SaneDevil
Detecting when a variable:URLVariables receives data
Aug 16, 2012 6:34 AM
Tags: #air #event #as3.0 #actionscript3
Hi
Is it possible to add a 'Change' event listener to URLVariables similar to adding addEventListener(Event.CHANGE, function) to a textinput?
I'm loading data and need to detect when it has completed and send those variables to another class.
Basically I need to know when it's 'safe' to retrieve the data from my URLVariables variable and that means I need to detect a change on URLVariables.
I have a workaround using a textinput that is changed in the complete function and then loads the data into a seperate URLVariables var meaning I have a textinput to dedect change and then another variable that hold the actual data which is a waste...
  • kglad
    Jul 21, 2002
    Aug 16, 2012 6:40 AM   in reply to SaneDevil
    you can detect whenever data is received by using the Event.COMPLETE listener and listener function.  whether data is new, changed or previously defined and unchanged, you'll need to code yourself after your complete listener function is called.
