Is Illustrator CS5 performance better than Illustrator CS6?
Jan 8, 2013 10:23 PM
Tags: #illustrator #lag #cs6 #jumpy
  Latest reply: hemmickreef, Mar 29, 2013 9:08 AM
Replies 1 2 3 4 5 Previous Next
    Jun 22, 2012 8:53 AM   in reply to Brent Blaskievich
    Dual Monitor 1920 x 1200, what I did was collapse all panels and restart illustrator and worked
    Jun 22, 2012 10:22 AM   in reply to paulzaragoza
    ATI Radeon HD 5870/1024VRAM driving dual monitors: 23" ACD-1920 x 1200, 30" ACD-2560 x 1600. The 23" holds all the palettes and the 30" is the work area.
    I've been reading the various suggestions to shut down the palettes or turn off thumbnails in Layers. Sorry, but that's simply unacceptable. Particularly thumbnails, It's like driving with your windshield painted black. I need to see that stuff. Constantly going to the Layers options to turn it on and off is real work flow kill.
    I can work on my  large industrial designfile  in PS5 all day and not have issues. Running the same workspace(s) in PS6, the slowdown becomes an issue. Again, I'd like to point out that a session doesn't start out slow immediately. It progresses over time....suggesting some sort of buffer problem or memory leak.
    If it turns out that it's how PS6 now deals with dual monitors and/or palette population, I expect Adobe to deal with it and improve the performance to at least where it was in CS5. Can't wait to see what the next revision brings.
    Judging by the amount of reads this subject is getting, I'd say it is a concern to more users than those contributing to this thread.
    Jun 25, 2012 2:09 AM   in reply to Brent Blaskievich
    Is that just on Macs? Im running on WIndows and can't seem to see anything about an Application Frame......
    Jun 25, 2012 2:34 AM   in reply to Ironhide001
    Yes Application Frame is there only on Macs.
    Jun 25, 2012 1:59 PM   in reply to Brent Blaskievich
    For me it does drop performance, it's annoying having to work with a crippled Illustrator.
    I know this is not the thread but Bridge CS6 keeps crashing and crashing, this CS6 release is not what I hoped for.
    Jun 25, 2012 3:03 PM   in reply to paulzaragoza
    You clearly have a cache problem and or a permissions problem and why you are not reading the article I posted I do not understand it will offer you the remedy you need but you have to read it and yes you have to do some work and if you do this it will bhe fine.
    I dumped my cache because I lost some performance which I had initially gain with CS 6 but once I repared the permissions and dumped the personal cahe files all was back to normal and now that I got  my additional 8 GB of memory back so that I now have 17 GBs things are working really well.
    Here is the article it is long but offers you the answers you need so you need to read and I think if you don't read it you should stop complaining because it is your own fault zI have yet to see the Bridge crash in CS 6 thought once in a while CS 5 has so this is definitely your problem.
    'Here article
    http://helpx.adobe.com/x-productkb/global/troubleshoot-unexpected-beha vior-user-account.html
    BTW the application frame or the number of opened panels has no effect on performance here, but then I dumped the personal cache files.
    Jun 25, 2012 3:13 PM   in reply to Wade_Zimmerman
    Actually I read the instructions for fixing this the first time you post them. And I followed them and did the work it required, in fact I installed Illustrator in other computer and fails also. For me it's not so clear even following the post. So that's why I'm still complaining.
    Jun 26, 2012 12:14 AM   in reply to Brent Blaskievich
    From the discussion so far, it appears that any one of the following is causing a problem:
    1. Font cache(Try clearing font cache)
    2. Layers Panel (Try to work by keeping it closed)
    3. Screen Resolution (Try to work by changing the screen resolution or working in single monitor)
    The intention here is that you should be able to find the cause of the problem and not change the way you work. But trying the above things is important because if we succeed to find the exact cause, then getting the solution would be easy as we can report it to Adobe then. I am not sure if discussions like this forces Adobe to fix the problems. It needs to be reported as Bug.
