.19287   2.0.5.19287
   CoolType.dll   CoolType 2012/01/18-15:07:40   66.492997   66.492997
   data_flow.dll   AIF   3.0   62.490293
   dvaaudiodevice.dll   DVA Product   6.0.0
   dvacore.dll   DVA Product   6.0.0
   dvamarshal.dll   DVA Product   6.0.0
   dvamediatypes.dll   DVA Product   6.0.0
   dvaplayer.dll   DVA Product   6.0.0
   dvatransport.dll   DVA Product   6.0.0
   dvaunittesting.dll   DVA Product   6.0.0
   dynamiclink.dll   DVA Product   6.0.0
   ExtendScript.dll   ExtendScript 2011/12/14-15:08:46   66.490082   66.490082
   FileInfo.dll   Adobe XMP FileInfo 2012/01/17-15:11:19   66.145433   66.145433
   filter_graph.dll   AIF   3.0   62.490293
   hydra_filters.dll   AIF   3.0   62.490293
   icucnv40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
   icudt40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
   image_compiler.dll   AIF   3.0   62.490293
   image_flow.dll   AIF   3.0   62.490293
   image_runtime.dll   AIF   3.0   62.490293
   JP2KLib.dll   JP2KLib 2011/12/12-16:12:37   66.236923   66.236923
   libeay32.dll   The OpenSSL Toolkit   0.9.8g
   libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
   libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   10.0
   LogSession.dll   LogSession   2.1.2.1640
   mediacoreif.dll   DVA Product   6.0.0
   MPS.dll   MPS 2012/02/03-10:33:13   66.495174   66.495174
   msvcm80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
   msvcm90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
   msvcp100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
   msvcp71.dll   Microsoft® Visual Studio .NET   7.10.3077.0
   msvcp80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
   msvcp90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
   msvcr100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
   msvcr71.dll   Microsoft® Visual Studio .NET   7.10.3052.4
   msvcr80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
   msvcr90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
   pdfsettings.dll   Adobe PDFSettings   1.04
   Photoshop.dll   Adobe Photoshop CS6   CS6
   Plugin.dll   Adobe Photoshop CS6   CS6
   PlugPlug.dll   Adobe(R) CSXS PlugPlug Standard Dll (32 bit)   3.0.0.383
   PSArt.dll   Adobe Photoshop CS6   CS6
   PSViews.dll   Adobe Photoshop CS6   CS6
   SCCore.dll   ScCore 2011/12/14-15:08:46   66.490082   66.490082
   ScriptUIFlex.dll   ScriptUIFlex 2011/12/14-15:08:46   66.490082   66.490082
   shfolder.dll   Microsoft(R) Windows (R) 2000 Operating System   5.50.4027.300
   ssleay32.dll   The OpenSSL Toolkit   0.9.8g
   tbb.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
   tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
   TfFontMgr.dll   FontMgr   9.3.0.113
   TfKernel.dll   Kernel   9.3.0.113
   TFKGEOM.dll   Kernel Geom   9.3.0.113
   TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
   updaternotifications.dll   Adobe Updater Notifications Library   6.0.0.24 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   6.0.0.24
   WRServices.dll   WRServices Friday January 27 2012 13:22:12   Build 0.17112   0.17112
   wu3d.dll   U3D Writer   9.3.0.113
Required plug-ins:
   3D Studio 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Accented Edges 13.0
   Adaptive Wide Angle 13.0
   ADM 3.11x01
   Angled Strokes 13.0
   Average 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Bas Relief 13.0
   BMP 13.0
   Camera Raw 7.3
   Chalk & Charcoal 13.0
   Charcoal 13.0
   Chrome 13.0
   Cineon 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Clouds 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Collada 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Color Halftone 13.0
   Colored Pencil 13.0
   CompuServe GIF 13.0
   Conté Crayon 13.0
   Craquelure 13.0
   Crop and Straighten Photos 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Crop and Straighten Photos Filter 13.0
   Crosshatch 13.0
   Crystallize 13.0
   Cutout 13.0
   Dark Strokes 13.0
   De-Interlace 13.0
   Dicom 13.0
   Difference Clouds 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Diffuse Glow 13.0
   Displace 13.0
   Dry Brush 13.0
   Eazel Acquire 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Embed Watermark 4.0
