CPetty99@gmail.com
Moving books from one EReader to another.
Aug 10, 2012 11:08 PM
I am trying to put some books from a Sony e-reader to a Nook Color and it had me download Adobie Reader. When I try to move the books it tells me it has to be authenacated but wull not accept my information. How do I get this fixed?
    Aug 13, 2012 11:55 AM   in reply to CPetty99@gmail.com
    Moving this discussion to the Adobe Digital Editions forum.
    Aug 13, 2012 3:45 PM   in reply to Jeff A Wright
    The original message was:
    this fixed?
    It's hard to tell from the message just how you're going about this, but I
    will assume that you're trying to do the transfer via a Windows computer,
    and that's where you downloaded and installed ADE.  I'm not sure how the
    ebooks were downloaded to the SONY ereader, so let me assume that it was
    done through the Sony Reader Library, direct from SONY.  Finally, I'm not
    sure whether the Nook Color told you that you needed to download and
    install ADE - or whether it did so from the B&N website or from your
    computer.
    These pieces of information are critical in giving you the right answer.  I
    could write a small book on what to do, but without some grounding in what
    your environment is, and how you've downloaded ebooks before, I think that
    would not be a good idea.
    Can you fill in more of the story?
    Aug 13, 2012 6:30 PM   in reply to CPetty99@gmail.com
    If I read between the lines, you have a PC and you've 'moved' an ebook from
    the SONY ereader to your computer, implying that you downloaded it onto the
    SONY ereader from somewhere else (the SONY Reader Store?).  You have
    downloaded and installed ADE.  Let's start there.
    The proper process to follow is to obtain an Adobe ID when or before you
    download and install ADE.  That ID will be associated with all ebooks that
    are downloaded to ADE after it's installed.  Those that have been
    downloaded beforehand can be problematic, but I think we'll be OK.  If you
    did not obtain an Adobe ID, then you should go to the Adobe website and do
    that by registering with Adobe.  No charge, and no tracking either - just
    an ID.  I am going to assume that you registered your ereaders with SONY
    and B&N respectively, so that they are activated (which sounds like they
    are).
    Next up is understanding what ADE is going to do for you and how.  It's a
    library management system and a control program for digital rights
    management of ebooks you have or get.  It's close to the industry standard
    for individuals to use for ebooks, so lots of sites 'require' that you use
    it.  SONY and B&N don't - you can use their library management software to
    do the work if you want to.
    The transfer....  Both of the ereaders must be recognized by ADE in order
    to do the transfer.  It works like this:
    Once the copy of ADE is authorized with your Adobe ID, then you can shut it
    down, then attach the ereader to your computer  Your computer should
    recognize it and give it a drive letter - which sounds like it's happened
    when you transferred the ebook from the SONY.  Look at the screen on the
    ereader to make sure that it's connected properly - you'll see messages
    that say it is.  Then, start up ADE.  When ADE starts in Library mode, it
    should show the SONY on the bookshelf - the left hand side of Library
    view.  if it does, then you can open the SONY and  drag and drop ebooks
    from it to your computer.  ADE will enter them into your library and make
    them available to you.  When you've finished dragging over all the ebooks
    you want to, you need to disconnect the ereader LOGICALLY before you pull
    the plug out of the computer.  You do this through the utilities on your
    computer.  Go to the lower right hand part of the START bar and you should
    find a small computer icon.  Click on that and you'll get a message that
    you can 'safely remove' the drive letter that represents your SONY.  Do
    that, and watch the screen.  It should change and tell you that it's
    processing new information.  When it's finished, then unplug it from the
    computer.
    Now for the other part.  Close ADE and plug in the Nook Color.  Go through
    the same process - watch the displays and the messages from your computer
    to make sure that the Nook is recognized and ready to use.  Then, start
    ADE, and you should see the Nook on the bookshelf, where the SONY was, and
    the Nook's screen should show it as connected.  Now, reverse the process:
    drag the ebook title from ADE's Library onto the Nook.  When you're done,
    follow the disconnect process above.
    If you hit any glitches or if something else doesn't work, just come back
    here and we'll figure it out.
    Nov 5, 2012 5:37 PM   in reply to Frustrated in AZ
    I am having the same issue. I have 400+ books on my Sony Reader account. I followed the instructions above to load three of those books in ADE, then copy them to my new Nook Color. Now when I try to read those books on the Nook Color, I get an error message that says, "Error Dialog. Sorry, cannot open this book". What do I have to do to access those ebooks on my NC?
