error #2007
Aug 15, 2012 4:08 AM
hi , how are you all? i hope you fine...
iam trying to make a game but when the object hit object to delete  another object i get these errors
TypeError: Error #2007: Parameter hitTestObject must be non-null.
at flash.display::DisplayObject/_hitTest()
at flash.display::DisplayObject/hitTestObject()
at MAIN/onEnterFrame()
and here is the class
(iam sure the problem from this class because i closed all the classes except 1 )
package  {
import flash.display.MovieClip;
import flash.events.Event;
public class MAIN extends MovieClip {
  public function MAIN() {
addEventListener(Event.ADDED_TO_STAGE,onAddedToStage)
public function onAddedToStage(event:Event):void
addEventListener(Event.ENTER_FRAME,onEnterFrame )
  public function onEnterFrame (event:Event)
    if (hero.hitTestObject(bat1) && (bat1) && (bat1.stage))
     healthbar1.width -=1
     trace("HHH")
    if (healthbar1.width >=  80 && healthbar1.width <=  100 ){
     zelda1.gotoAndPlay(1)
    if (healthbar1.width >=  60 && healthbar1.width <=  80){
     zelda1.gotoAndPlay(2)
    if (healthbar1.width >=  40 && healthbar1.width <=  60){
     zelda1.gotoAndPlay(3)
    if (healthbar1.width >=  20 && healthbar1.width <=  40){
     zelda1.gotoAndPlay(4)
    if (healthbar1.width >=  0 && healthbar1.width <=  20){
     zelda1.gotoAndPlay(5)
    if (hero.hitTestObject(portal2)){
     var map2:MAP2 = new MAP2
     addChild(map2)
     if(map1.stage){
     removeChild(map1)
     if (hero.hitTestObject(portal3) && (portal3) && (portal3.stage) && (bat1)){
      var map4:BACKGROUND = new BACKGROUND();
      if(bat1){
     removeChild(bat1)
     bat1.removeEventListener(Event.ENTER_FRAME, onEnterFrame);  // this doesn't need to be done unless you added a listener outside the Bat1 classs
     bat1 = null;
   removeChild(portal3)
   portal3 = null
i talked about this problem before in this discuss
http://forums.adobe.com/message/4620620#4620620
and all the project with the image here
http://forums.adobe.com/message/4615780#4615780
i tried alot to check with if statement the bat1 object but this error still.
thank you
  • kglad
    Jul 21, 2002
    Aug 15, 2012 6:49 AM   in reply to thunderxlight11111
    you're not following directions.  use the code i suggested.
    using
    if(hero.hitTestObject(bat1)&&bat1)
    is NOT the same as
    if(bat1){
    if(hero.hitTestObject(bat1))
  • kglad
    Jul 21, 2002
    Aug 16, 2012 6:52 AM   in reply to thunderxlight11111
    use:
    package  {
    if (bat1){
    if (hero.hitTestObject(bat1) )
    trace("HHH")
    addChild(map2)
    if(map1.stage){
    removeChild(map1)
    if(hero.hitTestObject(portal3)){
         removeChild(bat1)
         bat1 = null;
    the error still exist
    can i give you the fla file , maybe if you take closer look it will be easy to you , if you dont mind?
    thank you for your replay
  • kglad
    Jul 21, 2002
    Aug 16, 2012 7:04 AM   in reply to thunderxlight11111
    then you copied incorrectly.
    here's your code properly formatted so you can see the if(bat1) statement do not effect the portal2 hittest:
    package {
                addEventListener(Event.ADDED_TO_STAGE,onAddedToStage);
            public function onAddedToStage(event:Event):void {
                addEventListener(Event.ENTER_FRAME,onEnterFrame);
            public function onEnterFrame(event:Event) {
                if (bat1) {
                    if (hero.hitTestObject(bat1)) {
                        healthbar1.width-=1;
                        trace("HHH");
                    if (healthbar1.width>=80&&healthbar1.width<=100) {
                        zelda1.gotoAndPlay(1);
                    if (healthbar1.width>=60&&healthbar1.width<=80) {
                        zelda1.gotoAndPlay(2);
                    if (healthbar1.width>=40&&healthbar1.width<=60) {
                        zelda1.gotoAndPlay(3);
                    if (healthbar1.width>=20&&healthbar1.width<=40) {
                        zelda1.gotoAndPlay(4);
                    if (healthbar1.width>=0&&healthbar1.width<=20) {
                        zelda1.gotoAndPlay(5);
                if (hero.hitTestObject(portal2)) {
                    var map2:MAP2=new MAP2  ;
                    addChild(map2);
                    if (map1.stage) {
                        removeChild(map1);
                if (hero.hitTestObject(portal3)) {
                    var map4:BACKGROUND=new BACKGROUND  ;
                    removeChild(bat1);
                    bat1.removeEventListener(Event.ENTER_FRAME,onEnterFrame);// this doesn't need to be done unless you added a listener outside the Bat1 classs
                    bat1=null;
  • kglad
    Jul 21, 2002
    Aug 16, 2012 8:15 AM   in reply to thunderxlight11111
    if this thread's problem is resolved, mark helpful/correct responses.
  • kglad
    Jul 21, 2002
    Aug 16, 2012 9:38 PM   in reply to thunderxlight11111
    you're welcome.
    p.s.  someone else might download and correct your file but i generally don't download and correct files unless i'm hired.  if you have a question or problem with code, post it in the adobe forums and you'll probably get free help.
  • kglad
    Jul 21, 2002
    Aug 17, 2012 6:44 AM   in reply to thunderxlight11111
    ok.
    i actually do download and correct files without being hired but only if people offer to pay for my time (like you did).  my feeling is, if it's not worth anything to the person with the problem, it's not worth my time.
    anyway, i downloaded and checked your file.  use:
                    if(bat1){
                        removeChild(bat1);
                        bat1.removeEventListener(Event.ENTER_FRAME, onEnterFrame);// this doesn't need to be done unless you added a listener outside the Bat1 classs
                        bat1=null;
  • kglad
    Jul 21, 2002
    Aug 18, 2012 7:24 AM   in reply to thunderxlight11111
    you're welcome.
