bhartwell59
Many shapes, one gradient fill
Aug 14, 2012 7:22 AM
In Illustrator CS4:
I need to fill 20 circles with one common grad fill... so that the 1st circle is dark to the 20th as lightest (NOT each individual circle getting it's own gradient).
I thought this would be easy (clipping mask) but no.
Any ideas?
  • Mathias17
    Feb 20, 2012
    Aug 14, 2012 7:26 AM   in reply to bhartwell59
    Convert all circles into a Compound Path, or simply group them all and assign the gradient at the group level.
    Aug 14, 2012 7:28 AM   in reply to bhartwell59
    Good question. The solution is actually very easy. Select all your objects, then use the gradient tool to draw a line for the beginning and end of your gradient.
  • Mathias17
    Feb 20, 2012
    Aug 14, 2012 7:32 AM   in reply to Mike Gondek
    Right, Mike.
    But unless you group them all together somehow you're left manually selecting each one every time you want to modify the gradient, if you've unselected them and come back later. Probably best to get them all grouped together for easy re-selection.
