Open with another application
Aug 14, 2012 8:15 AM
Is it possible to open a photo with another application, without a pre-conversion to tiff by Lightroom? I love Active D-Lighting, it saves me a lot of shadow/highlight recovery, but Lightroom doesn't support it. I edit most of my photos with Capture NX, but I use Lightroom to catalog them and edit others. I can't find a way of opening a nef file directly in CaptureNX from Lightroom.
Thank you.
    Aug 14, 2012 8:31 AM   in reply to madeinlisboa
    You can open a photo with another application, but not from within Lr (except for Photoshop). You can open  NEF on Capture NX by locating it in your OS (Mac Finder / Win Explorer) and go <Open with> but there is no way to do that from within Lr.
    And, when you open a NEF in Capture NX that has previously been edited in Lr the edits will not be visible in Capture NX. And the vice versa is also true: if you edit a photo inCapture NX these edits will not be visible in Lr.
    This is so because both programs write the edits in a proprietary format that can only be read by the program writing it. Apart from that Lr stores the edits in its catalog which can only be read by Lr.
    It all comes down to the following: You either edit in Lr or you edit in Capture NX, but a cross-over editing is not possible - unless you create a TIF after the edit and open that in the other program. By creating a TIF the edits are written into the image pixels which then can be read by any photo editing software - if it can open and read TIfs that is.
    BTW: The Active D-Lighting works only if you shoot JPGs - as far as I know. Far better would be to shoot Raw and edit the highlights in Lr.
    Aug 14, 2012 8:33 AM   in reply to madeinlisboa
    Look up my OpenDirectly plug-in.
    Aug 14, 2012 10:33 AM   in reply to madeinlisboa
    active d lighting does nothing to the raw file.
    it´s capture NX that does the magic.. and LR did not have this nikon feature.
    i would like to see that in future LR versions. but i guess it depends on nikon.
    Sep 2, 2012 4:13 PM   in reply to madeinlisboa
    Sure you can. However it will be a TIFF that you are editing in Capture but I've done it. Simply point LR to Capture NX as an Additional External Editor.
    To do this:
    While in Develop Mode;
    Go to the Edit tab and select Preferences.
    Select External Editing
    In the lower portion of the window you will see the area to add an additional external editor. Simply navigate it to NX and add it.
    Once you've done this you can now go to the Photo tab and select the Edit In. NX should be one of your choices.
