div is not floating to the right!
Aug 13, 2012 11:08 PM
http://www.buzzfx.ca/services_new.html
I Need Left and Right Columns On The Page
In the above page I am trying to create left and right columns with about 20px. of space in between.
I created 2 separate divs (a .class named “.column_left" and a class named “.column_right”) and floated one to the left and one to the right.
Problem
The right div is not floating up to the right of the page but staying down to the left and I am unsure why?
The reason the right column may not be floating right is due to the “clearfix” container it is in but this is just a guess.
Important!
I do not want to change the container’s "style" the columns are in because that will change the layout of my whole site unless there is a way to change “only” the container in the above page. But again that may not be the problem.
I hope this all makes some sense.
    Aug 13, 2012 11:45 PM   in reply to Comp. 792
    column_right <div> is NOT floating right because its in one of your column_left <divs>. Why are you using two column_left <divs> when only one is required? Just delete the one that is not required.
    Delete the first instance:
    <div id="main" class="clearfix">
    <div class="column_left"><!-- DELETE THIS -->
    and delete its closing tag:
    </div><!-- DELETE THIS -->
        </div><!-- #main -->
    Aug 14, 2012 10:11 AM   in reply to Comp. 792
    You really just need to make 2 columns on your page and then insert the 3 <divs> into each column.
    Wrapping your 3 left divs in another <div class="column_left"></div> may work without the need to reconstruct the page.
    <div class="column_left">Title 1<img height="188" src="images/2D CHARACTER/THUMB/black_thumb.jpg" width="450" />Lorem ipsum dolor sit amet, consectetur adipiscing elit. Aliquam at lacus nisl, non consequat odio. Nam vel ligula massa. Nullam ligula velit, molestie accumsan fringilla a, facilisis non felis. Nullam blandit ligula metus, nec ultricies erat. Ut quam lorem, sagittis eu aliquam in, malesuada vitae dolor.</div>
    <div class="column_left">Title 3<img height="188" src="images/2D CHARACTER/THUMB/black_thumb.jpg" width="450" /> Lorem ipsum dolor sit amet, consectetur adipiscing elit. Aliquam at lacus nisl, non consequat odio. Nam vel ligula massa. Nullam ligula velit, molestie accumsan fringilla a, facilisis non felis. Nullam blandit ligula metus, nec ultricies erat. Ut quam lorem, sagittis eu aliquam in, malesuada vitae dolor.</div>
    <div class="column_left">Title 5<img height="188" src="images/2D CHARACTER/THUMB/black_thumb.jpg" width="450" /> Lorem ipsum dolor sit amet, consectetur adipiscing elit. Aliquam at lacus nisl, non consequat odio. Nam vel ligula massa. Nullam ligula velit, molestie accumsan fringilla a, facilisis non felis. Nullam blandit ligula metus, nec ultricies erat. Ut quam lorem, sagittis eu aliquam in, malesuada vitae dolor.</div>
          </div>
    Aug 15, 2012 12:55 AM   in reply to Comp. 792
    Comp. 792 wrote:
    Question 1
    So I uploaded an updated file using your suggestion. The “left” column is only 1 column with <br> to separate the content. Did I do this correctly?
    No, you didn't do it correctly. Insert three seperate <divs> within the parent 'column_left' <div> (as below)
    <div id="one">Div One</div>
    <div id="two">Div Two</div>
    <div id="three">Div Three</div>
          </div><!-- end column_left-->
    Comp. 792 wrote:
    Question 2
    I am confused as to why I can’t have individual div’s on the left side without them flowing inside each other. The right side has 3 separate div’s. Is this not possible to do also on the left side?
    If you follow the method above (inserting 3 <divs> into the parent <div>) you do have 3 individual <divs>.
