Hello,
This occurs both with XP Pro SP3 and Win7 iSP 1 . On a XP Pro SP3 without domain connection the crash does not occur. According to the event log caused ntdll.dll the crash.
Addendum: The XML is created correctly. this happens to all book projects, new and old. Does anyone have an idea?
You seem to have missed installing four updatte patches. Try installing those in order and see if this fixes things first.
For the updates see: http://www.adobe.com/support/downloads/product.jsp?product=22&platform =Windows
You could try checking your version of ntdll.dll (a Windows protected system file) for corruption using the "sfc /scannow" command. This replaces corrupted protected system files with the correct MS ones. Also, you could then check if there are any issues with the DirectX graphics (the drivers could be affecting the FM behaviourr) on your system using the DXDIAG utility.
However, as it seems to happen on two systems, the corruption doesn't seem that likely of a culprit. Are you using FM with the structure or unstructured interface, i.e. is your workflow creating the XML using the Save As XML from unstrucured files or are you exporting the XML from a structured application?
