Bugs With Flash Player in Chrome
Aug 6, 2012 9:17 AM
There are two major issues with Flash Player in Chrome:
1) You often end up with multiple Flash Players enabled in chrome://plugins which can conflict.  By disabling all but one of them, many problems go away (see this link for more details: http://www.lockergnome.com/media/2012/01/20/how-to-fix-shockwave-flash -crashes-in-google-chrome/).
2) When PepperFlash version 11.3.31.222 was released (around July 31, 2012) ip-multicast abilities stopped working and HDS video plays audio with black video.  All of this worked fine in earlier versions of Flash Players in Chrome (assuming you took care of 1 above).
Sincerely,
Greg Pulier
    Aug 9, 2012 8:24 AM   in reply to gpulier
    Thank you for the post, gpulier.
    I would just like to say i've found, "You often end up with multiple Flash Players enabled in chrome://plugins which can conflict" very true.
    A lot of 'page(s) unresponsive'... The crash on websites i've found today - also on prior occasions - signalled a new Shockwave Flash Plugin, (ver: 11.3.31.225) had been automatically updated and dually enabled with my prefered older one.
    Well, it's been updated, so i did enabled the new 11.3.31.225 on its own to test out - I do hope it's one that is stable! - but on Chrome you have to check 'chrome://plugins' quite frequently of late...
  • Chris Campbell
    May 4, 2010
    Aug 10, 2012 10:51 AM   in reply to Zumm.x.2
    I believe it's fine if you have multiple copies enabled in chrome, this is the default for all installs.  From what I can tell, Chrome uses the top one and ignores the rest.
    Aug 23, 2012 4:23 AM   in reply to gpulier
    Hi guys,
    I'm currently working on a project where Stage3D comes into play and after reading, that some problems with the flash player in Google Chrome exist, I gave it a try and updated Chrome. Wow, after the update has finished I noticed a dramatic decrease in performance!
    Here are my findings:
    Having all player-versions marked as aktiv in chrome://plugins
    Versions:
    11.3.31.230
    11,3,300,271
    11,4,402,265
    Chrome is using 11.3.31.230
    I see in the Away3D stats that software rendering is used. Performance is terrible! 8-10 Frames
    Deactivating 11.3.31.230
    Chrome is using 11,3,300,271
    I see in the Away3D stats that hardware acceleration is used (DirectX9). Performance is great! 58-60 Frames
    Deaktivating 11,3,300,271
    Chrome uses 11,4,402,265
    As with 11,3,300,271 great performance.
    I fear not a lot of people are changing manually their used flash plugin in Chrome and they will blame Flash for melting down their computers.
    Wolfgang
  • Chris Campbell
    May 4, 2010
    Aug 23, 2012 1:19 PM   in reply to Wolfgang Klopf
    Hi Wolfgang,
    I'll follow up with your report with our internal Chrome team.  In the meantime, would you mind opening a new bug report on this over at the Chromium bug database?
    http://code.google.com/p/chromium/issues/entry
    Chris
  • Chris Campbell
    May 4, 2010
    Aug 23, 2012 1:38 PM   in reply to Chris Campbell
    This slowdown might be related to this existing Chromium bug: https://code.google.com/p/chromium/issues/detail?id=142507
    Aug 23, 2012 10:49 PM   in reply to Chris Campbell
    Hi Chris,
    I've opened a new bug:
    http://code.google.com/p/chromium/issues/detail?id=144583
    kind regards
    Wolfgang
    Oct 7, 2012 4:29 PM   in reply to gpulier
    Hi all!
    I've just now tested on both Windows and Linux Chrome version 22.0.1229.79
    this flash :
    http://bit.ly/QWWQXd
    after a while (about 2 minutes) the following error message will appear:
    Shockwave Flash has crashed...
    No other browser and platfrom configuration can reproduce this crash, with this flash animation.
