Philip Galea
Disable Lightroom 4 video support option?
May 27, 2012 12:03 PM
Tags: #synchronize #folder_structure #lr4 #slow_synchronizing
Is there a way to disable lightroom 4 from importing or processing any file with a video extension mkv, 3gpp etc, as its really slowing down my workflow.
My typically workflow consists of pulling my files off of my memory carsd manually via explorer (into a specific folder under a root folder which I create manually).  I then synchronise the root folder in lightroom.
Unfortunately LR4 seems to take over and hour to do this since I have a lot of uncateloged videos.  LR fails each time to catalog the videos.
LR3, since it didn't support video, was blazingly fast and performing the same operations in LR3 takes minutes as oppose to hours.
Philip
    Aug 16, 2012 5:05 AM   in reply to Philip Galea
    you can not disable the video import or disable video support altogether... afaik.
    and unfortunately you can´t exclude them when synchronizing a folder (i have the same problem).
    but you can exclude videos from import easily. at least that. no help for the synchronize problem... i know.
    press the ALT key and you can select/deselect all video files in the import dialog.
    http://i.imgur.com/z8sFS.jpg
