      • EspaƱol
      • FranƧais
      • PortuguĆŖs
  • ę—„ęœ¬čŖžć‚³ćƒŸćƒ„ćƒ‹ćƒ†ć‚£
  • ķ•œźµ­ ģ»¤ė®¤ė‹ˆķ‹°
error #2007
Participant ,
Aug 15, 2012 Aug 15, 2012
hi , how are you all? i hope you fine...
iam trying to make a game but when the object hit object to delete  another object i get these errors
TypeError: Error #2007: Parameter hitTestObject must be non-null.
at flash.display::DisplayObject/_hitTest()
at flash.display::DisplayObject/hitTestObject()
at MAIN/onEnterFrame()
and here is the class
(iam sure the problem from this class because i closed all the classes except 1 )
package  {
import flash.display.MovieClip;
import flash.events.Event;
public class MAIN extends MovieClip {
  public function MAIN() {
addEventListener(Event.ADDED_TO_STAGE,onAddedToStage)
public function onAddedToStage(event:Event):void
addEventListener(Event.ENTER_FRAME,onEnterFrame )
  public function onEnterFrame (event:Event)
    if (hero.hitTestObject(bat1) && (bat1) && (bat1.stage))
     healthbar1.width -=1
     trace("HHH")
    if (healthbar1.width >=  80 && healthbar1.width <=  100 ){
     zelda1.gotoAndPlay(1)
    if (healthbar1.width >=  60 && healthbar1.width <=  80){
     zelda1.gotoAndPlay(2)
    if (healthbar1.width >=  40 && healthbar1.width <=  60){
     zelda1.gotoAndPlay(3)
    if (healthbar1.width >=  20 && healthbar1.width <=  40){
     zelda1.gotoAndPlay(4)
    if (healthbar1.width >=  0 && healthbar1.width <=  20){
     zelda1.gotoAndPlay(5)
    if (hero.hitTestObject(portal2)){
     var map2:MAP2 = new MAP2
     addChild(map2)
     if(map1.stage){
     removeChild(map1)
     if (hero.hitTestObject(portal3) && (portal3) && (portal3.stage) && (bat1)){
      var map4:BACKGROUND = new BACKGROUND();
      if(bat1){
     removeChild(bat1)
     bat1.removeEventListener(Event.ENTER_FRAME, onEnterFrame);  // this doesn't need to be done unless you added a listener outside the Bat1 classs
     bat1 = null;
   removeChild(portal3)
   portal3 = null
i talked about this problem before in this discuss
http://forums.adobe.com/message/4620620#4620620
and all the project with the image here
http://forums.adobe.com/message/4615780#4615780
i tried alot to check with if statement the bat1 object but this error still.
thank you
ActionScript
6.8K
Community Expert , Aug 16, 2012 Aug 16, 2012
if this thread's problem is resolved, mark helpful/correct responses.
you're not following directions.  use the code i suggested.
using
if(hero.hitTestObject(bat1)&&bat1)
is NOT the same as
if(bat1){
if(hero.hitTestObject(bat1))
Participant ,
i did this
if(bat1){
if(hero.hitTestObject(portal2)){
     removeChild(bat1)
     bat1 = null;
portal3 = null
but you know , after this code this if statement doesn,t work
i dont know why , does the bat become null before that for another reason
thank you
Participant ,
ohh sorry, forget that comment i missed somethig there
here
package  {
if (bat1){
if (hero.hitTestObject(bat1) )
trace("HHH")
addChild(map2)
if(map1.stage){
removeChild(map1)
if(hero.hitTestObject(portal3)){
     removeChild(bat1)
     bat1 = null;
the error still exist
can i give you the fla file , maybe if you take closer look it will be easy to you , if you dont mind?
thank you for your replay
use:
package  {
if (bat1){
trace("HHH")
addChild(map2)
if(map1.stage){
removeChild(map1)
     removeChild(bat1)
     bat1 = null;
Participant ,
i copied it then i pasted it , but the problem still the same?
thank you again for your replay
then you copied incorrectly.
here's your code properly formatted so you can see the if(bat1) statement do not effect the portal2 hittest:
package {
            addEventListener(Event.ADDED_TO_STAGE,onAddedToStage);
        public function onAddedToStage(event:Event):void {
            addEventListener(Event.ENTER_FRAME,onEnterFrame);
        public function onEnterFrame(event:Event) {
            if (bat1) {
                if (hero.hitTestObject(bat1)) {
                    healthbar1.width-=1;
                    trace("HHH");
                if (healthbar1.width>=80&&healthbar1.width<=100) {
                    zelda1.gotoAndPlay(1);
                if (healthbar1.width>=60&&healthbar1.width<=80) {
                    zelda1.gotoAndPlay(2);
                if (healthbar1.width>=40&&healthbar1.width<=60) {
                    zelda1.gotoAndPlay(3);
                if (healthbar1.width>=20&&healthbar1.width<=40) {
                    zelda1.gotoAndPlay(4);
                if (healthbar1.width>=0&&healthbar1.width<=20) {
                    zelda1.gotoAndPlay(5);
            if (hero.hitTestObject(portal2)) {
                var map2:MAP2=new MAP2  ;
                addChild(map2);
                if (map1.stage) {
                    removeChild(map1);
            if (hero.hitTestObject(portal3)) {
                var map4:BACKGROUND=new BACKGROUND  ;
                removeChild(bat1);
                bat1.removeEventListener(Event.ENTER_FRAME,onEnterFrame);// this doesn't need to be done unless you added a listener outside the Bat1 classs
                bat1=null;
Participant ,
i copied it , but the problem still
sorry mr.kglad
here is the link of the project
http://www.2shared.com/file/fIo-BLEw/project__4__.html
thankyou for your replay
Participant ,
ohh , sorry forget that
the problem comes after going to the portal 3
Participant ,
no the problem still ?!
i sent the link to you
here
maybe if you take closer look you will know the reason because you are very good in flash , but with me i did all my best but i couldn,t
Participant ,
ok , i will try to do that, i mean to fix it alone
thx mr.glad for your help
you're welcome.
p.s.  someone else might download and correct your file but i generally don't download and correct files unless i'm hired.  if you have a question or problem with code, post it in the adobe forums and you'll probably get free help.
Participant ,
Aug 17, 2012 Aug 17, 2012
ohh , ok thx
but i realy have project in my college i should finish it  before 3 months
sorry mr.kglad iam not sure if i get this sentence " download and correct files unless i'm hired"
i realy need that person ,help me and explain my errors , so can you help me and i can pay for that if you dont mind?
if you have problem you can just ignore this message
sorry again if i said something wrong
ok.
i actually do download and correct files without being hired but only if people offer to pay for my time (like you did).  my feeling is, if it's not worth anything to the person with the problem, it's not worth my time.
anyway, i downloaded and checked your file.  use:
                if(bat1){
                    removeChild(bat1);
                    bat1.removeEventListener(Event.ENTER_FRAME, onEnterFrame);// this doesn't need to be done unless you added a listener outside the Bat1 classs
                    bat1=null;
Participant ,
Aug 18, 2012 Aug 18, 2012
thank you alot mr.kglad.
you're welcome.
