IndoorsDave
Horrific PowerPoint Import
Aug 14, 2012 6:23 AM
Anyone know why PowerPoint files import into Captivate with low resolution images? The PowerPoint file has high res images, but in Captivate, looks horrfic.
    Aug 14, 2012 6:27 AM   in reply to IndoorsDave
    You might try changing the Slide Property Quality to High, see image. Hopefully that will make the resolution better.
    Aug 14, 2012 7:52 AM   in reply to IndoorsDave
    What's probably happening here is that the size of the Captivate stage is very different from the PPT sizing, and that's causing some loss of resolution when it scales.
    If you have Captivate 6, try using the new High Fidelity import setting.
    If on an older version of Cp, see if you can modify the setup of the PPT file so that it matches the Captivate slide.  Perhaps that will help. However, (and I know this is NOT what you're going to want to hear) for the ultimate solution that would keep your images at highest resolution, you'd probabl need to build the presentation in Captivate from the start using the same assets.
    Sep 11, 2012 10:23 PM   in reply to IndoorsDave
    ..the High Fidelity function is Windows-only.. booooooo.. all features should be available on all versions.. otherwise, it just creates too much disappointment and confusion..**
    Sep 12, 2012 3:50 AM   in reply to meungawa
    Yes, I just recently found that out, I'm on a MAC and no high fidelity function!