  • Mathias17
    Feb 20, 2012
    Jun 26, 2012 6:50 AM   in reply to Priyanews
    Sorry to hear about the ongoing problems, gents. I am as surprised as I am elated that the issues are absent from PC's.
    Jun 27, 2012 1:11 AM   in reply to Mathias17
    Something funny just occurred to me as I did my work on AI CS5 today. I asked myself: what is the functional difference between AI CS6 and the old, pre-CS v9.0 of Illustrator?
    AI CS6 doesn't come in a box heavy enough to be used as a doorstop.
    Jun 27, 2012 2:28 AM   in reply to Mathias17
    i wouldn't say they are totally absent. I am running PC version, and i am having some issues. Just noticed that the panning using the hand tool is struggling to cope and wont refresh in real time.
    Jul 2, 2012 9:44 AM   in reply to Brent Blaskievich
    Panning and moving around in Illustrator has become slower with every version in my experience. I always found this incredibly frustrating. When I switched from Windows to PC I noticed a difference in this respect as well. It's not a huge difference but CS4 on my old PC (running XP) felt more snappy for sure.
    So I tried messing around with OSX's beamsync settings. I found this utility called QuartzSimple to disable beamsync on OSX. After turning this off, CS4 on my Mac feels a lottt more snappy. To illustrate the difference, try working in outline mode (with a relative simple doc) and switch back to normal mode. Panning and zooming in outline mode is just faster. With beamsync turned off it's as if I'm working in outline mode all the time which is just a lot more comfortable. It should always be like this Adobe! Especially if you're working with art that isn't too complex.
    For anyone who would like to try the QuartzSimple trick. I uploaded it to my Dropbox as I cannot find the original link anymore. As far as I know there are no risks and I've never experienced anything bad because of it (after doing this for 3 years) but don't blame me if you blow up your computer pls ; ). Just make sure to force quit the prog so that it doesn't revert back to 'automatic beam sync', otherwise you won't see any difference.
    Unfortunately QuartzSimple doesn't make as big of a difference in CS6 as it does on CS4 but you should see some improvement. Depends also on your hardware specs of course. I'm running CS4 on a MacBook Pro 5.5 / OSX 10.6.8 with 8GB of ram, no external screen attached.
    Download here:
    https://dl.dropbox.com/u/1091814/Various/QuartzSimple.zip
    Jul 2, 2012 12:30 PM   in reply to Brent Blaskievich
    Brent Blaskievich wrote:
    Thanks for posting that, couldn't find it online anywhere when someone mentioned it before.
    Looks like it lowers the refresh to me. Goes from 4fps to 2fps in CS6. CS5 goes from 30 to 5. I don't have CS4 to compare though.
    Anything special you did to activate it?
    Yeah, I think that was me ; ).
    Run the prog, enter Tools/Beam Sync Tools and select Disable Beam Sync.
    Do not quit the app, go back to Illustrator (you won't need to restart Illustrator), create a new doc with some basic graphics and move around your doc. Turn on automatic beamsync to set it back to the default behavior. You should see a difference. Do not enable Tools/Quartz Extreme. That didn't work very well for me at least. Like I said, the difference is less in CS6 than CS4 but there's still a small 'performance' difference. CS4 runs very smooth for me with beamsync disabled. As long as the art work is not too complex it feels like outline view which is nice and the way it should imo.
    Also note that, if you do not want Quartz running in the background after you disabled beamsync, you have to force quit it so that the settings stick. If you simply quit it, it will revert back to automatic beamsync and you won't notice any difference.
    Don't forget that when you log out or restart OSX, it resets itself to the default setting (automatic beamsync) and you have to enable it again. There's no way around this as far as I know but it's a minor inconvenience and I restart OSX rarely anyway.
    This also improved perfomance in SketchUp for me btw.
