U ch
VUYA
May 15, 2013 4:12 PM
Thank you for having you replay.
I'm going to make AE Plug-In to work on Premiere pro.
I find at the SDK_Noise sample(AE SDK sample), I renewed a part of the "Render" function as follows
and carried it out.
but,
in the case of "src ①", noise_param.u.ld.data is "ARGB" format,
in the case of "src ②", noise_param.u.ld.data is "VUYA" format.
why are formats different "src ①" and "src ②" ?
static PF_Err
Render (
          PF_InData                    *in_dataP,
          PF_OutData                    *out_data,
          PF_ParamDef                    *params[],
          PF_LayerDef                    *output )
     else if (destinationPixelFormat == PrPixelFormat_VUYA_4444_8u)
          PF_ParamDef noise_param;
          AEFX_CLR_STRUCT(noise_param);
          ERR(PF_CHECKOUT_PARAM(  in_dataP,
                                                             0,
                                                             in_dataP->current_time,
                                                             in_dataP->time_step,
                                                             in_dataP->time_scale,
                                                             &noise_param));
          ERR(suites.Iterate8Suite1()->iterate( in_dataP,
        0,
        linesL,
        &noise_param.u.ld,                             // src ①
        //&params[NOISE_INPUT]->u.ld,         // src ②
        NULL,
        (void*)&niP,
        FilterImageVUYA_8u,
        output));
          ERR(PF_CHECKIN_PARAM(in_dataP, &noise_param));
    Aug 14, 2012 5:37 PM   in reply to U ch
    it is all dependant on the source footage format.
    Aug 15, 2012 10:13 AM   in reply to U ch
    Source files are different:
    eg:     DV, MPEG2, MPEG4 is compressed YUV420 -> Converted in Importer to YUVA4444 -> PrPixelFormat_YUVA_4444_8u
              MotionJPEG is compressed RGB -> Converted in Importer to BGRA4444 -> PrPixelFormat_BGRA_4444_8u
              Apple ProRes 10bit YUV422 -> PrPixelFormat_YUVA_4444_32f
    In your plugin register supported PrPixelFormat_* of what you can process.
    eg: If you only process PrPixelFormat_YUVA_4444_32f register only that PrPixelFormat.
    version<CS5.0 you MUST support PrPixelFormat_BGRA_8u
    version>CS6.0 Premiere Pro will convert to your format.
    I recommend you make your plugin using PrPixelFormat_YUVA_4444_32f only.
    Aug 16, 2012 9:26 AM   in reply to U ch
    Hi U ch,
    Have you confirmed that the pixel formats of the two buffers are different using pixelFormatSuite->GetPixelFormat()?
    Zac
    Aug 17, 2012 1:45 PM   in reply to U ch
    Ah yes, so in CS5.5 and earlier, frames retrieved from Premiere Pro using PF_CHECKOUT_PARAM() are always 8-bit ARGB.
    New in CS6,  you can optionally specify that PF_CHECKOUT_PARAM() should pass back frames in the same pixel format being requested by the current render.  In the AE CS6 SDK, in PrSDKAESupport.h, PF_UtilitySuite4 contains EffectWantsCheckedOutFramesToMatchRenderPixelFormat().  Your effect should make this call during PF_Cmd_GLOBAL_SETUP, which is the same selector where an effect would already advertise support beyond 8-bit RGB using AddSupportedPixelFormat().  After making that call, the two frames in your example above will be VUYA_32f.
    Cheers,
    Zac
    Aug 20, 2012 5:20 PM   in reply to U ch
    The PPro SDK has some sample code for you to start with.  See the ConvertFromBGRA32fToVUYA32f() in SDK_File.cpp.  You'll need to modify this to handle ARGB rather than BGRA_32f.  And you'll need to do the reverse function to get back to ARGB.
Incoming Links
