Hello,
I'm trying to install Photoshop CS6 (trial version) on my Macbook Pro (OS Mountain Lion) but I keep getting an error message at the end of the installation. I tried redownloading the DMG but no success.
I have uninstalled all my adobe programs (even the folder in Library/Application Support) and I'm running out of option now. Do you have any idea ?
Here's the summary of the message error :
Exit Code: 6
Please see specific errors and warnings below for troubleshooting. For example, ERROR: DF024, DW063 ... WARNING: DS012 ...
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 10 error(s), 6 warning(s)
----------- Payload: {0C4E7429-E920-4125-980E-029A87AE0A4D} AdobeColorCommonSetCMYK CS6 4.0.0.0 -----------
WARNING: DS012: LocalizeFile: Localized string not found for locale 'fr_FR' try fetching for en_US(Seq 21)
WARNING: DS012: LocalizeFile: Localized string not found for locale 'fr_FR' try fetching for en_US(Seq 22)
----------- Payload: {C7B1C1B3-368D-4C32-A818-83F1554EB398} AdobeColorCommonSetRGB CS6 4.0.0.0 -----------
WARNING: DS012: LocalizeFile: Localized string not found for locale 'fr_FR' try fetching for en_US(Seq 11)
WARNING: DS012: LocalizeFile: Localized string not found for locale 'fr_FR' try fetching for en_US(Seq 12)
----------- Payload: {48623899-C152-457D-9B30-1F957332AC2F} AdobeColorPhotoshop CS6 4.0.0.0 -----------
WARNING: DS012: LocalizeFile: Localized string not found for locale 'fr_FR' try fetching for en_US(Seq 3)
----------- Payload: {78E38D75-4D92-4F6E-B631-17A436BED680} AdobeColorVideoProfilesCS CS6 4.0.0.0 -----------
WARNING: DS012: LocalizeFile: Localized string not found for locale 'fr_FR' try fetching for en_US(Seq 5)
----------- Payload: {DE7C6FA1-AF75-48A8-B495-CFAD529BCC3D} Recommended Common Fonts Installation 2.0.0.0 -----------
ERROR: DF024: Unable to preserve original file at "/Library/Application Support/Adobe/SavedFonts/current/ACaslonPro-Bold.otf" (Seq 3)
ERROR: DW063: Command ARKDeleteFileCommand failed.(Seq 3)
----------- Payload: {311CDC89-AC18-4344-9EC9-0225328C73D3} Required Common Fonts Installation 2.0.0.0 -----------
ERROR: DF024: Unable to preserve original file at "/Library/Application Support/Adobe/SavedFonts/current/AdobeArabic-Bold.otf" (Seq 3)
----------- Payload: {9124DF4E-617D-486B-A970-8FA632244F24} Adobe Photoshop CS6 Core 13.0.0.0 -----------
ERROR: DF024: Unable to preserve original file at "/Library/Application Support/Adobe/HelpCfg/de_DE/goURL_lr_photoshop_de.csv" (Seq 2191)
ERROR: DW063: Command ARKDeleteFileCommand failed.(Seq 2191)
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050: - Required Common Fonts Installation: Install failed
ERROR: DW050: - Adobe Photoshop CS6 Core: Failed due to Language Pack installation failure
ERROR: DW050: - Adobe Photoshop CS6 French Language Pack_AdobePhotoshop13-fr_FR: Install failed
ERROR: DW050: - Recommended Common Fonts Installation: Install failed
System Requirements
Thanks in advance !
I have also tried contacting the support team via phone... That was honestly the worest experiance of my life. Hold time was longer that predicted which is understandable, however trying to charge someone $40.00 for a trial install issue is bad business flat out! I wanted to install the trial to see if I even wanted to buy the program...If I cannot even install the trial why would I spend $$$$ for the real thing, this is terrible marketing and leaves cutomers angry and feeling used.
@gcoop7711 I apologize for the experience you had with our support team. We actually don't charge for support for installing the trial software. If you have a case number from your interaction it would be appreciated. This will allow me to review the case history and provide the appropriate feedback.
As for how to adjust please see solution #2 in Error "Exit 6" or "Exit 7" | Install log | Read, write, system file errors | CS5, CS5.5 - http://helpx.adobe.com/creative-suite/kb/error-exit-6-exit-7.html. For Emyn_Muil I would recommend adjusting the permission on /Library/Application Support/Adobe/ and then make sure to complete step #6 for applying the permission changes to the enclosed items.
For gcoop7711 please adjust the permissions as is appropriate for your particular error message.
I've changed the permissions for the folder /Library/Application Support/Adobe/ and all the enclosed items but I'm still getting the same error message :
Exit Code: 6
Emyn_Muil then you will want to review your installation log in it's entirety to see if you have any other directories which you are having permissions issues on. You can find directions on how to accomplish this at Troubleshoot with install logs | CS5, CS5.5, CS6 - http://helpx.adobe.com/creative-suite/kb/troubleshoot-install-logs-cs5 -cs5.html.
I've checked the PDApp.log : I have no [FATAL], only some [ERROR] :
| Tue Aug 14 23:35:41 2012 | [ERROR] IMSLib - Failed in getting value for key in OPMGetValueForKey |
| Tue Aug 14 23:35:41 2012 | [INFO] IMSLib - Failed to get default user for clientId in fetchDefaultUserInfoForClientId... |
| Tue Aug 14 23:35:41 2012 | [ERROR] LWANative - failed in IMSLib's fetchDefaultUserInfoForClientId function, in getDefaultUserForClientId |
Appart from that, the only line that says "failed" is this one :
[INFO] OPM - Failed to set default attributes for File :/Users/XXX/Library/Application Support/Adobe/OOBE/opm.db error:1
I've checked this folder, the permissions are OK. Do you have any idea of what causing this problem ?
