How can I resolve installation errors DF024 & DF037 for CS5.5 on Mac?
Aug 12, 2012 7:38 PM
Tags: none (add) #cs5.5 #installation_error #df024 #df037 #cameraprofiles #sscPlease help. I've gone through the forum posts, as well as searched the Internet, and find the matter daunting. Have tried to implement a solution and may have caused more problems. Assistance would be greatly appreciated.
PROBLEM:
I am unable to uninstall or reinstall both Dreamweaver 5.5 and CS 5.5.
Continually get extensive number of the following errors:
ERROR DF024 Unable to preserve original file...
ERROR DF024 Unable to move file…
ERROR DF037 Unable to delete directory…
SYSTEM CONFIG:
Adobe CS 5.5
Mac OS 10.7.4
MacBook Pro 2.5 GHz
Intel Core 2 Duo with 4 GB Ram
BACKGROUND (History appears chronologically in 4 parts.):
- CS 5.5 was already installed and functioning fine, then upgraded from OS 10.6 to 10.7. Noticed issues with elements not appearing in DISPLAY VIEW of Dreamweaver, but was correct in CODE VIEW and BROWSER PREVIEW.
- Tried to reinstall and uninstall Dreamweaver 5.5 several times using the CS 5.5 installation disk. Consistently got DF024 errors. NOTE: After first attempt. installer marked Dreamweaver as already installed, but not the others. Using the Finder, the Dreamweaver directory appears to be empty unless the files are now hidden. Nothing regarding the application can be seen in the Trash. Also unable to launch any other Adobe CS apps.
Exit Code: 7
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 19 error(s), 15 warning(s)
----------- Payload: {ED28819E-310F-4F17-925C-C69B0A1C1F7F} Suite Shared Configuration CS5.5 2.5.0.0 -----------
ERROR: DF024: Unable to preserve original file at "/Library/Application Support/Adobe/ssc/DesignSuitePremium-CS5-Win-GM/SLConfig.xml" Error 0(Seq 15)
ERROR: DW063: Command ARKDeleteFileCommand failed.(Seq 15)
WARNING: DW036: Payload cannot be installed due to dependent operation failure
- SLConfig.xml appeared to be an alias pointing to a file of the same name in the Mac version. Went to original file, made a new alias and replaced the corrupted file.
- Then rebooted system and relaunched CSS5.5 Installer with all apps selected. Program started and ran for about 15 min before reporting more errors, now with error DF037 as well. Did this again with the same results except the DF037 error did not reappear. It appears the the problems are mostly in two directories:
/Library/Application Support/Adobe/CameraRaw/CameraProfiles/
and
/Library/Application Support/Adobe/ssc/DesignSuitePremium-CS5.5-Win-GM/
but I am not sure how to best resolve this.
- Below are selected portions of the most recent (and VERY verbose) error log. To conserve space, log entries in which the same error is repeated are truncated. (Only the first one and last repetitions are copied here; the others have been omitted and are replaced with highlighted ellipses [i.e., "..."].) Please let me know if you would like the complete log report.
Exit Code: 7
- 0 fatal error(s), 238 error(s), 98 warning(s)
WARNING: DW031: Payload:{0D96CFE6-376D-44B8-808A-16F3BEB73263} Adobe Media Encoder CS5.5 5.5.0.0 has been updated and has been selected for repair. The patch {41BFF2C7-9F45-4CF3-A257-E80E14802157} Adobe Media Encoder CS5.5_5.5.1_AMECore5.5All 5.5.1.0 will be uninstalled now.
WARNING: DW031: Payload:{37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw 6.0.0.0 has been updated and has been selected for repair. The patch {4E1B59A1-029E-4C16-BBB3-F10D40EBB6EE} Photoshop Camera Raw_6.7_AdobeCameraRaw6.0All 6.7.0.0 will be uninstalled now.
WARNING: DW031: Payload:{6A2E619B-E4AC-433B-A648-D458CE543A96} Adobe XMP Panels CS5 3.0.0.0 has been updated and has been selected for repair. The patch {5C0FEBDA-5A0E-4FC8-91CB-229A4C1561E9} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll 3.1.0.0 will be uninstalled now.
WARNING: DW031: Payload:{F313167E-5172-11E0-ACE7-30C2E3AB3DC5} Adobe InDesign CS5.5 Common Base Files 7.5.0.0 has been updated and has been selected for repair. The patch {6AFE0576-7A2C-11E1-88D2-74AAF24106A5} Adobe InDesign CS5.5 Common Base Files_7.5.3.333_AdobeInDesign7xCommonBase-mul 7.5.3.333 will be uninstalled now.
