The C-level API
Aug 14, 2012 2:05 AM
    Aug 14, 2012 2:05 AM   in reply to Community Help
    the fourth param of JS_ExecuteScript() function should mean the length of the string, not in bytes.
    Nov 20, 2012 11:08 AM   in reply to ScreenNameIsWhat
    Thanks for the tip. This will be fixed in the next release of Flash Pro docs.
    Randy Nielsen
    Senior Content and Community Manager
    Adobe
    Feb 10, 2013 3:16 PM   in reply to Community Help
    JS_ExecuteScript is implemented incorrectly. The conversion:
    (LPCTSTR)__FILE__
    is incorrect.
    First off __FILE__ generates C-string constant, not a unicode one. Then if the application is a unicode one, LPCTSTR stands for LPCWSTR which stands for unsigned short*.
    Converting char* (__FILE__) to unsigned short* is absolutely wrong.
    In the case of a non-unicode application, the LPCTSTR is translated to LPCSTR which is a char, but the function needs unsigned short.
    The way to do this is:
    (unsigned short *) T(_FILE__)
    I am not sure whether _T(...) will convert __FILE__ to unicode in the case of an ANSI application - I presume not.
    I've made a sample Unicode C-level extension dll in which I added and registered a function that calls JS_ExecuteScript. I called the dll's function from a test jsfl command.
    I had some error with the script that I tried to call with JS_ExecuteScript, and Flash warned me about an error in my script. The file name was displayed in Chinese letters
    because of the wrong conversion from char* to unsigned short*.
    #define JS_ExecuteScript(c, o, s, z, r) \
        (mmEnv.executeScript  ? (*(mmEnv.executeScript))(c, o, s, z, (unsigned short *) T(_FILE__), \
            __LINE__, r) : JS_FALSE)
    Feb 11, 2013 5:40 AM   in reply to Community Help
    • unsigned short *JS_ValueToString(JSContext *cx, jsval v, unsigned int *pLength) */
    #define JS_ValueToString(c, v, l) \
        (mmEnv.valueToString  ? (*(mmEnv.valueToString))(c, v, l) : (char *)0)
    Should be:
    /* unsigned short *JS_ValueToString(JSContext *cx, jsval v, unsigned int *pLength) */
        (mmEnv.valueToString  ? (*(mmEnv.valueToString))(c, v, l) : (unsigned short *)0)
