I need a script that would let me place an image in a template opening. I would like it to open a directory to choose the file to insert, resize it to fit the template opening, but keep it as a smart object so that it can be resized if necessary. I found this in this thread http://forums.adobe.com/message/3329062 and http://forums.adobe.com/thread/455645 and it seems to fit the bill but I cannot find any script that uses it. Can anyone direct me to something? Thanks.
Stdlib.insertImageIntoSelectionAsSmartObject(doc, layer, im, fit)
Yes, I have his folder of scripts. He has a script called InsertImage.jsx but that only resizes and places the image into the template. It doesn't come in as a smart object so that I can resize it, and it doesn't adjust if the template opening is square. So if I'm trying to insert a horizontal image in the opening it inserts it with the longer dimensions filling the sides of the square instead of the tob/bottom.
You could look at my Photoshop Photo Collage Toolkit
Photo Collage Toolkit UPDATED June 12, added Picture Package Support via PasteImageRoll and BatchPicturePackage scripts.
The package includes four simple rules to follow when making Photo Collage Template PSD files so they will be compatible with my Photoshop scripts.
There are eleven scripts in this package they provide the following functions:
Note : there are Bugs in CS6; Do not set your Pfererence to edit in Floating windows leave the option "Open documents in Tabs" checked You must Also set your Photoshop Preferences Interpolation to something other then Photoshop's default "Bicubic Automatic" for adobe failed to add code for that change in to scripting. If set to "Bicubic Automatic" when my scripts try to retrieve the interpolation preference a Photoshop internal error happens.
I had actually looked at your work first but it was more of an interactive set of panels from what I can tell. I just wanted to work one image at a time.
DesiredWorkflow:
Open Template
Click on One opening
Click on Insert action script, pick photo
Photo is inserted as smart object for possible resize.
Rince and Repeat.
Would something from your set work for me?
IMO Yes and give you more options to boot.
What you want to do is more or less what the interactive populate collage script does. There is one difference the script picks the opening hihjlights the opening to be populated then put you in an image selection dialog when you select the image the script places the image into the opening transforming it to fit. Then it puts you in an interactive transform on the picture so you can tweak the transformed placement.
Video Interactively Populated a Photo Collage Template
Message was edited by: JJMack
The Script Dialog what you call a panel let you choose the Template to open and populate and to set optons like Stamp File names in the images where the stamp should be on the image and if a text layer styles should be added to the text layers also wether or not to add a layer styles to the smart object images layers.
Gave the scripts a try this morning and unfortunately my templates are set up differently than yours so I get some error messages when using the scripts.
1. The script is looking for a background layer and most of my templates do not have them.
2. The script is looking for Alpha Channels and my templates do not use them, but rather there is a layer for each opening.
3. I opened one of your templates and when I ran a script I got an error about not finding the My Picture folder. It still will allow me to choose an image but I have to hit OK first for the script to continue. The script works great if I had mine set up the same way but that would take a long time to convert all of them.
Not sure if I can change the script to work with layer openings and not Alpha channels.
Your templates most likely can be made compatable with my scripts. A backround layer is required but it dose not have to be visible. Its required for my script want to place in images above it and know they are just above the bottom layer. Your templates must likely have layer mask or cutouts for images. All you need do is to make a selection that represents the size placement and shapes of your collage's images and save the selections as alpha channels named "Image 1", "Image 2" ... "Image N"
Post one of your PSD template files I'll have a look to see if they are easy to be made compatable with my scripts I find most templates are easy to be made compatable. It would be way easier to make templates compatible then to program scripts to populate the kind of templates you now use. There are only four simple rules templates need to use.
There is also an outside chance that the script LayerToAlphaChan.jsx - Used to convert a Prototype Image Layer stack into a template document. may be able to help make alpha channels for you.
As for the starting folders for images and templates they can be anywhere there are hard coded variable in the scripts that you can change to suite your environment. All is spelled out in the help documentation.
the scripts start with a section like this the last two vars are the defailt template and image paths.
///////////////////////CUSTOMIZE Here////////////////////////////////////////////
// Some Hard Coded variables that some day I may put into the dialog options area
var imageStyleList = ['Default Style (None)','Photo Collage Style 1','Photo Collage Style 2','Photo Collage Style 3','Photo Collage Style 4','Photo Collage Style 5','Photo Collage Style 6','Photo Collage Style 7','Photo Collage Style 8','Photo Collage Style 9'];
var imageStyleDefault = 0; // imageStyleList index number
var textSizeFactor = 4; // > 1 scales down text size
var textFont = "ArialMT"; // Photoshop internal font name
var textAngle = -10; // center text angle
var textColor = new SolidColor; // text color
textColor.rgb.red = 255;
textColor.rgb.green = 255;
textColor.rgb.blue = 255;
var textStyleList = ['Default Style (None)','Shiny Metal','Shiney Metal No Stroke','Strong Metal','Strong Metal No Stroke','Clear Emboss - Inner Bevel','Clear Emboss - Outer Bevel','JJMack Overlay'];
var textStyleDefault = 0; // textStyleList index number
var textLocationDefault = 7; // text Location Default Bottom Center
var templateFolder = "C:/Program Files/Adobe/Adobe Photoshop Templates/";
var imagePath = "~/My Documents/My Pictures/";
// End hard coded variables
If the script LayerToAlphaChan.jsx is able to convert your image layers to alpha channels there is a script in my crafting actions package that could be used to add background layer to templates that do not have background layers.
