NSGirlHR
Presenter 8 not installing
Aug 6, 2012 7:21 AM
Tags: #version #8 #failed #installation #previous #presenter #installed
Bought the Elearning Suite 6 upgrade (for 2.5) and can't get Presenter to install.  Getting the warnings/errors listed below.  I double-checked and there's no reason I should be gettng the OS Requirements not met warnings.
I also tried the Presenter 7 clean-up fix I found via another forum and posted on the captivate FB page.  No go on that.  Can anyone help?
WARNING: DW066: OS requirements not met for {839EE07B-C129-11E1-B356-8B3C5B357670} Adobe Presenter Video Creator (32 Bit) 8.0.0.0
WARNING: DW066: OS requirements not met for {3E0D8981-D10C-4D8A-82EA-3D73834CEABF} Adobe eLearning Suite 6 6.0.0.0
WARNING: DW066: OS requirements not met for {B00674D5-C129-11E1-B356-EF8CA3116C83} Adobe Presenter 8 8.0.0.0
WARNING: DW066: OS requirements not met for {9E37FB0F-C129-11E1-B356-CCEAC4E44CC4} Adobe Presenter 8_AdobePresenter8en_USLanguagePack 8.0.0.0
----------- Payload: {5B1373CD-AF0F-11E1-A68F-9274728544BD} MultiSCOPackager 6.0 6.0.0.0 -----------
WARNING: DF035: CreateAlias:Icon file does not exist at C:\Program Files\Common Files\Adobe\Adobe Multi SCO Packager 6.0\MultiscoPackager.ico for icon C:\Documents and Settings\All Users\Start Menu\Programs\Adobe eLearning Suite 6\Adobe Multi SCO Packager 6.0.lnk with target C:\Program Files\Common Files\Adobe\Adobe Multi SCO Packager 6.0\multiscopackager.exe(Seq 4810)
----------- Payload: {839EE07B-C129-11E1-B356-8B3C5B357670} Adobe Presenter Video Creator (32 Bit) 8.0.0.0 -----------
ERROR: A previous version of Presenter has been detected. Please uninstall it before running installation again.
ERROR: DW030: Custom Action for payload {839EE07B-C129-11E1-B356-8B3C5B357670} Adobe Presenter Video Creator (32 Bit) 8.0.0.0 returned error. Failing this payload.
----------- Payload: {B00674D5-C129-11E1-B356-EF8CA3116C83} Adobe Presenter 8 8.0.0.0 -----------
ERROR: DW030: Custom Action for payload {B00674D5-C129-11E1-B356-EF8CA3116C83} Adobe Presenter 8 8.0.0.0 returned error. Failing this payload.
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050:  - Adobe Presenter Video Creator (32 Bit): Install failed
ERROR: DW050:  - Adobe Presenter 8_AdobePresenter8en_USLanguagePack: Install failed
ERROR: DW050:  - Adobe Presenter 8: Failed due to Language Pack installation failure
    Aug 6, 2012 8:54 AM   in reply to NSGirlHR
    Aug 7, 2012 6:13 PM   in reply to NSGirlHR
    I'm in the same position.  Just installed ELS 6 and it won't install Adobe Presenter no matter what I do.  Same error as Michael above.  It complains about a previous version of Presenter being detected, even though I've uninstalled all versions of Presenter from previous ELS installs and removed their folders from Program Files.
    So is there some kind of registry setting that does not get cleaned up when you uninstall Presenter that the ELS 6 installer is looking at?
    We need some one from the Adobe development team to resolve this one.
    Aug 8, 2012 8:29 AM   in reply to NSGirlHR
    I have the identical problem and cannot find a solution. I can "see" the original eLearning Suite on my programs list within the control panel, but when I run uninstall from there the Adobe uninstall program begins, but shows no components available to uninstall. So I'm stuck as well not able to install Presenter 8.
