Ok I understand that Acrobat X is not supported directly with the AAMEE tool.
All the documentation states that you can use the Acrobat customization tool if needed, just so long as you don't serialize with it (makes sense, it should use the CS Suite serial and licensing). Though they also mention to use the same serial as the CS suite in some docs.
My question is can I use the same package+commandline for Adobe Acrobat X, that AAMEE produced when I built a package for say Design Standard Suite, with the other CS suites?
From what I understand, Acrobat X does not have a serial on its own (I also don't see the CS suite serial in any of the XMLs or msi code). Once it installs (or first run after CS install) it find the suite code and activates itself.
If my assumption is correct, in theory it would use what-ever serial code the installed CS suite used... and that I could use the same acrobat install for ALL the CS suites, rather then build a acrobat x install for each suite indivitually...
Thoughts?
Thanks for the input on that Dandirkmn. We may look at changing the prominence. So far most of the posts in the Creative Suite Enterprise Deployment forum though have been very much on topic. But increasing the capability of discovery might be useful if I see a high number related posts in the Download, Installation, and Setting up Forum.
