Form is not submitting to the databases
Aug 15, 2012 10:55 AM
Hello,
I'm having an issue right now. Everything i click the complete registration page on this site.
https://www.encourageexcellence.org/registration.php
The values entered won't submit nor return any error messages. Could you show me what I'm doing wrong? Here is the code
[CODE]
<?php
if (isset($_POST['submitted'])){
    require_once('Connections/encourage.php');
$fields = array(
    'email',
    'state',
    'district',
    'gender',
    'age',
    'profession',
if (safe($_POST['survey']=="Yes")){
    $survey = "Yes";
else{
    $survey = "No";
foreach($fields as $fieldName) {
    if(isset($_POST[$fieldName]) and safe(trim(stripslashes($_POST[$fieldName]))) !==''){
        $$fieldName = safe(trim(stripslashes($_POST[$fieldName])));
    }else {
                $errors[] = "Please enter your". $fieldName .""; //code to validate fields
    if(filter_var($email, FILTER_VALIDATE_EMAIL) == true){
    } else {
        $errors[] = 'Please enter a valid email address';
if(!isset($errors)){
    $query = "SELECT user_id FROM participants WHERE email='$email'";
    $result = mysql_query($query);
    if(mysql_num_rows($result) == 0) {
$query = "INSERT INTO participants (email, state, district, gender, age, profession, survey, registration_date)
VALUES ('$email', '$state', '$district', '$gender', '$age', '$profession','$survey', NOW())"; //databasse connection
    $result = mysql_query ($query);
if ($result){
    $url = 'http://'. $_SERVER['HTTP_HOST'] . dirname($_SERVER['PHP_SELF']);
    if ((substr($url, -1) == '/') || (substr($url, -1) == '\\')) {
        $url = substr ($url, 0, -1);
    $url .= '/thanks.php';
    header("Location: $url"); //This is the line of error that is reporting after submitting to the database
    exit();
    } else {
        $errors[] = 'You could not be registered due to a system error. We apologize for any inconvenience.';
        $errors[] = mysql_error() . '<br /><br />Query: ' . $query;
    } else {
        $errors[] = 'The email address has already been registered.';
    mysql_close();
    } else {
        $errors = NULL;
if (!empty($errors)){
            echo '<h1 id="mainhead">Error!</h1>
        <p class="error">The following error(s) occurred:<br />';
        foreach($errors as $msg) {
            echo " - $msg<br/>\n";
        echo '</p><p>Please try again.</p><p><br/></p>';
function safe($string)
        $pattern = "/\r|\n|\%0a|\%0d|Content\-Type:|bcc:|to:|cc:/i";
        return preg_replace($pattern, '', $string);
<!----html code-->
<form id="form1" name="form1" method="post" action"registration.php">
  <fieldset class="first">
  <label class="email" for="email">Email:* </label>
  <input name="email" value="<?php if(isset($_POST['email'])) echo $_POST['email'];?>"/>
  <label for="state"/>State:* </label>
  <input name="state" value="<?php if(isset($_POST['state'])) echo $_POST['state'];?>"/>
  <label for="schooldistrict"/>School District:* </label>
  <input name="district" value="<?php if(isset($_POST['district'])) echo $_POST['district'];?>" />
  <label for="gender">Gender:* </label>
<select name="gender">
   <option>Choose Your Gender</option>
   <option value="male" <?php echo ($form['gender'] == 'male' ? ' selected' : ''); ?>>Male</option>
   <option value="female"<?php echo ($form['gender'] == 'female' ? ' selected' : ''); ?>>Female</option>
</select>
    <label for="age"/>Your Age:* </label>
  <input name="age" type="text" class="age" maxlength="2" value="<?php if(isset($_POST['age'])) echo $_POST['age'];?>"  />
  <label for="profession"/>Profession:* </label>
  <input name="profession" value="<?php if(isset($_POST['profession'])) echo $_POST['profession'];?>" />
  <label for="survey"/>Willingness to participate in future surveys:</label>
  <input name="survey" type="checkbox" value="Yes" />
  </fieldset>
<fieldset>
  <input name="submit" type="submit" class="btn1" value="Complete your Registration" />
<input class="btn" name="reset" type="reset" value="Clear Form" />
<input type="hidden" name="submitted" value="TRUE" />
</fieldset>
  </form>
[/CODE]
Thanks in advanced!
    Aug 15, 2012 11:18 AM   in reply to atlnycdude24
    The form HTML is incorrect.
    you're missing a  = after action
    Aug 15, 2012 12:03 PM   in reply to atlnycdude24
    You are also not asking it to connect to a database, your "action=registration.php" is telling it to connect to itself. That action should be going to your form processing script.
    Aug 15, 2012 12:17 PM   in reply to atlnycdude24
    I have never heard of a php form processing script that functions the way you describe. The form processing script is usually a separate entity stored on the server that is called into action by the form when info is sent to it.
    At least that's how every pre-made form script I've ever used has worked. Maybe you're just trying something that's way over my head. There's likely a php coder here somewhere that can help you get it running, might take a while to get your answer though.
    Aug 15, 2012 1:39 PM   in reply to atlnycdude24
    Yep, over my head.
    Have a good one.
