hi
i have problem here because iam confusing between these things , i know that visible property has to values true and false , and addchild is another thing because when you have two objects
then you put object 2 in object1 and i it will have its own x,y postion depend on that object , and object 1 is child for the main stage , but here is the problem
i.ve opened discuss before this
http://forums.adobe.com/message/4615780#4615780
and when i remove the child , its effect will be there ?? on the stage !! it is like hiding object
? so iam very confuse now , also if removechild doesn,t remove the object from existing then how can i remove it??
thank you and i hope you guys get what imean in my question
please check this link (my old discuss)
thank you
if you want to destroy a display object, remove it from the display list, remove all listeners and object references and null the object. for example,
bat1.parent.removeChild(bat1); // if bat1 is in display list
bat1.removeEventListener(Event.ENTER_FRAME,f); // if this listener was previously added
batArray.splice(batArray.indexOf(bat1),1); // if bat1 is in the array batArray
bat1=null;
thx , i did all these steps but in the bat still exist
look
1- remove it from display list
in the main class
if (hero.hitTestObject(portal3)){
var map4:BACKGROUND = new BACKGROUND
if(bat1.stage){
removeChild(bat1)
bat1.removeEventListener(Event.ENTER_FRAME, onEnterFrame);
2-remove it from the display list, remove all listeners and object references and null the object.
in the bat1 class
private function onRemovedFromStage(event:Event):void
removeEventListener(Event.ADDED_TO_STAGE, onAddedToStage);
removeEventListener(Event.REMOVED_FROM_STAGE, onRemovedFromStage);
null;
trace("bat removed");
thank you
here
if(bat1.stage){
removeChild(bat1)
bat1 = null;
but i get these thing after getting to the portal
TypeError: Error #2007: Parameter hitTestObject must be non-null.
at flash.display::DisplayObject/_hitTest()
at flash.display::DisplayObject/hitTestObject()
at MAIN/onEnterFrame()
thank you for your replay
the last thing you do is null bat1:
var map4:BACKGROUND = new BACKGROUND();
if(bat1){
removeChild(bat1)
bat1.removeEventListener(Event.ENTER_FRAME, onEnterFrame); // this doesn't need to be done unless you added a listener outside the Bat1 classs
bat1 = null;
maybe , am gonna delete all the classes and doing all the game in the main because i get enough of errors
thank you alot kgald but is if(bat1) mean that bat 1 on the stage and if it is yes , what the deffrent between it andif(bat1.stage) because they look the same they both have to values true and false
thx again
