PSRem
Can no longer open CS3 on new PC
Aug 15, 2012 10:20 AM
Hi all
I have recently bought a new windows 7 computer, HP 1250ea it has a i7 processor and 6g memory.
I then loaded PS CS3 which I have been using on my old XP PC for years and it would no longer open raw files.
Both Bridge and PS give me the error message "Could not complete your request because it is not the right kind of document"
I have version 4 camera raw and I cant seem to update it either by using the Help > Updates in PS or downloading the latest version from the Adobe Website
I am using a Canon 40D
Hope that is enough information for someone to help.
Rem
    Aug 15, 2012 10:27 AM   in reply to PSRem
    You need at least 4.2, believe last version is 4.6.   When you try to update what error do you get?  Sometimes using a different browser to download files works.
    You can tell what version is installed in PS Help/about plugins/camera raw.
    Aug 15, 2012 10:54 AM   in reply to PSRem
    Usually when you get "no updates available" it means it is up to date.  And no, you do not have to update on old computer.
    Did you deactivate copy on old machine and then re-activate on new?
    Go here  -   Program Files/COMMON Files/Adobe/Plug-ins/CS3/File Formats.  Should be one file there, which is Camera Raw.8bi
  • Noel Carboni
    Dec 23, 2006
    Aug 15, 2012 10:53 AM   in reply to PSRem
    PSRem wrote:
    I tried downloading an update from the wesite and followed the installation instructions but that didnt work either.
    Please don't make people beg you for specific information when they're trying to help you.
    You're lucky someone here is willing to give you their time to try to help you debug your problems.  Make it easy for them.
    -Noel
    Aug 15, 2012 11:41 AM   in reply to PSRem
    I mentioned the deactivation as you can only have 2 copies activated at the same time.  If you have to deactive, as even if you junk your old computer, or your hard drive crashes, it is still considered an activated copy.
    Whether there is an error message or not is not telling.  If it installed more than one version in the file location ACR will not work.  So check the location and see if there is more than one fle there.  You could put a tilde (key usually under escape key) in front of it so computer does not see it.  Then download ACR again.  If this works delete the camera raw file with tilde.
    Aug 15, 2012 5:51 PM   in reply to PSRem
    To deactivate the old copy you have to open PS and click on Help.  Deactivate is about halfway down on the memu.  You can get by if you only loaded it twice.
    The ACR file (.8bi) MUST be in the location I specified.  That is where PS and Bridge will look for it.  It is is Program Files (x86)/COMMON FILES - - - - - as shown in post #3.