Not with the amount of information currently available. Typically you will want to review the PDApp.log file if you are not able to initialize the installer. Can you please run the Adobe Support Advisor - http://www.adobe.com/support/loganalyzer/ and choose the package for support option. Please then respond to this thread with your token number. Myself or another Adobe employee can then review your installation logs in it's entirety.
Interestingly , we have just the PDApp.log file in the Token , no install logs
Navigate to the log files in at
• Mac OS: /Library/Logs/Adobe/Installers/
The log filename includes the product name and install date, followed by ".log.gz." The extension .gz indicates a compressed format.
You can put it on the pastebin.com and share the link here.
BTW , as per the discussion and Install log snap shot , please try the below steps and check :-
Please Run following commands on "Terminal" on the machine (this will remove the corrupt fonts and should allow you to run the installer successfully) -
sudo mv "/Library/Application Support/Adobe/SavedFonts/current/ACaslonPro-Bold.otf" /tmp/
sudo mv "/Library/Application Support/Adobe/HelpCfg/de_DE/goURL_lr_photoshop_de.csv" /tmp/
Hello,
Thanks for your answer. I tried installing Photoshop CS6 once again but the folder /Library/Logs/Adobe/ remains empty (there is no "Installers" folder). Are the log files hidden ?
I also tried to run the operations above on the terminal but I get the following message :
Mac:~ XX$ sudo mv "/Library/Application Support/Adobe/SavedFonts/current/ACaslonPro-Bold.otf" /tmp/
Password:
mv: rename /Library/Application Support/Adobe/SavedFonts/current/ACaslonPro-Bold.otf to /tmp/ACaslonPro-Bold.otf: Operation not permitted
Mac:~ XX$ sudo mv "/Library/Application Support/Adobe/HelpCfg/de_DE/goURL_lr_photoshop_de.csv" /tmp/
mv: rename /Library/Application Support/Adobe/HelpCfg/de_DE/goURL_lr_photoshop_de.csv to /tmp/goURL_lr_photoshop_de.csv: Operation not permitted
My mistake for missing this , "mv" command can be used to move or rename the file however I wanted to move the file to the temp folder and not rename it but took it for rename becuase of the syntax of the command.
Please retry the below command one more time :-
sudo mv "/Library/Application Support/Adobe/SavedFonts/current/ACaslonPro-Bold.otf" "/tmp/abc"
sudo mv "/Library/Application Support/Adobe/HelpCfg/de_DE/goURL_lr_photoshop_de.csv" "/tmp/abc"
Secondly , Please run the Adobe cleaner tool and then login with the root user account and then try to install it.
Hello,
I'm sorry but I'm still getting the error message (even when logged with the root account) :
Mac:~ XX$ sudo mv "/Library/Application Support/Adobe/SavedFonts/current/ACaslonPro-Bold.otf" "/tmp/abc"
Password:
mv: rename /Library/Application Support/Adobe/SavedFonts/current/ACaslonPro-Bold.otf to /tmp/abc: Operation not permitted
Mac:~ XX$ sudo mv "/Library/Application Support/Adobe/HelpCfg/de_DE/goURL_lr_photoshop_de.csv" "/tmp/abc"
mv: rename /Library/Application Support/Adobe/HelpCfg/de_DE/goURL_lr_photoshop_de.csv to /tmp/abc: Operation not permitted
Does it means that it worked ?
Mac:~ XX$ sudo mv /Library/Application Support/Adobe/SavedFonts/current/ACaslonPro-Bold.otf /tmp/abc
usage: mv [-f | -i | -n] [-v] source target
mv [-f | -i | -n] [-v] source ... directory
Mac:~ XX$ sudo mv /Library/Application Support/Adobe/HelpCfg/de_DE/goURL_lr_photoshop_de.csv /tmp/abc
If it does, I'll run the Adobe cleaner and then login with the root account to install it.
Ok so I did everything you said (ran the Adobe Cleaner and then login with root account to install) but I still get the same error message at the end :
Exit Code: 6
- 0 fatal error(s), 12 error(s), 6 warning(s)
----------- Payload: {EB2A8CD4-B247-4810-A294-E3DB8EDC6060} Adobe CSXS Extensions CS6 3.0.0.0 -----------
ERROR: Exception caught in Custom Action for payload {EB2A8CD4-B247-4810-A294-E3DB8EDC6060}
----------- Payload: {36682D68-3834-487E-BA49-DFA4AB0A2E32} Adobe CSXS Infrastructure CS6 3.0.0.0 -----------
ERROR: Exception caught in Custom Action for payload {36682D68-3834-487E-BA49-DFA4AB0A2E32}
Run the mentioned command on terminal(this will remove the corrupt profiles)
sudo mv /Library/ColorSync/Profiles/Profiles/Library/ColorSync/Profiles/Profi les_bkup
else
Rename the following folders on your machine:
/Library/ColorSync/Profiles/Recommended
Restart the computer and start the installation.
I recently had to install CS6 suite onto my Macbook pro. Indesign was no problem. Photoshop and Illustrator downloaded OK but would not launch!!! The adobe tech's spent hours trying to solve the problem, I chucked stuff out, I used adobe cleaner, I re-installed, and re-installed, I nearly went bald with the stress of it all ... then one brilliant tech suggested I check that my Macbook was "a Multicore Intel processor with 64-bit support". BINGO! That was the problem. PS and Illustrator need 64bit support. Indesign can run on older macbook pro's 32bit. Fortunately for me my husbands newer 64bit mac can run all 3 programs! I hope this will help your situation... if not it may stop someone else from prematurely going bald ![]()
