How can I turn OFF audio monitoring during capture from tape?
Aug 13, 2012 3:22 AM
FCP has a very useful check box that allows you to turn off audio monitoring during capture, so you can listen to other things whilst the batch captures.  Is there any way to do this in PP?  If not, how can I make a feature request?
I'm using PP CS6.
Thanks for any help.
Dominic
    Aug 13, 2012 7:12 AM   in reply to Dominic Witherow
    In your capture window you need to click "edit" over to the right side. Then you need to uncheck both preview audio boxes and you're ready to roll
    Aug 13, 2012 9:06 AM   in reply to Dominic Witherow
    Don't know if the Mac OS offers similar, but when capturing on a PC, I bring up the "Audio Mixer" tool in Windows and it shows a separate slider for PREMIERE and I just bring that down to silence so I can watch NetFlix or whatever without hearing the capture audio. Does not affect the volume of what I am capturing in Premiere, just mutes it out to my speakers.
    Jeff Pulera
    Aug 13, 2012 9:54 AM   in reply to Dominic Witherow
    I left out one part sorry.  After you click edit and you have it on the exact device you want to capture from, then you need to click the settings box to the right then the following box I show in the picture should appear.
    Aug 13, 2012 11:14 AM   in reply to Dominic Witherow
    The only other solution I can offer is to go to "edit" "preferences" then select "playback". Under playback set the default audio device to your capturing device instead of the adobe desktop audio. This will allow you capture but not have to listen to whats being captured. However once it's done capturing you'll have to set it back to adobe desktop audio otherwise you can't hear what you're editing in your timeline.
    Aug 13, 2012 1:21 PM   in reply to ComputerNovice25
    Nor do I have these settings.
    Do you have a capture card of some sort installed?
    I have never been able to turn of the sound while capturing.
    I do not have any 3rd party card installed.
    Aug 13, 2012 1:54 PM   in reply to Ann Bens
    I'm just using my computers built in firewire port to capture from a DVC-Pro deck and also my older HDV camera.  Although I rarely use them now that I have newer cameras that are totally file based.
    Aug 13, 2012 2:24 PM   in reply to ComputerNovice25
    Then it must be the deck.
    Aug 13, 2012 3:13 PM   in reply to Ann Bens
    That setting has been there for me in every version of PP since it became Premiere Pro (and possibly before), regardless of computer or camera used for capture.
    (Note that a device must be hooked up and active for the option to appear.)
    Aug 14, 2012 4:31 PM   in reply to Dominic Witherow
