JdeB_721
How Much RAM
Aug 13, 2012 6:21 PM
Tags: #how_much_ram
i recently installed adobe creative suite 6 design and web premium, and I am unable to use it as after a short time of working on files, I get a message that it does not have enough RAM.  How much RAM is needed to use this application?  i am working on windows 7, 32 bit.
I don't know if this is the correct place to get answers, but I have just spent an hour trying to find out how to contact Adobe to find this out, and 30 minutes holding on the 800 number listening to elevator music, which finally cut off.
thanks
Joanne
    Aug 14, 2012 3:04 AM   in reply to JdeB_721
    Which programs do you use? Illustrator and Photoshop can be quite memory hungry, yes. Anyway, I'd consider it a moot point in your case - on a 32bit operating system there is simply no way to handle more than 2.7GB RAM for either of the apps. Only upgrading to a 64bit OS and then using the 64bit versions of those programs will improve matters. Still, even then there may be other issues...
    Mylenium
    Aug 16, 2012 2:29 PM   in reply to JdeB_721
    Joanne,
    Windows uses RAM for varioius processes and aslo pages memory to your hard disk as needed. How many programs are you using at one time? Do you have any background processes in use? How much free hard disk space is available.
    Aug 18, 2012 9:14 PM   in reply to JdeB_721
    JdeB_721 wrote:
    I have 4G RAM.
    As Mylenium has already indicated, with a 32-bit OS you can only use a bit more than half of your memory.
    How large is your Virtual Memory (page file)?
    Aug 19, 2012 6:19 PM   in reply to JdeB_721
    Re-reading your earlier posts indicates that you can open the program fine, but working with files will produce the error after a while.  Can you watch the memory usage with the Task Manager (Processes tab)?
    How much memory does PS use when opened by itself?
    How much memory does it use when you open several image files?
    How much memory does it use when you close some or all of these files?
    I just opened PS, and it used about 100MB.
    Then I opened a moderate-sized image, and memory doubled to 200MB.
    I opened another image and memory went to 300MB.
    Then I closed all images, and the memory used was not reduced in any way.
    When reopening these files, memory increased again, although not the same level as originally.
    This indicates some sort of memory leak; memory not released when no longer used.
    Is this the same that you observe?  How high does your memory usage go before you receive an error?
    P.S. your Virtual Memory settings are fine; I just wanted to make sure that they were not set to something too low.