    Aug 8, 2012 5:51 PM   in reply to Bob Mack 94536
    The issue seems to be due to some Registry keys for Presenter 7 that don't get cleaned up properly by its uninstaller.
    One of the Adobe techs helped me with it last night.  Expect a blog post about how to fix this very soon.  Please be patient.
    Aug 13, 2012 8:07 AM   in reply to RodWard
    Did you find a resolution Rod? I just installed the eLS6 upgrade this weekend and experienced the same error. I don't have eLS 2.5 installed but do have eLS 2.0...and had done some upgrades Presenter directly as well a few months ago (don't recall details, but some bug fix upgrade, I believe, that took some maneuvering...)
    Looking forward to the blog post, and I'll echo it
    Aug 13, 2012 8:56 AM   in reply to Erik Lord
    It seems that you can't have Presenter 7 and Presenter 8 installed on the same machine.  So Presenter 7 (all versions of it) have to be completely uninstalled BEFORE you will be able to install Presenter 8 and its related components from the ELS 6 package.
    Since Presenter 7 also came with ELS 2 you may need to ensure that you've used the uninstall procedure for ELS 2 to try and get rid of that version of Presenter 7.  I think in my case part of the problem was that I had originally installed Presenter 7 with ELS 2.0 (or was it ELS 1.0...can't remember) and then also installed a slightly updated version of Presenter 7 with ELS 2.5.  Somehow all of these different versions left their mark in the Registry and, even once they were uninstalled there were some traces of the program left behind, which led the ELS 6.0 installer to believe it could not install Presenter 8.
    The Adobe technician that helped me provided a REGEDIT file that cleaned out the references to Presenter 7.  Then I was able to open up the ELS 6 installer again and finally install Presenter 8.
    I believe this registry edit file is now available for download from the Adobe blog. You may have to search for it.
    Aug 14, 2012 5:53 AM   in reply to RodWard
    I can confirm that I had similar error messages.  I have just unistalled Presenter 7, and then installed Presenter 8 with no problems.
    Aug 16, 2012 11:28 AM   in reply to NSGirlHR
    Hi There,
    Can you please follow this blog download the uninstaller and then try to install the Presenter 8, please let me know if that helps.
    http://blogs.adobe.com/captivate/2012/08/resolution-adobe-presenter-8- installer-issue.html
    Priyank
    Oct 22, 2012 4:43 PM   in reply to NSGirlHR
    For anyone else struggling with this issue as I was, here's what worked for me (as detailed here, thanks to Mukul and mvasic1):
    1. Open Registry Editor and navigate to HKEY_LOCAL_MACHINE > SOFTWARE > Wow6432Node > Adobe > Presenter (or for 32 bit, HKEY_LOCAL_MACHINE > SOFTWARE > Adobe > Presenter)
    2. Rename the '7.0' folder to something like '7.0-old'
    3. Attempt to reinstall Presenter 8, it should work.
    Feb 13, 2013 7:31 AM   in reply to ejwn
    Neither Priyank or Ejwn's solutions worked for me.  When I open the Registry, I do not have 7.0 folder.  Yet when I try to install Presenter 8, I am told an older version is there.
    Feb 14, 2013 12:57 PM   in reply to Nealf21
    Here is what finally worked.
    I ran the reg files above.
    I deleted all the folders and files related to Presenter 7 or 8 in
    C Drive> Users > Your User Name>App Data > Local > Adobe >
    and App Data > Roaming > Adobe >
    I uninstalled office 2010, rebooted, the reinstalled office 2010, and rebooted again. I uninstalled eLearning Suite, rebooted, then reinstall eLearning Suite 6 and rebooted again.
    When I opened PowerPoint, I still did not have Presenter. However, I have been checking each time to see if the add-in was disabled. I found the Presenter add-in was installed but disabled.
    I re-enabled the Presenter add-in.  Now Presenter seems to be working.
    Feb 17, 2013 1:14 PM   in reply to Nealf21
    Thank you for posting your solution, Nealf21, I'm sure it will come in handy for others!
