Dear Forum,
Running CS5.5 and I'm having errors when I publish, debug, or preview:
Error creating SWF movie file.
Be sure the destination file is not read-only or opened by another application. Also, check that the file name is not too long.
This error pops up constantly, and occasionally does not pop up at all. I sometimes find myself hammering Alt+Shift+F12 for twenty times before I get "through". I've seen a number of past topics on this issue, but none of the solutions presented in there seemed permanent solutions. Does anyone have any idea? It's killing productivity, really.
Thanks in advance.
A really annoying behavior of Flash CS5.5 and before is the last location you export a SWF to is the location a new document may try to publish to. Or if that path cannot be found it may reset to exporting the SWF to the same folder the FLA is in. REALLY annoying that each FLA does not remember publish paths properly.
I get this error when I do not go into publish settings, hit browse on the SWF output location and explicitly set it every time I open a FLA. Try hitting your publish settings and set the export location of the SWF. The error may go away.
Hi there,
It seems the problem does not occur when the virus software is disabled. For the record, I'm using ESET NOD32 Antivirus. I'm completely unfamiliar with how to tweak antivirus software, and disabling it while working with Flash Professional also is kind of a nuclear solution. If anyone knows how this can be resolved, please... but I suspect it's difficult without identifying why NOD32 blocks the transaction in the first place...
Thanks for your help.
I finally found an answer at http://stackoverflow.com/questions/5368925/adobe-flash-error-creating- flash-movie-file-destination-directory-doesnt-exist
I am posting it here. Maybe it help others.
I have been banging my head on this same problem for days. Reading you post here about disabling NOD32 (yes, I am also using NOD32), I tried your suggestion, and ... it totally worked!! Thanks very much, I am very grateful.
Man it would be interesting to know why NOD32 cuases this to happen.
I recently bought a new laptop PC, bought and installed NOD32 (version 5.2) on this machine too. And to my surprise, the problem with publishing did not occur anymore. So I checked my other machine, and updated NOD32 to the latest version... and wow, the problem seems to have disappeared! So you might want to look into that.
Sincerely,
werz
Always suspect any software whos sole job is to intercept data to be a potential problem. That's why I ask about it first every time
Just adding a couple keywords in the post so others having the same issue can find it on google.
Eset, NOD, NOD32, Norton, McAfee.. Hope it fixes someone elses issues.
