borntalent
CS3 audio out of sync
Aug 13, 2012 12:41 PM
Tags: #cs3 #audio #sync
Hello everyone,
    I created an approximately 3min music video in Premiere Pro CS3.  The audio and video are perfectly synced when viewing on the timeline, however, when I export to an mp4 it is off by about 3 seconds.
I used a Sony Handy cam Standard Definition to shoot video footage, and imported the mp3 version of my song into the audio timeline, and lined it up to the clips perfectly.
I exported to an H264 file, and selected the Youtube preset. I changed the frame to 640x480, with NTSC, 29.7fps, 3.0 Level.  I set the Audio at AAC, 128kps sound.  MP4
I have done in this set in the past so I can have a good quality video for youtube upload, and never had a problem until now.  The quality is good enough...but the audio is off sync.
Thanks for any help in advance!!
Brent
  borntalent@hotmail.com
    Aug 13, 2012 2:27 PM   in reply to borntalent
    Render the mp3 to wave and put that on the timeline.
    See if that will help.
    Mp3 is notorious for screwing things up.
    Aug 14, 2012 6:28 AM   in reply to borntalent
    SD from a handycam, would that be a tape camera?
    Did you have any dropped frames while capturing?
    Aug 14, 2012 7:24 PM   in reply to borntalent
    A dropped frame (usually/only ???) occurs when you are playing a tape in a camera/deck and "something" (causes vary) happens to interrupt the flow of data down the Firewire connection... so a frame is not recorded
    When you copy video from a DVD or memory card there is no way (that I know of) to drop anything... you are simply copying a file
    Now... with a camera that records to mini-DVD, there MAY be the possibility of an interruption during the recording process... I don't use that kind of camera, so really don't know for sure if it is possible to have a recording interruption