WARNING: DW031: Payload:{0CCF0458-5171-11E0-BC45-DC59E3AB3DC5} Adobe InDesign CS5.5 Application Base Files 7.5.0.0 has been updated and has been selected for repair. The patch {848BF4CC-7A2B-11E1-8A90-3F8CF24106A5} Adobe InDesign CS5.5 Application Base Files_7.5.3.333_AdobeInDesign7xAppBase-mul 7.5.3.333 will be uninstalled now.
WARNING: DW031: Payload:{3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer 6.0.0.0 has been updated and has been selected for repair. The patch {A189C479-C7CD-4E08-8CCF-D999B68C0C71} Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All 6.3.0.0 will be uninstalled now.
WARNING: DW031: Payload:{ED9DC850-516E-11E0-9096-1FE5E2AB3DC5} Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-en_US 7.5.0.0 has been updated and has been selected for repair. The patch {C68C3E1A-7A29-11E1-A9D9-0F55F24106A5} Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-en_US 7.5.3.333 will be uninstalled now.
WARNING: DW031: Payload:{D97AF04B-B70A-4862-BC25-31E6D9C4A529} Adobe Flash CS5.5 11.5.0.0 has been updated and has been selected for repair. The patch {D9F625C8-FD5B-4C13-9B3C-5B9F09BA0DC0} Adobe Flash CS5.5_11.5.1_AdobeFlash11.5-mul 11.5.1.0 will be uninstalled now.
WARNING: DW031: Payload:{03FB981A-5170-11E0-A90E-3CEDE2AB3DC5} Adobe InDesign CS5.5 Application Base Files2 7.5.0.0 has been updated and has been selected for repair. The patch {FE75A95E-7A2B-11E1-8037-B59BF24106A5} Adobe InDesign CS5.5 Application Base Files2_7.5.3.333_AdobeInDesign7xAppBase2-mul 7.5.3.333 will be uninstalled now.
ERROR: DF024: Unable to preserve original file at "/Library/Application Support/Adobe/ssc/DesignSuitePremium-CS5.5-Win-GM/aul.xml" Error 0(Seq 26)
ERROR: DW063: Command ARKDeleteFileCommand failed.(Seq 26)
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050: - Adobe WinSoft Linguistics Plugin CS5: Install failed
ERROR: DW050: - AdobeHelp: Install failed
ERROR: DW050: - Adobe InDesign CS5.5 Application Base Files2: Install failed
ERROR: DW050: - Creative Suite 5.5 Design Premium: Install failed
ERROR: DW050: - Adobe Photoshop CS5.1 Core: Failed due to Language Pack installation failure
ERROR: DW050: - Adobe InDesign CS5.5 Application Base Files: Failed due to Language Pack installation failure
ERROR: DW050: - Adobe Media Encoder CS5.5: Install failed
ERROR: DW050: - AdobeColorNA CS5.5: Install failed
ERROR: DW050: - DynamiclinkSupport: Install failed
ERROR: DW050: - Adobe Device Central CS5.5_DeviceCentral3.5LP-en_US: Install failed
ERROR: DW050: - HIL Help Search: Install failed
ERROR: DW050: - Adobe Flash CS5.5_AdobeMobileExtension_Flash11.5-en_US: Install failed
ERROR: DW050: - CSXS Story Extension: Install failed
ERROR: DW050: - Photoshop Camera Raw: Install failed
ERROR: DW050: - Adobe Player for Embedding 3.2: Install failed
ERROR: DW050: - Adobe Extension Manager CS5.5: Install failed
ERROR: DW050: - Adobe WinSoft Linguistics Plugin CS5.5: Install failed
ERROR: DW050: - Adobe Media Encoder CS5.5_5.5.1_AMECore5.5All: Install failed
ERROR: DW050: - AdobeColorCommonSetRGB: Install failed
ERROR: DW050: - AdobeColorPhotoshop CS5.5: Install failed
ERROR: DW050: - Adobe Device Central CS5.5: Failed due to Language Pack installation failure
ERROR: DW050: - Adobe Mini Bridge CS5.1: Install failed
ERROR: DW050: - Adobe ReviewPanel CS5.5: Install failed
ERROR: DW050: - Adobe Fireworks CS5.1: Failed due to Language Pack installation failure
ERROR: DW050: - Adobe SING CS5: Install failed
ERROR: DW050: - Photoshop Camera Raw_6.7_AdobeCameraRaw6.0All: Install failed
ERROR: DW050: - Adobe SwitchBoard 2.0: Install failed
ERROR: DW050: - Adobe Flash Catalyst CS5.5: Install failed
ERROR: DW050: - AdobeColorCommonSetCMYK: Install failed
ERROR: DW050: - Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll: Install failed