Crafting Actions Package Contains
The script named SelectBackground.jsx you may be able to record a Action that uses SelectBackground.jsx followed by LayerToAlphaChan.jsx Then batch that action to convert your templates in your Template folder to compatible templates in a new Template Folder.
SelectBackground is a very siimple script
// A Script by JJMack's Designed for use with Custom Mat Actions
// This script targets the background if there is one or
// adds a new tageted background layer if there wasn't one.
// This script is supplied as is. It is provided as freeware.
// The author accepts no liability for any problems arising from its use.
<javascriptresource>
<about>$$$/JavaScripts/SelectBackground/About=JJMack's Select Background.^r^rCopyright 2009 Mouseprints.^r^rScript utility for action.^rNOTE:Select Background adding one if need be!</about>
<category>JJMack's Action Utility</category>
</javascriptresource>
// enable double-clicking from Mac Finder or Windows Explorer
#target photoshop // this command only works in Photoshop CS2 and higher
// bring application forward for double-click events
app.bringToFront();
// ensure at least one document open
if (!documents.length) {
alert('There are no documents open.', 'No Document');
// if at least one document exists, then proceed
else {
main();
// main - main function
function main() {
try {
// declare local variables
var layers = activeDocument.layers;
activeDocument.activeLayer = layers[layers.length-1] // Target Bottom Layer
if ( activeDocument.activeLayer.isBackgroundLayer ) { return; } // quit
app.activeDocument.artLayers.add()
var newlayers = app.activeDocument.layers;
// arrange layers so new layer added is at bottom
newlayers[0].move(newlayers[newlayers.length-1], ElementPlacement.PLACEAFTER);
// Make it a Background Layer
activeDocument.activeLayer.isBackgroundLayer=1
// display error message if something goes wrong
catch(e) { alert(e + ': on line ' + e.line, 'Script Error', true); }
You need to upload PSD to a site for sharing files you can also e-mail one as an attachment jjmacks@hotmail.com
Sent you e-mail with attachments an Action, a Script and a link to your sample template. If you reverse the stacking order of your image layers before doint the conversion tmahes will pe populated from left to right. The way it is now images will be populated right to left.
Images are populated above the background layer from the botton layer to the top image layer in the layer stack.
Thanks for your undying efforts on this. I downloaded the script and action, and added them to my actions and scripts folder, then put the action in the action pallet. For some unknown reason the action is there but when I click to open the action steps there are no scripts where the script steps are. Any idea what's going on? I loaded some other actions earlier today and the same thing happened, no scripts where the script step is. I have the scripts in the scripts folder and could add them manually but I'm not sure which two scripts you put in the action. This is Photoshop CS3 ver 10.0.1
Adobe changed the was script are recorded in newer versions of photoshop. You will need to record the twi steps on your CS3
In the Actions in the action palette in the action you should see a Stop step followev by two script steps. Highlight the two script steps and drage them to the trash can in the Actions palette.
Open one of your template files the in the Actions Palette highlight the Convert Template action and click the Play button. The Action shouls play and stop after you click the stop button the delete current layer step should be highlighted. Hihglight the Stop step above it instead.
The click on the record button.
Use menu File>Scripts>SelectBackground
Use menu File>Scripts>LayerToAlphaChan
click on the stop recording icon in the action palette
Highlight the ConvertTemplate action set
Use the Actions Palette fly-out menu iten Save Action
save the action set the action set should now work ou ypour CS3 system
Thing are backwards compatible it hard to make programs forward compatible for its has not been programmed yet. That is your case CS3 is not forward compatible with cs5. I had created the action with CS5.
I like CS5 way for I can install scripts in my script tree and link all Photoshop versions script folder to my install tree. That way all version of Photoshop the will look for Script by name will work.
However CS2 and CS3 where my scripts will also work from the scripts menu if used in actions need to be recorded in actions in CS2 or CS3. The Scripts location must never change and they must be install in the same location on all Machines. For CS2 and CS3 action player will not look for scripts by name they expect the scripts full path to be recorded in the action step..
There is more flexability the new way actions work. The Script are normally used from menu File>Scripts>List Script Name. Therefore scripts can be installed anywhere on one's system and as long as the location in linked into Adobe Photoshop Script Path they will be listed in the Scripts List by name and findable. Enen in actions recorded in CS4,5 or 6.