    Jul 8, 2012 5:17 AM   in reply to Wade_Zimmerman
    I've got the same freaking problems on Windows... and my system is a 2xQuad Xeon 5430, Quadro FX4600 768MB (similiar to Mac Pros)... not a slow machine at all..zooming, panning is a pain in the *** on Illustrator CS6.
    A simple test... create a A3 zise new document, maximize the window, and start zooming in and out (Alt+ Scroll Wheel). It's slower than my old machine (Intel Q6600). I've noticed that the smaller the Illustrator Window is the better the performance is. It's like adobe made a deal with intel and want's to cripple Illustrator on older machines just to upgrade.
    For example on a low end laptop (i3 380M, GeForce GT540M 1GB) Illustrator works, zooms and pans perfectly! Imagine that!
    Is it a Xeon problem?? I have no idea but something is rotten here!
    Should I sell my machine and buy some new i5/i7 Ivy Bridge generation system?
    Jul 8, 2012 6:07 AM   in reply to dpcdpc11
    It is not the xeon processor I have a MacPro original and an A3 size Document alt (option) scroll wheel zooms in out really fast, I would say way to fast. Did you check your settings for you mouse?
    Is your card working properly.
    Have tried trashig your caache files?
    Do you have any plugins? Any od fonts like free ones installed?
    Jul 8, 2012 6:24 AM   in reply to Wade_Zimmerman
    Of course it's not a mouse problem... come on, I'm not a noob.
    Video card driver is up to date. I've even replaced my video card with an older Radeon HD 3870 and still the same sluggish performance in Illustrator.
    Yes, I've deleted the cache files.
    Plugins... none!
    I've got 2 fonts installed: Aller and Ubuntu... both verified fonts which can't be the reason for the slow performance. On my older machine (intel Q6600) I've got over 100 fonts installed and zooming works much better in Illustrator CS6 than on my xw8600 dual xeon machine. Is my machine FUBAR?? I've tested it in 3D Marks and gets really good scores.
    All the coolers are new ones... temperatures are normal... running out of options here... hopefully I won't have to throw my workstation out the window!
    Jul 9, 2012 7:25 AM   in reply to dpcdpc11
    Any ideas to the problem above? Really any ideas are welcome!
    I've seen done a little digging around the web and I think this generation of Xeon just can't take certain operations without chocking one CPU instead of using the other ones as well. So I think the CPU is to blame... I just can't believe it's performs so badly on Illustrator CS6!
    Aug 13, 2012 9:39 PM   in reply to Brent Blaskievich
    I have to agree with this as I have the same issue. It stutters and only updates once you stop scrolling. My program is crashing every 5 mins. REALLY DISSAPOINTED.
    Aug 14, 2012 3:03 PM   in reply to shanewi11iams
    Hey All,
    At my workplace we recently switched to CS6. I tried everything I could: exploring possibility of corrupt account, cleared font cache, turned off smart guides, worked in outlines. None of it worked.
    Then I found the culprit: live previewing in the following panels (any of them previewing will cause this issue) : Layers panel and Navigator panel. This is why working in outlines didn't even help because the computer re-draws all of your data live in full color for your live previews, thus eating up all your ram.
    I find that there is still a memory leak in CS6 but I can live with that flaw. Minimizing/closing these panels seem to have fixed laggy issues in my office, certain key commands not working properly and "possessed" cursors.
    Just turn off the panels mentioned above, hopefully you experience a vast improvement in performance. As a precaution, I also keep my following panels minimized when not needed: Artboards, Links, Appearance.
    Hopefully this helps you, it certainly has benefitted the office I work at.
  • Mathias17
    Feb 20, 2012
    Aug 14, 2012 3:06 PM   in reply to Galateah
    So pathetic . . .
    Why is this not fixed yet? Are you kidding me???
    Aug 14, 2012 3:33 PM   in reply to shanewi11iams
    Hey williams,
    Could you please share with us your pc/mac specs? I really want to get to the bottom of this and I cant believe how poor Illustrator CS6 is performing on my workstations. I've changed my HDD with a SSD but still the same poor performance.
