With Premier Pro, I used think that the value was 0.01 seconds, until I found out it only goes up to 24. So what is the actual value? I'm depending on this for my physics EEI.
[IMG]http://i50.tinypic.com/33y1jio.png[/IMG]
The value with a red box around it.
The timecode is set to hours;minutes;seconds;frames.
If your sequence setting is 24 frames per second the timecode will show 0 to 23.
If your sequence setting is 30 frames per second the timecode will show 0 to 29.
So the 21 stands for 21 frames.
As there are : (colon) in between the numbers i gather you are in PAL-land. Pal has 25 frames per second.
NTSC has ; (semicolon) in between the numbers.
Mongoose,
Note that you can change from the SMPT TimeCode (Hrs.;mins.;secs.;frames) to Audio Units, if you need finer adjustment for Audio, as it will be in Sample Rate, say 1/48,000th of a sec.. However, for Video, the lowest unit of time is Frame, as you cannot have partial Frames.
Good luck,
Hunt
