dancing_mongoose
The Less-than-a-second value
Aug 14, 2012 2:06 AM
With Premier Pro, I used think that the value was 0.01 seconds, until I found out it only goes up to 24. So what is the actual value? I'm depending on this for my physics EEI.
[IMG]http://i50.tinypic.com/33y1jio.png[/IMG]
The value with a red box around it.
    Aug 14, 2012 3:15 AM   in reply to dancing_mongoose
    The timecode is set to hours;minutes;seconds;frames.
    If your sequence setting is 24 frames per second the timecode will show 0 to 23.
    If your sequence setting is 30 frames per second the timecode will show 0 to 29.
    So the 21 stands for 21 frames.
    As there are : (colon) in between the numbers i gather you are in PAL-land. Pal has 25 frames per second.
    NTSC has ; (semicolon) in between the numbers.
    Aug 14, 2012 6:25 AM   in reply to dancing_mongoose
    That is correct.
    Aug 14, 2012 8:46 AM   in reply to dancing_mongoose
    Mongoose,
    Note that you can change from the SMPT TimeCode (Hrs.;mins.;secs.;frames) to Audio Units, if you need finer adjustment for Audio, as it will be in Sample Rate, say 1/48,000th of a sec.. However, for Video, the lowest unit of time is Frame, as you cannot have partial Frames.
    Good luck,
    Hunt