    I now think it may has something to do with the video card. A strange thing I've noticed in Photoshop: if Use video hardware acceleration is on, the performance is not that good. For example when I hit Ctrl+T (free transform) I have to wait about 2 seconds before I can do anything, other wise works instantly.
    I use a Radeon HD3870 and also tried a Nvidia Quadro FX 4600 and the result is the same.
    Maybe the two xeon cpus must br paired with a recent generation video card? Not sure if I should buy a new video card or not. I found a pretty well priced GeForce 460. But before I buy it I want to be sure I'm not spending my money for nothing.
    @Galateah... I've tried turning off and minimizing all the panel and still this problem persists. It just makes me throw my workstation out the window. Cant believe it works better on my older desktop pc and there's no memory leak there. I feel the impact of the memory leak pretty hard on the workstation after about 15-20 minutes in Illustrator. Everything becomes slow and heavy.
    Galateah, could you also share wih us your specs please?
    Aug 14, 2012 3:49 PM   in reply to dpcdpc11
    Do you run with the Navigator panel open?
    Aug 14, 2012 5:09 PM   in reply to Galateah
    Considering how the same palette arrangement I use in CS5 (using all those you mention above) doesn't affect the performance a whit, I find this "workaround", as helpful as it is, to simply be unacceptable as far as workflow speed is concerned. Do we really need to be constantly turning on and off mission critical UI components to achieve the same performance level as the previous version? I think not.
    I'm now suspecting Illustrator's Mercury Performance System implementation. Premier and After Effects took a huge screen performance hit in the initial CS6 release. Their last revision seems to have solved it. Maybe someone on the Illustrator team could call over over to the Premier/AfterEffects team and ask them what they did to improve screen performance.
    Aug 16, 2012 1:50 PM   in reply to dpcdpc11
    Hey dpcdpc11,
    Here are my specs (copied from my sys profiler):
    Hardware Overview:
      Model Name:    iMac
      Model Identifier:    iMac11,1
      Processor Name:    Intel Core i7
      Processor Speed:    2.8 GHz
      Number Of Processors:    1
      Total Number Of Cores:    4
      L2 Cache (per core):    256 KB
      L3 Cache:    8 MB
      Memory:    8 GB
      Processor Interconnect Speed:    4.8 GT/s
      Boot ROM Version:    IM111.0034.B02
      SMC Version (system):    1.54f36
    Running OS 10.6.8
    Our office runs off of networked accounts, I've noticed that has affected performance quite a bit too.
    I just thought I'd share my two cents because   all of us in my office experienced quite an improvement in the performance of AI CS6 after turning these panels off... enough improvement so that we can actually work again. The switch had originally left us very crippled an unable to get our work done.
    The way we use Illustrator is very unique because we do lots of fashion illustration with tonnes of pattern swatches, and we constantly max out our 100 artboard limit... this is why any live previewing was killing our performance speed so much. Hope that gives you a a little more insight.
    We had upgraded from CS4 where having the layers panel or navigation panel open was never an issue before.
    Cheers.
    p.s. Making amendment, you can choose from the little drop down menu in your layers palette "Panel Options" and turn off "Thumbnails" for Layers as an alternative ... but you'd have to do this with each different/new file you open.
    p.p.s. Found another preview thumbnail that seems to slow things down a little. In the "Appearance" palette.
    Aug 17, 2012 10:44 AM   in reply to Galateah
    Have you noticed any difference between files that were created in CS6 vs. files that were originally created in an earlier version and then saved as CS6?
    Aug 18, 2012 9:38 AM   in reply to Galateah
    Hey Galateah... thanks for sharing your specs!
    One more thing... could you also tell us what video adapter are you using? I think the problems comes from the Video Hardware Accelation and the Mercury Engine which doesn't really play nice with all the graphic cards.
    It's strange that there are no update neither from Photoshop or Illustrator to address this problem. Like I said in a previous post... this slow performances makes me throw my Workstation out the window and I don't think this is the best solution!