   Entropy 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Extrude 13.0
   FastCore Routines 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Fibers 13.0
   Film Grain 13.0
   Filter Gallery 13.0
   Flash 3D 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Fresco 13.0
   Glass 13.0
   Glowing Edges 13.0
   Google Earth 4 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Grain 13.0
   Graphic Pen 13.0
   Halftone Pattern 13.0
   HDRMergeUI 13.0
   IFF Format 13.0
   Ink Outlines 13.0
   JPEG 2000 13.0
   Kurtosis 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Lens Blur 13.0
   Lens Correction 13.0
   Lens Flare 13.0
   Liquify 13.0
   Matlab Operation 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Maximum 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Mean 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Measurement Core 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Median 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Mezzotint 13.0
   Minimum 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   MMXCore Routines 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Mosaic Tiles 13.0
   Multiprocessor Support 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Neon Glow 13.0
   Note Paper 13.0
   NTSC Colors 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Ocean Ripple 13.0
   Oil Paint 13.0
   OpenEXR 13.0
   Paint Daubs 13.0
   Palette Knife 13.0
   Patchwork 13.0
   Paths to Illustrator 13.0
   PCX 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Photocopy 13.0
   Photoshop 3D Engine 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Picture Package Filter 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Pinch 13.0
   Pixar 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Plaster 13.0
   Plastic Wrap 13.0
   PNG 13.0
   Pointillize 13.0
   Polar Coordinates 13.0
   Portable Bit Map 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Poster Edges 13.0
   Radial Blur 13.0
   Radiance 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Range 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Read Watermark 4.0
   Reticulation 13.0
   Ripple 13.0
   Rough Pastels 13.0
   Save for Web 13.0
   ScriptingSupport 13.0
   Shear 13.0
   Skewness 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Smart Blur 13.0
   Smudge Stick 13.0
   Solarize 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Spatter 13.0
   Spherize 13.0
   Sponge 13.0
   Sprayed Strokes 13.0
   Stained Glass 13.0
   Stamp 13.0
   Standard Deviation 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Sumi-e 13.0
   Summation 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Targa 13.0
   Texturizer 13.0
   Tiles 13.0
   Torn Edges 13.0
   Twirl 13.0
   U3D 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Underpainting 13.0
   Vanishing Point 13.0
   Variance 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Variations 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Water Paper 13.0
   Watercolor 13.0
   Wave 13.0
   Wavefront|OBJ 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   WIA Support 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   Wind 13.0
   Wireless Bitmap 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
   ZigZag 13.0
Optional and third party plug-ins: NONE
Plug-ins that failed to load: NONE
Flash:
   Mini Bridge
   Kuler
Installed TWAIN devices: NONE
It says that the GPU sniffer crashed before it could get the identity of your video card.  That means there's a huge bug in your video card driver.   You probably need to update the driver (from the GPU maker's website).
Also, you have Photoshop 13.0.0 and should be on 13.0.1 or 13.1.2.
Feb 19, 2013 Feb 19, 2013
great
Ok thanks I will try that, the driver is up to date but should I download it anyway?
This is really starting to get on my nerves
Thanks.
Kara.
great
Thanks.
Kara.
The driver is up to date according to who?  Did you get the latest from the GPU maker's website?  Or Microsoft (mistake)? or the card builder (another mistake)?  Or the system integrator (another mistake)?
According to INTEL where I clicked on the option automatically identify and find drivers:
It came up saying my driver is current (Intel® G33/G31)
