Scrollable content inside an MSO bug
Aug 10, 2012 1:05 AM
  Latest reply: Neil Enns - Adobe, Aug 18, 2012 7:03 AM
Replies 1 2 Previous Next
    Aug 14, 2012 9:59 AM   in reply to toutoungi
    Just to update everyone, our internal testing team could not reproduce this issue yesterday, however we have since received files that show the problem from folks in this thread. Our engineers will investigate, hopefully I'll have something to report later today.
    Neil
    Aug 17, 2012 1:10 AM   in reply to Neil Enns - Adobe
    @Neil – can your engineers pinpoint the issue?
    Is there any hint what's causing the bug?
    Uwe
    Aug 17, 2012 11:25 AM   in reply to Laubender
    We were able to reproduce the issue using one of the supplied sample files from this thread. It is a new issue in release 22. The reason some people aren't hitting this is it is specific to the authoring in this situation: the object state has a drop shadow applied to it.
    The workaround is to remove the drop shadow from the object state. If you really need the drop shadow you can create the object state with the drop shadow in Photoshop, export the state as a static image, and place that in the frame.
    Neil
    Aug 18, 2012 4:36 AM   in reply to Neil Enns - Adobe
    Thank you, Neil.
    I looked up the applied drop shadow effect in the data Yves sent me by e-mail:
    x Offset: 0 px
    y Offset: 0 px
    Spread: 0%
    Noise: 0%
    [x] Object knocks out Shadow
    The Size value could be the culprit…
    Is it the Drop Shadow effect only?
    Or are other effects from the Effects Panel causing this, too?
    In my current configuration I cannot test for the bug, because I'm NOT affected…
    Uwe
    Aug 18, 2012 7:03 AM   in reply to Laubender
    Any effect that expands the size of the content outside the frame will cause the issue. Outer glow might do it too.
    Neil
1 2 Previous Next
