Janine G.
Shared Content error
Aug 15, 2012 4:44 PM
Tags: #plug-in_missing
I have a CS5 file that I am trying to open in CS5.  However I'm getting a shared plugin error.  Help!  I thought this only occurred when you were trying to open files between different versions of InDesign.
    Aug 15, 2012 6:04 PM   in reply to Janine G.
    I'll bet that it's not a CS5 file. It's either CS5.5 or CS6.
    Bob
    Aug 15, 2012 10:46 PM   in reply to Janine G.
    That is actually put there by the operating system. It just tells you the name of the program that the file which it will open with. Any .indd file will say "kind:InDesign® CS5 Document" if you have CS5 set as your default progam to open .indd files. You should try downloading a trial of CS6 and see if it opens there.
    Aug 15, 2012 10:55 PM   in reply to Janine G.
    If you really need to, you can install a CS6 trial, and save it as an .IDML file, and then open it in CS5.
    Aug 15, 2012 11:51 PM   in reply to Janine G.
    Newer versions can open older versions, but not vice-versa. So yes it can open the file.