    Aug 20, 2012 2:22 PM   in reply to angelamyers
    Hey angelamyers,
    Yes and no. For a brief period, I thought the issue was using CS4 files in CS6 but then after about an hour, quickly realized that CS6 simply has gremlins when it tries to do any live thumbnail previews. Not sure if that answers your question?
    Aug 20, 2012 2:24 PM   in reply to dpcdpc11
    Hey dpcdpc11,
    Does this answer your question?
    ATI Radeon HD 4850:
      Chipset Model:    ATI Radeon HD 4850
      Type:    GPU
      Bus:    PCIe
      PCIe Lane Width:    x16
      VRAM (Total):    512 MB
      Vendor:    ATI (0x1002)
      Device ID:    0x944a
      Revision ID:    0x0000
      ROM Revision:    113-B9110C-425
      EFI Driver Version:    01.00.383
      Displays:
    iMac:
      Resolution:    2560 x 1440
      Pixel Depth:    32-Bit Color (ARGB8888)
      Main Display:    Yes
      Mirror:    Off
      Online:    Yes
      Built-In:    Yes
      Connection Type:    DisplayPort
    Display Connector:
      Status:    No Display Connected
    And Oh yes, I know what you mean by wanting to throw your machine across the room.
    Aug 28, 2012 7:14 AM   in reply to Galateah
    I don't believe all of this is still going on.  Adobe obviously did something that specifically degrades performance.  Illustrator is broken.  There should be no need to update/ugrade anything in a vector drawing program that worked wonderfully in the last version.  It feels like I'm being targeted.  And there is nothing in the program to change video settings, say, like in photoshop.
    Aug 28, 2012 7:35 AM   in reply to babygenius55a
    Has anyone installed the newest CS6 update that was released yesterday?  I'm wondering if that addressed any of these performance issues.
    Aug 28, 2012 11:40 AM   in reply to angelamyers
    13 listed fixes but nothing addressing the perfomance issues discussed here.
    http://helpx.adobe.com/illustrator/release-note/illustrator-cs6-0-1-re lease-notes.html
    Aug 28, 2012 1:54 PM   in reply to Frank Heller
    Currently testing the updated version 16.0.1 and don't see any improvements here!
    I've listed my dual Xeon workstation up for selling cause I can't use it in Illustrator. I know my CPUs are a bit old but their still powerfull enough to handle a software like Illustrator but it seems AI CS6 prefers newer CPUs or something... I still don't have any explanation for my low performance in AI.
    Sep 18, 2012 11:34 AM   in reply to dpcdpc11
    I wouldn't sell your system, it's not the computer, it's illustrator. I have an i7 980X, 256 Intel 502 SSD, 24GB Geforce GTX690 and Illustrator CS6 still runs like a two-legged DOG!  My experience tells me it's a buggy POS, with an obvious memory leak somewhere. Added to the failure of effectively testing this application prior to release, they've now made all perpetual-licensees second class citizens. If I'm going to dump anything, it's going to be Adobe.
    Here's why I'm thinking of looking elsewhere;
    • Illustrator's performance is worse than previous versions and they're not too swift at fixing it.
    • The help system is total crap, hasn't been fixed in two versions.
    • New features (including the number one requested, file packaging) are only available to CC members, despite the fact that non-CC users pay more.
    Here's the link to the Zorro file
    http://forums.adobe.com/message/4415348#4415348#4415348http://
    Aug 29, 2012 2:45 AM   in reply to Frank Heller
    yep, same problems persist. Navigator window crashes Illustrator if i try and use it. And there was me thinking i might actually be able to work at the speed i use to before the Nav window became such a pain.
    Aug 29, 2012 3:59 AM   in reply to Ironhide001
    If they don't want your money, what can you do except request a refund until a faster, more stable version/fix is released?  There is always cs5.5, or open source even.  Inkscape is actually a wonderful program.
Actions
Bookmarked By (1)
