TallMeerkat1243
Automating Variables and Data Sets
Aug 12, 2012 11:31 AM
Hello,
I want to create a cross platform browser droplet that takes 14 jpegs from one folder and using variables and datasets imports them into a template. I can do this but it requires a lot of user interaction which defeats the object as it is for different users to use with little photoshop experience.
  1. Sort by date created in folder A
  2. Batch rename and move to folder B
  3. Open Template psd
  4. Import Data Set ( a txt file) and apply to template psd
  5. Save Template psd as pdf or jpg in folder B>”for print” folder
  6. Clear template
  7. Move originals from folder B to  folder C as backup
  8. Close Save Template psd
I am creating an action set that opens a file in which I have created layers as variables to do pixel replacements. The data set is a txt file. And all works OK when I do it manually. However, not all the actions are being recorded for automation.
I have the action 4 for eg working as far as image>variables>data sets. But after that the commands are not being recorded. I have tried insert menu item but going further than “data sets” is not being recorded. So," import>select file>ok>use first row as... >replace existing data>ok>apply>ok" is not being recorded. The same for the other actions that require a file being selected etc.
I have installed the javascript scriptlistener but it is not recording the code either. It seems that some of the photoshop objects and variables are not accessible. Is this true or am I missing something
How should I be doing this please? I've watched loads of videos and done lots of research but I am at a dead  end.
Thanks, TallMeerkat
Windows 7, ps cs5
