How to join anchor points precisely
Aug 12, 2012 6:28 AM
In the above image, I have four symmetrical corners of an ellipse which I'm trying to join together into one ellipse that is perfectly symmetrical. I am trying to line up the anchors perfectly (one corner at time) and then do a join, yet the result is always slightly off. I've been selecting the two points I want to join and using Path -> Average, then Path -> Join to do this, yet as mentioned it's not coming out precise. Does anyone know a better way to do this?
KiSS
    Aug 12, 2012 6:56 AM   in reply to kissfrito@yahoo.com
    Using the select tool and the "align to anchor point" setting, grab each of those paths by one of its endpoints and drag it onto the corresponding endpoint.
    or: use the align panel to do this, distributing a space of 0 between two shapes. See manual on how to select one object as a reference object when distributing.
    Aug 12, 2012 7:24 AM   in reply to kissfrito@yahoo.com
    Kiss,
    You may also use the View>Smart Guides and drag one Anchor Point over the other. When you are there (close enough to have it snap), they say anchor point.
    But if you have four (basically identical) segments they should fit easily. Are they identical?
    Aug 12, 2012 7:27 AM   in reply to kissfrito@yahoo.com
    It's in the View menu.
    Aug 12, 2012 3:07 PM   in reply to kissfrito@yahoo.com
    Kiss,
    You may, using the Align/Distribute palette/panel (Window>Align):
    0) If needed, under Align Objects select the two top quarters and Align>Vertical Align Top and select the two bottom quarters and Align>Vertical Align Bottom,
    Then under Distribute Spacing and with the Direct Selection Tool:
    1) Select the two top quarters, click the leftmost once more and Horizontal Distribute Space (with the default setting Auto), then select the coinciding end Anchor Points and Ctrl/Cmd+J (Smooth),
    2) Repeat (similarly) for the bottom pair,
    3) Select both halves, click the topmost once more and Vertical Distribute Space (with the default setting Auto), then select one set of coinciding end Anchor Points and Ctrl/Cmd+J (Smooth), then join the other set.
    Aug 13, 2012 7:07 AM   in reply to kissfrito@yahoo.com
    You are welcome, Kiss.
    Your version is undoubtedly newer.
