is it me, or is illustrators snap system a little buggy?
Aug 15, 2012 10:02 AM
is it true that you cannot snap multiple points at once? as in, selecting 3 vertices on 3 separate paths, and moving them to a point on the grid? they don't snap
    Aug 15, 2012 10:17 AM   in reply to Pacoan
    Yes, it's been forever this way, but I see no rational reason why it should behave differently. It would be even more confusing, if multiple point selection jsut zapped together and snapped al lto the same point.
    Mylenium
    Aug 15, 2012 10:59 AM   in reply to Pacoan
    If you have several lines selected, your lines will snap to the grid using the line you clicked on last to snap, as long as you have view >> snap to grid enabled. If after you drop the lines you want each of them to snap individually to the grid you cannot do that, and most people would not want that.
    Aug 15, 2012 2:13 PM   in reply to Pacoan
    Multiple points snap in Illustrator but with the original space between points preserved. In some programs snapping and aligning vertically or horizontally can be done in one step. For example moving several selected points on different horizontal or vertical level by dragging on of them can snap the point being dragged and and also align the rest of the selected points to it horizontally or vertically. If this is what you want in Illustrator it has to be done in two steps first align horizontally or vertically all selected points and then drag and snap one of them and the rest will go along with it.
    Aug 15, 2012 2:36 PM   in reply to Pacoan
    Yeah, that's annoying, they programmed it so that the point being dragged can snap to itself, so if the target is very close to the point the snapping can get the point itself than the target. Who on earth would want to snap the point being dragged to itself - there is undo for that.
    Well that's the case with smart guides and snap to point, if  snap to grid is on then snapping point to itself won't interfere
  • Mathias17
    Feb 20, 2012
    Aug 15, 2012 2:57 PM   in reply to Pacoan
    I don't get along with Illy's snaps, either. You're not the only one. Using AutoCAD for a few years spoiled me. If Adobe would just steal AutoDesks snaps I'd be very happy. Both AutoCAD and 3D Studio Max have such great snapping.
    Course, I'd rather they fix the performance slogs first . . .
