So this is driving me up the wall. I have a form which has a multiple line input field and for some reason the data is getting thrown up to the top on every new page the field flows over to. Oddly though, the field itself seems to be sized correctly. I feel like i've validated everything that can possibly be done.
- Made sure every subform is flowed & allows page breaks
- Field allows page breaks and is multiple lines
- Loading data from XML dynamically and form is dynamic
Oddly enough, I copied the entire page into a new form and the paging seems right. So now I'm comparing the XML source trying to find the root of the problem. Any thoughts?
Don't see a way to attach forms here?
You can use a file sharing service such as Acrobat.com and post a link her to allow us to download your form.
Ok, you can download the adobe form and corresponding XML data from here:
https://dl.dropbox.com/u/6687172/Adobe%20Issues/Fixed_Form_1.pdf
https://dl.dropbox.com/u/6687172/Adobe%20Issues/original_data.xml
Please help
Great! Wow, I can't believe i didn't know that in had to be saved that way. But we learn something new every day... thanks so much!!!
I did have another question relating to another error I am getting ( I believe around special characters ). Can I post it here or should I create a new forum post?
So in that same form, once it's set to dynamic and you bring it up. Scrolling down yields a ton huge errors that take up the whole screen, they are shown in alert boxes and read "Invalid Value <content of fields>".
The contents of these fields are loaded with special characters which users are copy pasting in here and I really have no control over that. Alot of thoughts here, like do I need to embed fonts, install some updates to the readers, etc.? Most importantly though is not showing these errors. I expect you see them on your screen after you saved the form to being dynamic? (I saw these when i copy pasted the form into a new one and now again after following your suggestion above).
