ucantbeserious7
Does anyone know how to achieve this in Photoshop? Any help is appreciated, thanks.
Aug 11, 2012 8:36 PM
Tags: #photoshop #cs5
Hello,
I'm relatively new to Photoshop so if you know how to do this, please explain by telling me where I click. E.g. File>Open
Does anyone know how I would achieve this exact effect in Photoshop in the image above (without the circular logo)? The 2 light blue type of effects, one at the top of the image, the one at the bottom of the image. I don't know how to achieve this effect, please show me if you know how. I'm using Photoshop CS5.
I have looked through hundreds of tutorials, none provide me any clue as to how this is achieved.
Or does anyone know a tutorial on how this effect is achieved?
Thank you for your help.
  • Noel Carboni
    Dec 23, 2006
    Aug 11, 2012 8:47 PM   in reply to ucantbeserious7
    I guess that's not too terribly different than my avatar.
    Look for online tutorials about how to make a "Gel Button".
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Aug 11, 2012 10:00 PM   in reply to ucantbeserious7
    Well then, I guess I have no idea how to do that.
    -Noel
  • Noel Carboni
    Dec 23, 2006
    Aug 12, 2012 4:51 AM   in reply to ucantbeserious7
    Sorry, I had to sleep.
    I just created a solid blue canvas then painted over it with a soft brush set to a very low flow and set to Linear Dodge and later Lighten, and painted in the highlights.  Sometimes low tech can be the answer for a one-off project.
    It can help to work at a size larger than your final needs, then downsample the image later.
    It's possible the Layer styles could be used to help achieve this - it does have some aspects of a soft inner bevel.
    -Noel
    Aug 13, 2012 12:19 AM   in reply to ucantbeserious7
    Teaching you Photoshop from the ground up far exceeds what can be accomplished (or expected) within the scope of a user to user forum.
    If you can't follow the instructions you have been given, you have a lot of reading and studying to do.
    Photoshop is a professional level application that makes no apologies for its long and steep learning curve.
    Try the video tutorials at lynda.com, or a book such as "Photoshop Classroom in a Book", etc.  Also Google for tutorials Photoshop.  Take a class at your local community college.
    Aug 14, 2012 2:34 AM   in reply to ucantbeserious7
    ucantbeserious7 wrote:
    Hello,
    …however I'm not asking to be taught Photoshop from the ground up, where did I say that in my post? I can't quite see where I requested that, sorry if I can't see, please show me…
    Sure.  In post #6, you wrote:
    Would you be able to show me how you set a 'very low flow', and what do you set to 'linear dodge'? How do you lighten it and paint in the highlights?
    Anyone who has to ask those basic questions needs to learn Photoshop from the ground up.  If not, you would have been able to follow Noel Carboni's directions right away, with no trouble.  There's a minimum due diligence expected from all of us.  In this case, you can start by reading up on the Brush tool in the Photoshop Help files.
    Please understand that I'm not putting you down.  I'm pointing out that you have a lot of learning to do, and I made some suggestions as to where to start.
    Aug 14, 2012 2:47 AM   in reply to ucantbeserious7
    Incidentally, your confrontational attitude is not helpful to you.  The last line of your post #2 is insulting to the poster who had just offered you help.
    The tone of your post #8 required some restraint on my part before I could compose post #9.
    Please read this FAQ for advice on how to ask your questions:
    http://forums.adobe.com/thread/419981?tstart=0
  • PECourtejoie
    Jan 11, 2006
    Aug 14, 2012 3:28 AM   in reply to ucantbeserious7
    Yes, it would have been faster and more constructive to point out exactly where to find information rather than scold you.
    Check out the Option bar that one gets under the Menu bar. If it is not showing, go to windows>Options.
    More info: http://helpx.adobe.com/photoshop/using/tools.html#using_the_options_ba r
    If you select the brush tool, you will notice a flow value, that you can lower; and a Mode drop down list.
    paint tool options: http://helpx.adobe.com/photoshop/using/painting-tools.html#paint_tool_ options
    Set the mode to Linear Dodge, then for the next stroke set it to lighten.
    Blending modes explanations with links about their effects http://help.adobe.com/en_US/photoshop/cs/using/WSfd1234e1c4b69f30ea53e 41001031ab64-77eba.html
    Have fun learning Photoshop!
  • PECourtejoie
    Jan 11, 2006
    Aug 14, 2012 3:34 AM   in reply to ucantbeserious7
    You are very welcome.
    Remember to pay it forward, and help others when you can!
    Aug 14, 2012 3:44 AM   in reply to ucantbeserious7
    PECourtjoie is right.  I apologize for having responded to your posts at all.  My bad.
