I am trying to burn a DVD in Adobe Premiere Elements 10. The original footage is in 1920x1080 from a Canon HD camcorder. I just burned a project last week that burned fine. This one is burning with horizontal lines that appear to be "pixelating" the faces of people in the video. I've tried interlacing, reversing field dominance, and exporting to an mpeg first, but all with the same result. When I make the footage into an mpeg, it is crystal clear on the screen. As soon as I burn it to DVD, it messes up. I have a feeling it has to do with the program not appropriately converting it to the correct format for DVD, but appear to be missing something. Any suggestions?
The AVI file is extremely fuzzy and I notice lines in it as well. Trying to burn to DVD to see the outcome.
I should followup to my original post by adding this - I am editing a dance recital video. I have already completed several of these in the past few weeks and have had NO problems. Nothing different - same equipment, same file type, same DVDs, same program, same computer. Plenty of HD space available also.
Are you judging this DVD quality when played on a TV and standalone DVD player? It should look fine there.
If you're playing it on your computer, a number of issues could be at work. Most computer playback software doesn't de-interlace well. (DVDs are interlaced, most TVs are interlaced and computers are not.)
So try it on your TV/DVD player. And, if you want to give it a test run on your computer, play it with a program like VLC Media Player, which does a better than average job of de-interlacing. But don't play it at full-screen. DVDs are only the equivalent of 640x480 in size, while computer monitors are usually at least 4 times that resolution and can exaggerate issues.
All of this would expain why you're not seeing this interlacing issue when you output a WMV.
Yes,judging on a TV - and I've tried it in both a DVD player and blu-ray (which does upconvert). I tried it on a 32" and 40" TV, and both had the same result.
In the meantime, I found a workaround that works much better. I rendered it to a high-quality mpeg-2 in PE10, and then burned it to DVD in Sony DVD Architect 5. Quality is outstanding. I assume it's something with how PE10 is converting it to DVD quality. I'm still interested in figuring out to do it all in PE though. Thanks.
Not sure what may be wrong in the workflow - I have been editing videos like this the same way since I got the program, and none have caused problems until I got to this one, and nothing has changed. Even though it's an extra step using DVD Architect, it works great for now. Once I finish with these projects, I'll consider looking for something else that has more punch to it... Considering going MAC and getting Final Cut Pro. Thanks for all of the suggestions.
Before going with FCPx, you might want to see these videos:
http://teamcoco.com/video/conan-editors-love-final-cut (note: ad before Video)
Good luck,
Hunt
Brian,
Thanks for that workaround! I ran into the exact same problem of low-res DVD output from PrE 10, the very day that you posted..
Not only deos Sony DVD Architect 5 solve that problem, but it also allowed me to construct a usable DVD menu, which PrE was also making impossible for me.
