I've done some tests and it looks like clipping mask and pathfinder>crop (CS5) do pretty much the same thing. I realize that clipping mask leaves the paths of the original objects for possible release while crop is creating a new path.
When would you choose to use one vs. the other? The only thing I can think of is when you want to end up with a new object use crop but if you want to maintain the integrity of the original objects use clipping mask.
Is it a toss up?
Tom
Thanks both of you but I'm not sure I'm any closer to understanding.
Maybe I should ask the question about what's different between crop and clip?
From my reading:
Is that it?
You both may be right that it comes down to personal preference. I just want to make sure any differences aren't workflow sensitive.
Tom
[EDIT] I ran a clip test with 3 objects and I may be getting an idea of the important difference between crop and clip.
Clip will keep the fill of the object just below the top object. I used a star over a circle over a rectangle. Where the star was over the circle I got the circle fill. Where the star was over the rectangle (but not the circle) I got the rectangle.
Crop is going to burn right through all the objects below the top object.
It appears crop (pathfinder) is about creating new objects. Clip is very specific to bringing the fill of an object or objects "through" a front shape.
You could accomplish the same effect clip creates but it looks like it would require multiple steps.
I'm new to this so if I have it wrong I'd very much appreciate comments.
Clipping masks hide object areas which fall outside the top shape.
Pathfinder Crop deletes object areas which fall outside the top shape.
Clipping masks = all your original shapes are still in tact, simply hidden.
Pathfinder Crop = Your original shapes are gone and have been edited to create new shapes which conform to the crop boundaries.
Both Clipping Masks and Pathfinder Crop use the top object as a defining area. There is no difference there. I don't see where you're getting "clip uses the top and bottom shapes". That is compeltely inaccurate.
Clipping masks can contain an infinate amount of objects. Pathfinder Crop can also work with a very large number of objects. However, Pathfinder operations can ocassionally have problems with strokes, or symbols, or brushes, becaase they need to be.... well, cropped which may not always fall in a desired location for the object.
In the end it comes down to the inital difference at the start of this very post..... do you want to hide objects or remove them? Do you wish to work destructively or non-destructively? Neither one is "better" they are merely different.
TCarp,
You may also have a look at Object>Path>Divide Objects below (with deletion of outlying paths).
And you may have a look at what happens with strokes.
In any case, always keep a copy of the artwork before you do something irreversible. For more complicated and thorough changes made within a layer, you may simply duplicate the layer and keep the old one as a draft you may go back to.
You're correct. I got that idea from a web tutorial (which is also incorrect).
