the deffrent between children and visibles objects
Participant ,
Aug 14, 2012 Aug 14, 2012
hi
i have problem here because iam confusing between these things , i know that visible property has to values true and false , and addchild is another thing because when you have two objects
then you put object 2 in object1 and i it will have its own x,y postion depend on that object , and object 1 is child for the main stage , but here is the problem
i.ve opened discuss before this
http://forums.adobe.com/message/4615780#4615780
and when i remove the child , its effect will be there ?? on the stage !! it is like hiding object
? so iam very confuse now , also if removechild doesn,t remove the object from existing then how can i remove it??
thank you and i hope you guys get what imean in my question
please check this link (my old discuss)
thank you
ActionScript
2.0K
Community Expert , Aug 14, 2012 Aug 14, 2012
that error is not from the code i suggested.  somewhere in your code you're trying to reference bat1 after it is nulled.
use an if-statement to prevent that.
if(bat1){
if you want to destroy a display object, remove it from the display list, remove all listeners and object references and null the object.  for example,
bat1.parent.removeChild(bat1);  // if bat1 is in display list
bat1.removeEventListener(Event.ENTER_FRAME,f);  // if this listener was previously added
batArray.splice(batArray.indexOf(bat1),1);  // if bat1 is in the array batArray
bat1=null;
Participant ,
thx , i did all these steps but in the bat still exist
look
1- remove it from display list
in the main class
if (hero.hitTestObject(portal3)){
      var map4:BACKGROUND = new BACKGROUND
      if(bat1.stage){
     removeChild(bat1)
     bat1.removeEventListener(Event.ENTER_FRAME, onEnterFrame);
2-remove it from the display list, remove all listeners and object references and null the object.
in the bat1 class
private function onRemovedFromStage(event:Event):void
   removeEventListener(Event.ADDED_TO_STAGE, onAddedToStage);
   removeEventListener(Event.REMOVED_FROM_STAGE, onRemovedFromStage);
   null;
   trace("bat removed");
thank you
no, you didn't.  where is bat1=null??
putting null; on a line by itself in your Bat1 class does nothing.
Participant ,
here
      if(bat1.stage){
     removeChild(bat1)
     bat1 = null;
but i get these thing after getting to the portal
TypeError: Error #2007: Parameter hitTestObject must be non-null.
at flash.display::DisplayObject/_hitTest()
at flash.display::DisplayObject/hitTestObject()
at MAIN/onEnterFrame()
thank you for your replay
the last thing you do is null bat1:
      var map4:BACKGROUND = new BACKGROUND();
      if(bat1){
     removeChild(bat1)
     bat1.removeEventListener(Event.ENTER_FRAME, onEnterFrame);  // this doesn't need to be done unless you added a listener outside the Bat1 classs
     bat1 = null;
Participant ,
i copied it then i paste in my code but the errors still!
thank you again for your replay
if(bat1){
Participant ,
maybe , am gonna delete all the classes and doing all the game in the main because i get enough of errors
thank you alot kgald  but is if(bat1) mean that bat 1 on the stage  and if it is yes , what the deffrent between it andif(bat1.stage) because they look the same they both have to values true and false
thx again
if(bat1) means is bat1 not null.  ie, before you null bat1 the code within the if-statement (your hittest) will execute.  after you null bat1, that code will not execute and that will prevent the 2007 error.
if(bat1.stage) checks if bat1 is in the display list.
Participant ,
thanks alot kgald
you're welcome.
