Leigh_OTC
Help for Touch Screen application
Aug 7, 2012 1:28 AM
We would like to create a Help for a Touch Screen application.
How different is this to creating a regular HTML or WebHelp?
If there are differences, please tell me what I need to do?
  • RoboColum(n)
    Oct 8, 2004
    Aug 7, 2012 1:55 AM   in reply to Leigh_OTC
    Quite apart from the terminology differences (e.g. click versus tap) the differences largely depend on the devices on which the application will run. Each have their own characteristics (e.g. screen size, resolution, etc) which need to be taken into account. The recently released RoboHelp 10 allows you to output for mobile devices and you'd be best to look at the collateral released around this. Check out these links:
    http://www.adobe.com/uk/products/robohelp.html
    http://www.grainge.org/pages/authoring/rh_tour/index.htm
    Aug 7, 2012 2:37 AM   in reply to Leigh_OTC
    Also see the Announcements in the forums. There are some useful links there.
    @petergrainge
    Aug 14, 2012 7:41 AM   in reply to Leigh_OTC
    You can specify your own screen size, so I'm guessing you will be ok.
    Aug 14, 2012 10:10 AM   in reply to Leigh_OTC
    RoboHelp 10 HTML5 output can indeed help you. Since your application runs on a 23" monitor, you may need to test whether the supplied default layouts suit your needs. Perhaps you can simply use a default layout but it is always possible to design and build a layout specifically catered to this desktop.
    Greet,
    Willam
