Boy this is turning out to be a pain...
Here's what I'm trying to do:
Migrate a site from a US datacentre - to the Australian one.
I'm following this guide: http://kb.worldsecuresystems.com/203/bc_2038.html
When it comes to migrating webapps, on this guide: http://kb.worldsecuresystems.com/208/bc_2080.html
It has this image:
But on the admin I'm using it has this in the same location:
I'm logged in as the admin, where can i adjust settings to "see" everything like an admin should?
Or is it a case of "this depends on what hosting account" the site is running?
Do you have to do that via adobe support (get them to do it), or can you do it when you take it live?
You can do it yourself with no support needed. I just like to build them with all the tools available just in case. Way easier to downgrade at going live stage than it is to upgrade during development. Actually once it is live it is easy to upgrade it to eComm as well.
Not sure what you are getting at Liam? I have never experienced any issues downgrading a site at going live stage. As long as the package you select supports everything you used in the site.
For example, if you use web apps, even though you can downgrade it, you won't have access to the tools for them in the admin. But if you create a site at eComm level and you end up not using any web apps or ecommerce for example I have never had a problem downgrading at time to go live.
A lot easier than trying to upgrade a site that hasn't gone live if original scope didn't call for web apps but then client decided he wanted something you need web apps for you have the tools already to build it.
But as I say, if the plan you downgrade to supports what you actually have on the site, I have never run across any known issues.
I think it should be made known that if you're editing a template (e.g. from BCgurus) and you a) want to edit a menu, or b) want to simply edit a web app, you MUST select a higher hosting plan to begin with.
These templates come loaded with things you can't edit (as an admin) if the hosting plan is too low.