ERROR: DW050: - Adobe Hunspell Linguistics Plugin CS5.5: Install failed
ERROR: DW050: - Adobe XMP Panels CS5: Install failed
ERROR: DW050: - Adobe InDesign CS5.5 Common Base Files_7.5.3.333_AdobeInDesign7xCommonBase-mul: Install failed
ERROR: DW050: - AIR for APPLE IOS Support (FP): Install failed
ERROR: DW050: - AdobeTypeSupport CS5: Install failed
ERROR: DW050: - Adobe CSXS Infrastructure CS5.5: Install failed
ERROR: DW050: - Adobe InDesign CS5.5 Common Language Files_AdobeInDesign7xCommonLang-en_US: Install failed
ERROR: DW050: - Adobe Flash Fonts1: Install failed
ERROR: DW050: - Adobe Content Viewer: Install failed
ERROR: DW050: - Adobe InDesign CS5.5 Application Base Files_7.5.3.333_AdobeInDesign7xAppBase-mul: Install failed
ERROR: DW050: - Adobe Fireworks CS5.1_AdobeFireworks11.1.0en_USLanguagePack: Install failed
ERROR: DW050: - Adobe Flash CS5.5_AdobeFlash11.5-en_USLanguagePack: Install failed
ERROR: DW050: - Digital Publishing: Failed due to Language Pack installation failure
ERROR: DW050: - Adobe Dreamweaver CS5.5: Failed due to Language Pack installation failure
ERROR: DW050: - Adobe ExtendScript Toolkit CS5.5: Install failed
ERROR: DW050: - Adobe Illustrator CS5.1_AdobeIllustrator15_1en_USLanguagePack: Install failed
ERROR: DW050: - Pixel Bender Toolkit: Install failed
ERROR: DW050: - Adobe Dreamweaver Widget Browser: Install failed
ERROR: DW050: - Adobe Toolhints CS5.5: Install failed
ERROR: DW050: - PDF Settings CS5: Install failed
ERROR: DW050: - Adobe Linguistics CS5: Install failed
ERROR: DW050: - Adobe Illustrator CS5.1: Failed due to Language Pack installation failure
ERROR: DW050: - AdobeColorJA CS5.5: Install failed
ERROR: DW050: - AdobeOutputModule: Install failed
ERROR: DW050: - Acrobat Professional: Install failed
ERROR: DW050: - Adobe Dreamweaver CS5.5_AdobeDreamweaver11.5en_USLanguagePack: Install failed
ERROR: DW050: - AdobePDFL CS5: Install failed
ERROR: DW050: - AdobeCMaps CS5: Install failed
ERROR: DW050: - Adobe CSXS Extensions CS5.5: Install failed
ERROR: DW050: - Adobe Digital Publishing Application Language Files_AdobeDigitalPublishingAppLang-en_US: Install failed
ERROR: DW050: - Adobe InDesign CS5.5 Application Language Files_7.5.3.333_AdobeInDesign7xAppLang-en_US: Install failed
ERROR: DW050: - Required Common Fonts Installation: Install failed
ERROR: DW050: - Adobe InDesign CS5.5 Application Feature Set Files: Install failed
ERROR: DW050: - Adobe Buzzword CS5.5: Install failed
ERROR: DW050: - Adobe Flash CS5.5: Failed due to Language Pack installation failure
ERROR: DW050: - Adobe Flash CS5.5_11.5.1_AdobeFlash11.5-mul: Install failed
ERROR: DW050: - SiteCatalyst NetAverages CS5.5: Install failed
ERROR: DW050: - Flash Player: Install failed
ERROR: DW050: - Adobe Flash CS5.5_AdobeMobileExtension_Flash11.5-mul: Install failed
ERROR: DW050: - Recommended Common Fonts Installation: Install failed
ERROR: DW050: - AdobeColorVideoProfilesCS CS5.5: Install failed
ERROR: DW050: - Suite Shared Configuration CS5.5: Install failed
ERROR: DW050: - Adobe InDesign CS5.5 Application Language Files_AdobeInDesign7xAppLang-en_US: Install failed
ERROR: DW050: - Adobe Photoshop CS5.1 English Language Pack_AdobePhotoshop12-en_US: Install failed
ERROR: DW050: - Adobe Bridge CS5.1: Install failed
ERROR: DW050: - Adobe Photoshop CS5.1 Support: Install failed
ERROR: DW050: - Adobe InDesign CS5.5 Common Base Files: Install failed
ERROR: DW050: - Adobe Linguistics CS5.5: Install failed
ERROR: DW050: - Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All: Install failed
ERROR: DW050: - Adobe InDesign CS5.5 Application Base Files2_7.5.3.333_AdobeInDesign7xAppBase2-mul: Install failed
ERROR: DW050: - AdobeColorEU CS5.5: Install failed
