the deffrent between children and visibles objects
Aug 14, 2012 2:09 AM
hi
i have problem here because iam confusing between these things , i know that visible property has to values true and false , and addchild is another thing because when you have two objects
then you put object 2 in object1 and i it will have its own x,y postion depend on that object , and object 1 is child for the main stage , but here is the problem
i.ve opened discuss before this
http://forums.adobe.com/message/4615780#4615780
and when i remove the child , its effect will be there ?? on the stage !! it is like hiding object
? so iam very confuse now , also if removechild doesn,t remove the object from existing then how can i remove it??
thank you and i hope you guys get what imean in my question
please check this link (my old discuss)
thank you
  • kglad
    Jul 21, 2002
    Aug 14, 2012 2:50 AM   in reply to thunderxlight11111
    if you want to destroy a display object, remove it from the display list, remove all listeners and object references and null the object.  for example,
    bat1.parent.removeChild(bat1);  // if bat1 is in display list
    bat1.removeEventListener(Event.ENTER_FRAME,f);  // if this listener was previously added
    batArray.splice(batArray.indexOf(bat1),1);  // if bat1 is in the array batArray
    bat1=null;
  • kglad
    Jul 21, 2002
    Aug 14, 2012 3:21 AM   in reply to thunderxlight11111
    no, you didn't.  where is bat1=null??
    putting null; on a line by itself in your Bat1 class does nothing.
  • kglad
    Jul 21, 2002
    Aug 14, 2012 3:51 AM   in reply to thunderxlight11111
    the last thing you do is null bat1:
    if (hero.hitTestObject(portal3)){
          var map4:BACKGROUND = new BACKGROUND();
          if(bat1){
         removeChild(bat1)
         bat1.removeEventListener(Event.ENTER_FRAME, onEnterFrame);  // this doesn't need to be done unless you added a listener outside the Bat1 classs
         bat1 = null;
  • kglad
    Jul 21, 2002
    Aug 14, 2012 4:02 AM   in reply to thunderxlight11111
    that error is not from the code i suggested.  somewhere in your code you're trying to reference bat1 after it is nulled.
    use an if-statement to prevent that.
    if(bat1){
  • kglad
    Jul 21, 2002
    Aug 14, 2012 7:45 AM   in reply to thunderxlight11111
    if(bat1) means is bat1 not null.  ie, before you null bat1 the code within the if-statement (your hittest) will execute.  after you null bat1, that code will not execute and that will prevent the 2007 error.
    if(bat1.stage) checks if bat1 is in the display list.
  • kglad
    Jul 21, 2002
    Aug 14, 2012 11:57 AM   in reply to thunderxlight11111
    you're welcome.
Incoming Links
